[Pre-Release] macOS Ventura
Guys please help, I’m at a loss with Ventura on AMD. It boots and installs but instead of the initial setup I get a black or grey screen. It sometimes goes past this but when I get to network selection I get an instant reboot. Monterey works great. Attached my EFI for diagnosis.
Kernel patches need to be updated for Ventura
MaxKernel is Wrong (if you are using this EFI for ventura
Also GPU device injection is wrong (you do not need of it
Yea I am trying to use this on Ventura. I will update the min max values and remove GPU injection and try again when I can. What is the new max? Can we just use 99.99?
I got the kernel patches from the amd-OS X GitHub so I assumed they were correct.
Edited by SavageAUS
you have 21.99.99 in this EFI
for Ventura is 22.99.99
Hai nel plist 21.99.99 per ventura e' 22.99.99
By the way here are in an italian part of this forum
if you like, open a thread in International section of macos86.it and i think your system will boot in Ventura OS also with Clover bootloader 😛 😛
A proposito, qui siamo in una parte italiana di questo forum
Se vuoi, apri un thread nella sezione Internazionale di macos86.it e penso che il tuo sistema si avvierà in Ventura OS anche con il bootloader Clover 😛 😛
You have in the plist 21.99.99 for fortune and '22.99.99
By the way, here we are in an Italian part of this forum
If you want, open a thread in the International section of macos86.it and I think your system will boot into Ventura OS even with the Clover bootloader 😛 😛
I have tried Clover but I get a KP.
I will update my patches and test again. I will post in international section next time, my apologies. Google translated this forum into English so I thought nothing of it.
@SavageAUS
Create a thread in International area of macos86.it and post a your working EFi with Monterey 12.4 or 12.5 beta (OpenCore and Clover that you prefer 🙂 )
I think we can have success also for you as we did in the past 😉
Crea un thread nell'area internazionale di macos86.it e pubblica il tuo EFi funzionante (OpenCore e Clover che preferisci 🙂 )
Penso che possiamo avere successo anche per te come abbiamo fatto in passato 😉
Qualcuno ha visto un aumento di temperature sotto Ventura? Oggi pomeriggio ho visto 70°... con bigsur non ci sono mai arrivato...raffreddamento a liquido che fa più schifo di uno ad aria, e dovrei cambiare la pasta...
Anche il mio portatile con Ventura Beta2 appena avviato la CPU va al 40, 50 % con temperature 60 °70°  poi la CPU scende a 2 ,3  %  e la temperatura si stabilizza a 50, 55 °
inoltre ho ventura su HD esterno quindi non so se influisce sulla temperatura ....
13 minuti fa, fabiosun ha scritto:
@Gengik84ma vale solo scrivere beta3?
rosik rosik! 🙂
😂 Avevo sbagliato a caricare l immaggine ...
stavo x postare  questa ....gia' e' successo nuovamente anche a me .. risolto con la procedura ormai certificata : pulizia + riavvio
Scusate l OT
  • Haha 1
Anche a me... Boot loop selezionando macOS installer, dopo un reset ho selezionato invece il disco Ventura... sta procedendo...
Però è divertente dai :default_hysterical: ad ogni rilascio c è una novità
Credo di no ha terminato... Ma mi ritrovo la versione precedente  😲
... Adesso da aggiornamento software ha trovato altro, xcode credo... Lo lascio finire vediamo un po'
Mi sa che si è riscaricato l aggiornamento 1,5gb + 700mb xcode.. Riavviato, bootloop da macOS installer... Lol
Edit : Ho lanciato invece il disco, come prima... sembra andare adesso... Vediamo una volta terminato se aggiorna 🤞
