i5 9400f 32gb ram corsair gtx1060 msi b360 high sierra -> BigSur
peppepinta
ecco qua, cosi e'l'ultima modifica che ho fatto, copiato rootpci2
config.plist.zip
ma poi perche' mi crea log di continuo? sia su pendrive che su ssd,. ditanto in tanto li elimino io
con questo config qui nello screen invece parte però da sempre 7mb e va lento
Edited by peppepinta
non va con nessuno dei due
00:000 00:000 AAPL: #[EB|LOG:INIT] 2021-01-29T11:35:39
00:006 00:006 AAPL: #[EB|VERSION] <"boot.efi 495.60.1~4 (Official), built 2020-11-23T06:24:48-0800">
00:012 00:005 AAPL: #[EB|BUILD] <"BUILD-INFO[296]:{"DisplayName":"boot.efi","DisplayVersion":"495.60.1~4","RecordUuid":"03CF57CA-3D51-4B97-BB17-0A939346620A","BuildTime":"2020-11-23T06:24:48-0800","ProjectName":"efiboot","ProductName":"boot.efi","SourceVersion":"495.60.1","BuildVersion":"4","BuildConfiguration":"Release","BuildType":"Official"}">
00:017 00:005 AAPL: #[EB|CFG:DEV] r2 0x0 0x0
00:023 00:005 AAPL: #[EB|H:IS] 0
00:029 00:005 AAPL: #[EB|WL:MODE] 0
00:034 00:005 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
00:040 00:005 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
00:046 00:005 AAPL: #[EB|CFG:ARG] console       0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
00:051 00:005 AAPL: #[EB|CFG:ARG] serial        0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default
00:057 00:006 AAPL: #[EB|CFG:ARG] embed-log-dt  0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default
00:063 00:005 AAPL: #[EB|CFG:ARG] timestamps    0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
00:069 00:005 AAPL: #[EB|CFG:ARG] log-level     0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
00:074 00:005 AAPL: #[EB|CFG:ARG] breakpoint    0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
00:080 00:005 AAPL: #[EB|CFG:ARG] kc-read-size  0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
00:086 00:005 AAPL: #[EB|H:IS] 0
00:092 00:006 AAPL: #[EB|WL] 0 0 0x01 0x01   0 0x00
00:097 00:005 AAPL: #[EB|BRD:NV] Mac-63001698E7A34814
00:103 00:005 AAPL: #[EB|WL] 0 0 0x01 0x01   2 0x00
00:109 00:005 AAPL: #[EB.BST.IDT|+]
00:117 00:007 AAPL: #[EB.BST.IDT|-]
00:122 00:005 AAPL: #[EB|WL] 0 0 0x01 0x01   3 0x00
00:128 00:005 AAPL: #[EB|WL] 0 0 0x01 0x01   4 0x00
00:134 00:005 AAPL: #[EB|BRD:NV] Mac-63001698E7A34814
00:139 00:005 AAPL: #[EB|WL] 0 0 0x01 0x01   5 0x00
00:145 00:005 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
00:151 00:005 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:156 00:005 AAPL: #[EB|WL] 0 0 0x01 0x01  23 0x0E
00:162 00:005 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:168 00:006 AAPL: #[EB|WL] 0 0 0x01 0x01  24 0x0E
00:174 00:005 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:180 00:005 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:185 00:005 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:191 00:005 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:197 00:005 AAPL: #[EB|H:NOT]
00:203 00:005 AAPL: #[EB|SB:P] 0x1
00:208 00:005 AAPL: #[EB.B.MN|BM:+SB]
00:214 00:005 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(17|0)/SATA(1,FFFF)/HD(Part2,Sig857F8A9C-92F5-49A2-A9E6-85D03CE75423)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842)
00:220 00:005 AAPL: #[EB|LIMG:FP] \A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E\System\Library\CoreServices\boot.efi
00:226 00:005 AAPL: #[EB|LIMG:OPT]
00:231 00:005 AAPL: #[EB.OPT.LXF|F] <"\\A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E\\System\\Library\\CoreServices\\com.apple.Boot.plist">
00:237 00:005 AAPL: #[EB.LD.LF|IN] 0 1 <"\\A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
00:242 00:005 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E\\System\\Library\\CoreServices\\com.apple.Boot.plist">
00:248 00:005 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
00:254 00:005 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
00:259 00:005 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
00:266 00:006 AAPL: #[EB|KF] <"">
