Asus TRX50 Pro Sage WIFI OSX Installation
Jerry-ag
14 minutes ago, Jerry-ag said:
No, an NVME drive includes the macOS Sonoma icon, which was installed from my Dell workstation. However, I plan to format and reinstall a new one on this PC (AMD cpu). Sorry, I forgot to mention that to you.
config.plist.zip
try to overwrite this in my previous efi
post boot menu screenshot
i see 14.4.1 recovery...so Sonoma is full installed in your disk?
isnt it only an icon?
have you tried to boot ftom there?
your system does not start early steps and it is very weird
Just now, fabiosun said:
Thank you for your efforts to help me. I will try it and let you know the result. Sonoma is fully installed on the NVME (it was installed from a Dell workstation). I tried to boot from that disk, but it is stuck at the same point.
@Jerry-ag
I created a thread for your motherboard , i have also moved there our unsuccesful tries (for now i hope)
with latest two config.plist?
12 hours ago, fabiosun said:
@Jerry-ag
Yes, both of the latest config.plist files had the same issue before. I tried changing some parameters, but it still won't boot. Perhaps this motherboard is not compatible.
@backinblackx86asus sage is a brand of the best motherboard available on consumer market
i have add a x299 sage and it was a beast of power
user has to disable only serial port
and maybe this will solve his initial hang
1 hour ago, fabiosun said:
Serial port…..nooooooooioooiki🥹🥹🥹
Try without it
and also disable parallel port if you have
Yes, the serial port has been disabled, but still no luck. I do not know what can I do next.
19 minuti fa, Jerry-ag ha scritto:
Thank you @Lorys89, I will try your new EFI folders and update you on the results shortly. Have a great weekend!
EFI.zip please use this to boot installed macos version and send log
