backinblackx86
I do still have my 7960x trx50 AeroD machine but it has been repurposed as a GPU-rendering linux server. I had it running MacOSx86 Sonoma, it was stable, maintained weeks of uptime, and ran FCPX well. I did not use it as much as I planned to as my work took priority over creative interests. I do second the WRX90e, I built a 6x GPU setup around a 7985wx, a great platform. The AITop board is odd, as it accepts the wrx chip but uses quad memory, iirc. From the MacOS, I would stick with the AeroD.
Edited by backinblackx86
13 hours ago, etorix said:
And, if I'm not mistaken, no one has ever hacked EPYC (3000/5000/7000/8000/9000, not 4000, which I would expect to be a given).
On the Intel side of things, it seems that X299 "had quite a few people", but looks like a niche rather than a "popular" playground,  while C422 has a handful of faithful users (which is a pity, as I find these systems to generally be a breeze to hack…), C621 even less and we may be down to two or three users with C621A hacks; no one has yet cracked W790 or C741.
You commend some respect for willing to address such requirements on a Hackintosh rather than jumping to Linux like everybody else…
But I submit that for this amount of RAM you should look straight at WRX90 (Threadripper Pro 7000WX) and its 8 RAM channels (up to 2 TB) rather than at TRX50 and its mere 4 channels (1 TB). (If you're willing to go for older DDR4 systems, dual Xeon Scalable can take up to 4 TB RAM with 3DS LRDIMM or Optane DCPMM.)
Yeah that’s why I am looking at the Gigabyte’s TRX50 AI Top. It seems to support 2TB with threadripper pro CPUs.
regarding the Linux / macOS. By necessity I have an Asus WRX90 based system but it only has 768GB RAM running Linux (hopefully I can upgrade to 2TB when the 256GB DIMMs become available). Plus given the occasional (not so infrequent with PCIe 5.0 based SSDs) instability, I can’t use the hackintosh as my work machine anyway. Also Nvidia’s GPUs not being supported, I have to use Linux.
Regardless, I would like to boot macOS on the work machine baremetal just for fun, as I have Apple devices so you know the echo system along with the aesthetics…
There’s another thread with a person tried hackintoshing the Asus TRX50 board without success (last I checked). That’s another reason for looking at the AI Top..
or even non-Pro. But 2 DIMMs per channels, so reduced speed (and probably best to keep to the RAM QVL).
In the event that either of you had a free week-end to tinker while the WRX90 machine is at rest, you might give a try at hackintoshing it (with hyper-threading disabled for the 7985WX, and a compatible AMD GPU). It should not be that different from a TRX50.
I will be open to that when I begin to build the second WRX90E machine
@etorix I have been told that a virtual machine could be built on the WRX90 system. But I want to boot bare metal.
my own EFI gets stuck on the boot screen that immediately follows when a selection is made of the installation to boot in to. I tried with a few other EFIs, to the same effect.
15 minutes ago, etorix said:
@Jaidy Maybe open a dedicated thread and post your EFI and SysReport from the WRX90 system?
I unfortunately can neither make time nor afford for it to go down as it is my work machine and I wanna graduate yesterday (plus my adviser would start breathing down my neck too)
