kayaman80 Posted November 19, 2020 Share Posted November 19, 2020 Perfetto, grazie Link to comment Share on other sites More sharing options...
kayaman80 Posted November 19, 2020 Share Posted November 19, 2020 Allora, da situazione pulita credo di aver raggiunto già la finestra di installazione, ma schermo nero, ovviamente perchè avevo una nvidia e non ho i parametri per la Intel HD integrata...ho qualvhe errore in verbose nella fase iniziale, forse per qualcosa che ho sbagliato, ma se volete dargli un'occhiata... CLOVER.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 20, 2020 Administrators Share Posted November 20, 2020 Come ti colleghi al monitor? rimuovi nvda_drv=1 e patchVbios metti inject intel sul bios: dvmt 64mb, CSM disable, grafica primaria iGPU smbios MacBookPro16,2 è per portatili, metti iMac15.1 Link to comment Share on other sites More sharing options...
kayaman80 Posted November 20, 2020 Share Posted November 20, 2020 (edited) Perfetto, faccio subito, HDMI x il monitor Purtroppo ancora schermo nero...riposto clover CLOVER.zip Edited November 20, 2020 by kayaman80 Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted November 20, 2020 Supervisor. Share Posted November 20, 2020 Stai continuando a mettere MacBookPro anziché iMac nel SMBIOS. Link to comment Share on other sites More sharing options...
kayaman80 Posted November 20, 2020 Share Posted November 20, 2020 (edited) Cavolo, scusate...non ero andato abbastanza in basso nella lista degli SMBios Sotto il verbose con il blocco Edited November 20, 2020 by kayaman80 Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted November 20, 2020 Supervisor. Share Posted November 20, 2020 Se hai ancora schermo nero, prova a iniettare questo valore di ig-platform-id: 0x0D220003 1 Link to comment Share on other sites More sharing options...
kayaman80 Posted November 20, 2020 Share Posted November 20, 2020 Da cosa potrebbe dipendere il blocco? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 20, 2020 Administrators Share Posted November 20, 2020 la grafica Link to comment Share on other sites More sharing options...
kayaman80 Posted November 20, 2020 Share Posted November 20, 2020 Scusate, ma col nuovo CCG non vorrei sbagliare come ho già fatto in precedenza...in DFevice, dove dovrei inserire il valore IG-Platform-id? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 20, 2020 Administrators Share Posted November 20, 2020 parte grafica, ig-platform-id Link to comment Share on other sites More sharing options...
kayaman80 Posted November 20, 2020 Share Posted November 20, 2020 Tutto perfetto per ora, installazione in corso...attendo la fine e vediamo, grazie mille x ora 1 Link to comment Share on other sites More sharing options...
kayaman80 Posted November 20, 2020 Share Posted November 20, 2020 Sembrava filare tutto liscio, ma nella seconda parte dell'installazione, dopo il rpimo riavvio, ho questo errore che si ripete all'infinito Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 20, 2020 Administrators Share Posted November 20, 2020 prova a resettare la nvram e ripeti Link to comment Share on other sites More sharing options...
kayaman80 Posted November 21, 2020 Share Posted November 21, 2020 e come faccio in un Hackintosh? lo faccio sui miei mac originali, ma su hackintosh mai fatto Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 21, 2020 Administrators Share Posted November 21, 2020 F11 nella gui di clover 1 Link to comment Share on other sites More sharing options...
kayaman80 Posted November 21, 2020 Share Posted November 21, 2020 Niente, arriva a metà installazione e si riavvia, forse è per questo che non riesce a completare la seconda parte dell'installazione Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 21, 2020 Administrators Share Posted November 21, 2020 prova a vedere se i log riportano qualcosa Link to comment Share on other sites More sharing options...
kayaman80 Posted November 23, 2020 Share Posted November 23, 2020 (edited) Provo a vedere, dove lo trovo eventualmente? magari lo posto Bah, mi sa che si è corrotto l'installer, provo a rifarlo Edited November 23, 2020 by kayaman80 Link to comment Share on other sites More sharing options...
kayaman80 Posted November 23, 2020 Share Posted November 23, 2020 (edited) Stavo provando a ricreare la chiavetta dal mio mac originale, ma non mi permette di installare clover sulla destinazione, mi dice che non ho accesso di scrittura sul file system....che strano Risolto disabilitando SIP da recovery....tento una nuova installazione Niente da fare, anzi ho fatto decisamente passi indietro e non so neanche come, visto che non ho toccato nulla...comunque riposto la EFI, non ci sto capendo nulla al momento EFI.zip Edited November 23, 2020 by kayaman80 Link to comment Share on other sites More sharing options...
kayaman80 Posted November 23, 2020 Share Posted November 23, 2020 Salve, nessuna anima pia?? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted November 23, 2020 Administrators Share Posted November 23, 2020 ma stai usando le stessa efi di prima? se si, come arrivavi prima all'installer devi arrivarci anche ora Link to comment Share on other sites More sharing options...
kayaman80 Posted November 23, 2020 Share Posted November 23, 2020 Si certo, sto usando la stessa EFI, ma adesso invece che piantarsi e riavviarsi nella seconda parte, non mi arriva più neanche alla finestra di installazione Link to comment Share on other sites More sharing options...
kayaman80 Posted November 24, 2020 Share Posted November 24, 2020 Potreste dare x favore un'occhiata allla EFI x capirci qualcosa?? sono bloccato da giorni ormai Link to comment Share on other sites More sharing options...
kayaman80 Posted November 24, 2020 Share Posted November 24, 2020 Ragazzi, vi prego, ho bisogno di lavorare e non so come fare...non ho più una build funzionante e non so come uscire da sta situazione Link to comment Share on other sites More sharing options...