00:271 00:005 AAPL: #[EB|MBA:CL] <"">
00:278 00:006 AAPL: #[EB|MBA:NV] <"-v alcid=1 -wegnoegpu slide=242">
00:283 00:005 AAPL: #[EB|MBA:KF] <"">
00:289 00:005 AAPL: #[EB|MBA:OUT] <"-v alcid=1 -wegnoegpu slide=242 chunklist-security-epoch=0 -chunklist-no-rev2-dev">
00:295 00:005 AAPL: #[EB|LOG:VERBOSE] 2021-01-29T11:35:39
00:301 00:005 AAPL: #[EB.CSR.S|VAR] 0x00000040
00:306 00:005 AAPL: #[EB|OPT:BM] 0x280102
00:312 00:005 AAPL: #[EB.OPT.LXF|F] <"\\A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E\\System\\Library\\CoreServices\\PlatformSupport.plist">
00:317 00:005 AAPL: #[EB.LD.LF|IN] 0 1 <"\\A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
00:324 00:006 AAPL: #[EB|B:VAw]
00:330 00:005 AAPL: #[EB|P:CPR] N
00:336 00:005 AAPL: #[EB|P:MPI] N
00:341 00:005 AAPL: #[EB|P:BPI] N
00:347 00:005 AAPL: #[EB|KMR] 214937600
00:353 00:006 AAPL: #[EB.CS.CSKSD|+]
00:359 00:005 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
00:365 00:005 AAPL: #[EB|WL] 0 0 0x01 0x01   6 0x0E
00:370 00:005 AAPL: #[EB.CS.LFC|+]
00:376 00:005 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey"> <"0">
00:388 00:012 AAPL: #[EB.FS.AGSVH|PU] A4EBE0FE-2CE2-4ABD-8D78-9D70DB07600E
00:394 00:005 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
00:400 00:005 AAPL: #[EB.G.CS|-?] Ok(0)
00:406 00:005 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
00:414 00:008 AAPL: #[EB.B.SBS|SZ] 723512
00:425 00:011 AAPL: #[EB|B:SHA] <dffbec4c2621fe23a1e7179de04de783ab8b4279>
00:432 00:006 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:438 00:005 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
00:444 00:006 AAPL: #[EB.WL.PWLFRTC|NONE]
00:450 00:005 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
00:457 00:006 AAPL: #[EB.LD.LKC|D] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development">
00:463 00:006 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0">
00:470 00:006 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
00:476 00:006 AAPL: #[EB.LD.LKC|R.2] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc">
00:483 00:006 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0">
01:863 01:379 AAPL: #[EB|SB:P] 0x1
01:868 00:005 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
01:875 00:006 AAPL: #[EB|SB:MF] boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m
01:881 00:006 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m"> <"0">
02:238 00:356 AAPL: #[EB|SB:MKRN]
02:253 00:015 AAPL: #[EB.LD.LKFS|-?] Ok(0)
02:259 00:005 AAPL: #[EB.LD.LKC|-?] Ok(0)
02:266 00:007 AAPL: #[EB|FWFM] 0x00000000FFDFFF7F
02:272 00:005 AAPL: #[EB|FWFT] 0x00000000FD8FF576
02:278 00:005 AAPL: #[EB|BST:REV1]
02:284 00:005 AAPL: #[EB|CSR:OUT] 0x00000040
02:289 00:005 AAPL: #[EB.BST.FBS|+]
02:302 00:012 AAPL: #[EB.BST.FBS|ADSZ] 0
02:308 00:005 AAPL: #[EB.BST.FBS|KSSZ] 0
02:314 00:005 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
02:320 00:006 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
02:326 00:006 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m">
02:332 00:006 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
02:340 00:008 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m"> <"0">
02:347 00:006 AAPL: #[EB.BST.FBS|RHPSZ] 229
02:353 00:005 AAPL: #[EB.BST.FBS|RHMSZ] 3626
02:358 00:005 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0
02:365 00:006 AAPL: #[EB|LOG:DT] 2021-01-29T11:35:41
02:371 00:006 AAPL: #[EB|LOG:EXITBS:START] 2021-01-29T11:35:41
questo il log d'errore d'avvio dell'ultimo (2)
 sono un po' interdetto, pare funzionare più una mazza
qui viene spiegato la logica dei valori che si usano
https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md
nel caso tuo i5 9400 UHD630 coffe lake refresh
Intel UHD Graphics 610-655 (Coffee Lake and Comet Lake processors)
Supported since macOS 10.14 (UHD630 Comet Lake supported since macOS 10.15.4, recommended 10.15.5)
CFL/CML framebuffer list:
Framebuffer Type Connectors TOTAL STOLEN Memory
0x3EA50009 mobile 3 58 MB
0x3E920009 mobile 3 58 MB
