T-RyZo 3950X MSI Unify Arez56 [HS - Mojave - Catalina] + BigSur
dopo avere aggiornato la partizione catalina beta test con 10.15.4 prima beta, ho aggiornato anche la "stable" e mi sono dedicato a un po' di giocoleria.... 🤩
giusto per far venire delle paranoie a chi ha la lista PCI vuota.... 😈 come poi hanno i veri mac, vuota. 😉
547715805_Schermata2020-02-06alle18_33_03.thumb.png.6ca3f3477b02ce5d82e44a77e9efaaa7.png
  • whahahah 1
Hi @iCanaro,
Finally I build and install my ryzentosh 3950x + OC 5.5, Catalina 10.15.2 + Update to 10.15.3. It works very good 🙂
I have only one problem with virtualization(for docker) and it's because macOS does not support AMD-virtualization.
I enabled SVM in BIOS and it works for VirtualBox and 64bit OS, without SVM it works only with 32bit OS.
As I see on some resources in 10.15.4 beta someone found specs about AMD APU/CPUs. It's a good news but I think it's to early to receive AMD virtualization support 🙂
Can you check on 10.15.4 if AMD virtualization(SVM enabled in BIOS) is supported "sysctl kern.hv_support"?
Thanks!
17 minuti fa, yurkins ha scritto:
Hi @iCanaro,
Thanks!
I really doubt Apple will give us AMD support anytime soon, but who knows? 😄
Let's hope Apple did see AMD's potential and eventually embrace the architecture 🤞
On 1/16/2020 at 9:16 AM, iCanaro said:
@yurkins BIOS setting https://www.macos86.it/topic/1948-ryzentosh-3950x-msi-unify-arez56-hs-mojave-catalina/?do=findComment&comment=49902
EFI OC https://www.macos86.it/applications/core/interface/file/attachment.php?id=11134 [pwd = ryzentosh]
high sierra, mojave and catalina were already installed on SSD (direct installation by other hack)
pwd = ryzentosh does not work.
ACPI_MSI_UNIFY_BIOS_A3.zip
491932179_Schermata2020-02-23alle23_15_28.thumb.png.693abc0fb7cb0b9961999942df879322.png
aggiornato il BIOS; come si poteva rinunciare all'optical device compatibility 🤥
BT Intel integrato ora funzionante
per i kext vedi qui
ATTENZIONE: disattivazione e riattivazione al momento non è il massimo della stabilità e funzionalità
1522840662_Schermata2020-02-23alle23_07_54.thumb.png.1c049d28c7c45b0db26ee7a4cd15b2bd.png
476190952_Schermata2020-02-23alle22_56_14.thumb.png.f3e1a59d5e7abca09ac0cd3559b05b14.png
con SMCAMDProcessor.kext ora nell'app HWMonitorSMC2 è possibile avere la temperatura della CPU
1650284184_Schermata2020-02-23alle23_10_35.thumb.png.e8b9b23e9b2eadbd8927a6bf3aa1018b.png
Con SMCSuperIO vengono rilevate le ventole
SMCAMDProcessore e SMCSuperIO sono plugin di VirtualSMC il quale è un plugin di LILU
(e venne il gatto che si mangiò il topo etc.. etc.. etc...)
App Sensei
1348997728_Schermata2020-02-23alle23_51_36.png.9d822a01b5b53386178929305044fdac.png951248059_Schermata2020-02-23alle23_51_13.png.d851bfefc07ff25431e47d3543f1ca1f.png
App MenuBar Stats
in Arrivo nuovo case
http://metallicgear.com/products/Neo-Air
  • whahahah 1
mmm non lo carica
 prova così
copialo sul desktop e poi scrivi sul terminale
cd ~/Desktop && sudo chown -R root:wheel AppleIntelWifiAdapterV2.kext/ && sudo kextload -v AppleIntelWifiAdapterV2.kext/
poi ricontrolla se viene caricato
visto che non è stato detto, non importa riavviare, questo è il risultato:
Last login: Mon Feb 24 18:36:15 on ttys000
utente@MacPro3950x ~ % cd ~/Desktop && sudo chown -R root:wheel AppleIntelWifiAdapterV2.kext/ && sudo kextload -v AppleIntelWifiAdapterV2.kext/
Password:
Requesting load of /Users/utente/Desktop/AppleIntelWifiAdapterV2.kext.
/Users/utente/Desktop/AppleIntelWifiAdapterV2.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
utente@MacPro3950x Desktop % kextstat | grep -v com.apple
Index Refs Address            Size       Wired      Name (Version) UUID <Linked Against>
   42    5 0xffffff7f85e5f000 0x29000    0x29000    as.vit9696.Lilu (1.4.2) 6066A51A-2933-32E1-A929-A7E79359A021 <8 6 5 3 2 1>
   43    0 0xffffff7f85ea1000 0x12e000   0x12e000   as.vit9696.AppleALC (1.4.7) 883A4154-453E-3671-906E-C2578AFC0493 <42 13 8 6 5 3 2 1>
   44    0 0xffffff7f86050000 0x6e000    0x6e000    as.vit9696.WhateverGreen (1.3.7) 1873FDF0-5351-3BD5-B007-FF8101653A26 <42 13 8 6 5 3 2 1>
   45    2 0xffffff7f85e88000 0x19000    0x19000    as.vit9696.VirtualSMC (1.1.1) 48CE6895-665D-3F24-B7BB-F62AB600C579 <42 12 8 6 5 3 2 1>
   46    0 0xffffff7f860c2000 0x6000     0x6000     wtf.spinach.SMCAMDProcessor (1.0.1d1) AB17DEB8-034B-3CC3-B406-17D13E0838D4 <45 42 13 8 6 5 3 2 1>
   64    0 0xffffff7f860d9000 0x10000    0x10000    ru.joedm.SMCSuperIO (1.1.1) 762D35F5-8B88-3A96-A53B-AACC69BC3C5B <45 42 12 8 6 5 3 2 1>
   69    0 0xffffff7f85fd8000 0x64000    0x64000    com.insanelymac.RealtekRTL8111 (2.3.0d7) B7AD4389-A98A-3626-B575-765B605CEB91 <18 13 6 5 3 1>
   86    0 0xffffff7f860ec000 0xd21000   0xd21000   com.zxystd.IntelBluetoothFirmware (1.0.2) AC350FBA-0A28-301D-A5DB-2C2BA350A6C0 <85 27 12 8 6 5 3 1>
  135    0 0xffffff7f81240000 0x42000    0x42000    com.paragon-software.filesystems.ntfs (100.5.15) 2C6A4B7D-E7B3-3C8C-AA4B-46B7754E2C8C <8 6 5 1>
posso anche provarlo...
5 minuti
  • iCanaro changed the title to T-RyZo 3950X MSI Unify Arez56 [HS - Mojave - Catalina] + BigSur
