Asus TRX50 Pro Sage WIFI OSX Installation
Jerry-ag
  On 4/6/2024 at 9:03 PM, Lorys89 said:
Is the block always the same? Or is it different?
Expand
Good morning all @Lorys89 @fabiosun@backinblackx86,
Yes, the block remains consistent despite my attempts to install macOS using three different USB drives. Even when I attempted to use the EFI from my Dell workstation, the installation of macOS was still blocked. That is very weird. I have no idea and what's wrong with this Asus motherboard.
@Jerry-agi do not think you have problem with your bios
it is hard to debug your problem because system hangs in initial early stage
i have tested different things in my tries with you
MMIO, and also a solution which bypass MMIO configuration, your system hangs in the same way with all tries done
I would double check all your bios option (serial port must be always disabled)
Sage board are great but as in the past with ASUS X299 Sage..they are a bit more complex to hack
Expand
Hello @fabiosun,
Thank you for your suggestion. Yes, I have checked very carefully with the BIOS (serial port is always disabled). I tried to use another EFI folder (successfully installed on a Dell workstation and AMD SER5), but it seems to be blocked from booting to install without any reason. Please let me know if you have any new ideas to fix this issue. Thank you!
  On 4/7/2024 at 10:18 AM, Jerry-ag said:
Hello @fabiosun,
Expand
please test this
EFI.zipFetching info...
  • Cross Finger 1
  On 4/7/2024 at 11:11 AM, Lorys89 said:
please test this
Expand
Hello @Lorys89,
Thank you for your EFI file, but it is still stuck as before. I found that the secure boot mode only has two options: Standard and Custom (tried disabling both of them), and there is no option to disable secure boot mode like on another motherboard. Do you think this is the main issue? If yes, how could I define a custom user secure boot.
Expand
"Custom" is your key to disabling Secure Boot.
PS. In my experience with Xeons, serial ports are no issue at all. macOS is happy to boot with them, and to display "Serial" among networking possibilities. (I haven't dug up my 33.6k modem to check whether they actually work.)
  • Haha 1
  On 4/8/2024 at 4:48 AM, fabiosun said:
@Jerry-agi would like to try a different thing..if you agree
it is a simple EFI done for clover with your core count and mmio parameter
let see if the hang is the same
Expand
Thank you @fabiosun,
It is my pleasure to try out this new EFI with Clover. I hope it works; I will let you know the results when I come back home to test it.