0x3E9B0009 mobile 3 58 MB
0x3EA50000 mobile 3 58 MB
0x3E920000 mobile 3 58 MB
0x3E000000 mobile 3 58 MB
0x3E9B0000 mobile 3 58 MB
0x3EA50004 mobile 3 58 MB
0x3EA50005 mobile 3 58 MB
0x3EA60005 mobile 3 58 MB
0x3E9B0006 mobile 1 39 MB
0x3E9B0008 mobile 1 58 MB
0x3E9B0007 desktop 3 58 MB
0x3E920003 desktop 0 1 MB
0x3E910003 desktop 0 1 MB
0x3E980003 desktop 0 1 MB
0x9BC80003 desktop 0 1 MB
0x9BC50003 desktop 0 1 MB
0x9BC40003 desktop 0 1 MB
Spoiler: CFL/CML connectors
Native supported DevIDs:
  • CFL:
    • 0x3E9B
    • 0x3EA5
    • 0x3EA6
    • 0x3E92
    • 0x3E91
    • 0x3E98
  • CML:
    • 0x9BC8
    • 0x9BC5
    • 0x9BC4
Recommended framebuffers:
  • Desktop:
    • 0x3EA50000 (default)
    • 0x3E9B0007 (recommended)
  • Laptop:
    • 0x3EA50009 (default)
  • Empty framebuffer (CFL):
    • 0x3E910003 (default)
  • Empty framebuffer (CML):
    • 0x9BC80003 (default)
If you are using a 9th generation Coffee Lake Refresh processor, it is necessary to fake device-id 923E0000 for IGPU. Starting with macOS 10.14.4 the fake is not necessary.
cfl-r_igpu
non va nemmeno col framebuffer mobile
ma che valore dovrei aumentare per aumentare solo la memoria che gli arriva? potrei fare una prova con quello che parte che ha 4 valori all'interno di pciroot2 e poi aggiungo solo i mb che gli devono arrivare alla igpu. è una cosa fattibile?
  • Gengik84 changed the title to i5 9400f 32gb ram corsair gtx1060 msi b360 high sierra -> BigSur
come dicevo poc'anzi, sono interdetto, non mi è chiaro perché non si attivi la grafica
11 minuti fa, peppepinta ha scritto:
eh peccato non ho capito granche, ok devo sostituire i valori e provare, ma quali e come? in base a che cosa mi devo regolare, qua si che e complicato
in pratica vi è una tabella dove vedi rappresentati i vari framebuffer, quanta vram e quanti connettori uscita hanno.
Si deve usare ovviamente quelli con 3 connettori, poi il resto lo dovrebbe fare WEG
evidentemente in tutto questo delicato meccanismo vi è qualcosa che si inceppa, forse dovuto a come configurate uscite della tua mobo o un bug da qualche parte, o semplice incapacità nostra...
allora la scheda madre ha entrata displayport e dvi, e io ho collegato dvi, lo schermo è un samsun fullhd, doppia entrata( Dvi-vga) e infatti nella porta vga di questo monitor tramite adattatore ho attaccato anche windows dalla 1060.a me va bene tutto, le usb le legge, il bluetooth non so come mai ma a volte si e a volte no, ma sarà problema del config e delle 1000 modifiche fatte, cioè per sistemarlo del tutto mi mancherebbe sta igpu e il wifi in pratica, audio va pure.
signori cala il sipario!!!! funziona con il primo conf di gengik, parli poco ma quando parli...c'e' il silenzio XD Comunque legge 1536 mb di video e va bene ora. Grandissimo, una domanda adesso x il mio wifi intel chipset 6 che cosa mi consigliate di fare? ho altre molte domande Comunque, tipo ora posso copiare sto file nella pendrive o la lascio com'e la pendrive e via? io backup ne ho a bizzeffe sia di config che di efi. Comunque ora per aggiornamenti os originali?? grazie ragazzi a tutti, siete mitici! senza di voi, e'chiaro, non ce l'avrei fatto
ok l'ho messo anche nella pendrive , tutto bene, non trovo il thread del wifi intel ma Comunque ora cerco meglio, ma invece mi sapete dire qualche programma mac os free che mi permetta di leggere e soprattutto scrivere su ntfs? perche' avevo paragon ma non funge su big sur e sinceramente non lo compro
certo, ma vorrei fare un backup dell'ssd completo, e me lo salvo da qualche parte, in modo tale che eventualmente ci siano problemi io carico tramite un app x windows il backup e lui me lo ricrea per come era, non so se hai presente, esattamente come fa win32disk con raspberry, ho un immagine del mio cabinato quando ho avuto problemi ho caricato la iso e via, questo carbon cloner che dici tu lo fa questo? perche' poi se ho problemi mi resta solo windows. se quello va bene e hai pure un link ottimo senno' cerco con google
