backinblackx86
2 minutes ago, fabiosun said:
is it enabled in moherboard bios?
Yes it is enabled...also when I opened your last config.plist in OCAT, it reported
"Kernel->Patch[18]->Replace requires ReplaceMask to be active for corresponding bits!
Kernel->Patch[19]->Replace requires ReplaceMask to be active for corresponding bits!"
3 minutes ago, Lorys89 said:
please send ioreg log , thanks 🙂
https://github.com/vulgo/IORegistryExplorer
Using this tool?
Using this tool?
use this https://github.com/khronokernel/IORegistryClone/raw/master/ioreg-302.zip
yes it is a problem with that editor
but it should be fine
I do not have any TB4 devices to test with but I may go shopping for one. The AQ ethernet has still yet to populate even with the patches set to true and the quirk, I am attempting to boot now with the algrey patch OFF. I will then give USB4 enabled a try…stand by….these reboot take a very long time….2 minutes to see the boot picker
ok enable Shanee patch and leave disabled Algrey one
it is a pity TRX50 needs of one of it
After I re-enabled usb4 in the bios, I tested one of the USB-C ports with a flash drive and it did mount automatically. In the past I have only used USBMap in python. https://github.com/corpnewt/USBMap
I am open to all suggestions to improve the stability and performance of this system.
Issues currently:
10GbE is disconnected
- Have attempted the Casey set 2 patches and quirk.
Internal Sata identified as External
- In the past I have used Innie.kext (https://github.com/cdf/Innie)
Open Core Boot picker is very long, perhaps because of all the debug kexts and flags.
None the less, a major achievement. I will pull the 6800 from another system.
Have you tested both set of Casey’s patches?
I do not remember it was also useful to add DiasableIOmapprr quirk
about usb mapping, I use a SSDT done by Lorys
now is dinner time in Italy
i think in the next days we could help to refine your Efi and lorys could help you to do it at it’s best
1 ora fa, backinblackx86 ha scritto:
For reference here is my current EFI
test this efi and if boot send new ioreg log
in this efi I put ssdt for thunderbolt hotplug, this ssdt on x670 asus causes the bios to reset, if you feel up to it, try it and see if they have solved it on the new chipset.
Rainy night here in NY. Computer troubleshooting time well spent. I have only tried Set 2. I also set "DisableIOMapper." Stand by...
Yes, this EFI booted! However, I no longer have active USB ports.
@backinblackx86
here an EFI with other set of Casey's Aquantia patches
Also added a graphical boot menu and minor adjustment
If it starts well could be your base EFI for further tests (i have seen in V3 EFi you keep disabled some kexts..but you could also keep on AMDRyzenCPUPowerManagement if you like to see correct CPU name
backinblackx86_EFI_v4.zip
Backup yours and try this
If Aquantia doesent work the same you can delete many patches in config.plist kernel section
Others modifies done:
1)Uncheck Hide Ausiiary button because in this tests could be useful to see reset Nvram and toggleSip option
2) deleted some bootargs and kexts
3)added some uefi drivers (ToggleSip and ResetNvram)
4)added second set of patches for aquantia (some doubt they work..)
5) deleted unuseful and unused ssdt/DSDT
  • Recently Browsing   1 member
