Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 prova a copiare in questa EFI, BOOTX64.efi e CLOVERX64.efi della tua con cui avvii Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Provato ma niente Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 @Nikino sostituisci opss. aspè fartto... mi ero scordato una cosa EFI 6.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 altra efi EFI 7.zip Link to comment Share on other sites More sharing options...
Moderators netgear Posted September 14, 2020 Moderators Share Posted September 14, 2020 Io uso la video integrata: - EFI_GAG5_10.15_5122.ZIP Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 @Nikino estrai e posta le ACPI Link to comment Share on other sites More sharing options...
Nikino Posted September 15, 2020 Author Share Posted September 15, 2020 Quella di @netgear si blocca qua origin.zip Link to comment Share on other sites More sharing options...
Nikino Posted September 15, 2020 Author Share Posted September 15, 2020 Questa è quella di @iCanaro Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 15, 2020 Support Team Share Posted September 15, 2020 @Nikino rifletti prima di rispondere come mai nella EFI che hai postato in cui ti si avvia hai acpi e mappatura che non hanno niente a che fare con le acpi ora postate??? non mi dire che hai aggiornato il BIOS, perché non cambiano nome piuttosto hai preso EFI altrui e hai mantenuto una mappatura sulle USB non tua Link to comment Share on other sites More sharing options...
Nikino Posted September 15, 2020 Author Share Posted September 15, 2020 no, le acpi postate le ho estratte avviando con la efi di @netgear origin.zip queste sono della tua ultima efi, che si blocca anche quella. il malato è grave... 🙂 Link to comment Share on other sites More sharing options...
Nikino Posted September 15, 2020 Author Share Posted September 15, 2020 (edited) comunque si ho aggiornato il bios all F14 che è quella che usa @netgearlo avevo anche scritto in un post precedente Edited September 15, 2020 by Nikino Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 15, 2020 Support Team Share Posted September 15, 2020 40 minuti fa, Nikino ha scritto: il malato è grave... questo si era capito sei tu che non hai capito; se vedi tua EFI con cui avvii e che hai in questo thread postato, hai acpi e mappatura delle usb che non sono relative al tuo hardware... (le ultime postate vanno bene) ora, a meno che non ti ci lavori la notte il fantasma hackerino, sono tutte cappelle e imprecisioni che fai tu e che ti trascini dietro. ti posto questa ultima EFI, poi difficilmente ne arriveranno altre, che è sulla base di quella allegata da netgear ma con uno sguardo più preciso per le tue impostazioni. Per cui se ti avvia, bene, altrimenti dovrai lavorare sul BIOS o flasharne un'altro... 🤞 EFI-netgear_iCan.zip Link to comment Share on other sites More sharing options...
Nikino Posted September 15, 2020 Author Share Posted September 15, 2020 ti ringrazio tantissimo per il tempo che stai perdendo con me, lo capisco che sono per niente esperto e che ti faccio perdere i gangheri... ma fino adesso ho fatto tutto quello che mi hai chiesto, sostituendo le efi che mi hai inviato senza mai toccare nulla se non sotto tua indicazione. mi dispiace che non ne riesco a venire a capo e anche di romperti le scatole... speriamo che questa funziona. Comunque la mia efi che avvia regolarmente, sto scrivendo dal'hack, sarà incasinata, ma avvia. è un po vecchiotta lo so ma fatta sempre con il vostro aiuto, ma funziona tutto è solo lenta a spegnere. grazie ancora Link to comment Share on other sites More sharing options...
Nikino Posted September 15, 2020 Author Share Posted September 15, 2020 L’ultima è questa Link to comment Share on other sites More sharing options...
Moderators netgear Posted September 15, 2020 Moderators Share Posted September 15, 2020 Ma anche di BIOS c'è poco da settare, questo è il mio setting, alcune porte SATA sono disabilitate, la 1 e 2 sono attivate cmq. Io non ho NVME... Cmq la macchina si avvia con estrema facilità. - Setting_F14.zip Link to comment Share on other sites More sharing options...
Moderators netgear Posted September 15, 2020 Moderators Share Posted September 15, 2020 Ma sei sicuro di avviare qualcosa di Funzionante :)... Link to comment Share on other sites More sharing options...
Nikino Posted September 16, 2020 Author Share Posted September 16, 2020 (edited) Ciao, adesso sto scrivendo dall'hack avviato con la mia vecchia efi che avvia regolarmente con il bios F14 come il tuo e con il Setting consigliato nella guida dei bios. quando inserisco le efi che mi avete inviato voi, l'avvio si blocca con tutte. ogni volta prendo la efi e la copio al posto di quella che c'è senza toccare nulla . credo che sia la procedura corretta, oppure devo fare dei cambiamenti prima di copiarla? il tuo file con i settaggi è illeggibile. Edited September 16, 2020 by Nikino Link to comment Share on other sites More sharing options...
Moderators netgear Posted September 17, 2020 Moderators Share Posted September 17, 2020 Non saprei mi sembra un gran CAOS :), la EFI la metti e via, la configurazione del BIOS la carichi da BIOS e via... Link to comment Share on other sites More sharing options...
Nikino Posted January 28, 2021 Author Share Posted January 28, 2021 Ciao a tutti, finalmente trovato il momento per lavorare un po sul mio hack. Ho fatto una nuova EFI con Clover 5128 con i quirks e tutto funziona bene. Avvio e spegnimento veloci e senza blocchi.Mi rimane soltanto l'impossibilità di aggiornare oltre la 10.15.3 ne Catalina ne bigsur. Al riavvio scegliendo le icone di installazione sia normali che preboot rimane su schermo nero e devo riavviare. Poi sto tentando di mappare le usb, ho fatto la mappature e ho modificato il file SSDT, l'ho messo in acpi patched e nella tabella di drop seguendo le istruzioni della guidama con queste modifiche il pc non si avvia. allego ioreg SSDT e efi grazie per l'aiuto EFI .zip Vincenzo’s iMac.zip SSDT-5-A M I.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 30, 2021 Administrators Share Posted January 30, 2021 Ciao hai aggiunto la tabella in drop table e poi definito in sortedOrder: SSDT-Basic e dopo SSDT-5-AMI.aml? per droppare nel tuo caso devi usare per forza Lenght e devi prenderlo dalla tabella originale in caso allega le acpi pulite dopo averle estratte nuovamente Non devi avere Generate C & P states, il PM viene gestito da ssdt-basic Link to comment Share on other sites More sharing options...
Nikino Posted January 30, 2021 Author Share Posted January 30, 2021 Ciao, grazie per la risposta, si ho messo la tabella in drop table come length secondo la guida x299, ma in effetti in sorted order on ho messo ssdt-basic ma solo ssdt-5 aml con il nome length. Potrebbe questo causare il blocco all’avvio? Se ho capito bene, devo mettere ssdt-5-ami in acpi/patched, poi in drop table con denominazione length (per primo) assieme al tuo ssdt-basic. cosa ne pensi della efi, del ioreg e della mappatura? L’hack funziona molto bene, è stabile tranne il Bluetooth che non trovo neanche nelle impostazioni e l’audio delle cuffie, non segnalato. uso clover configurator ma non trovo dove inserire il layout dell’audio. non finirò mai di ringraziarvi per quello che fate. io non sono uno smanettone, ma grazie a voi sono riuscito a fare cose che non credevo alla mia portata. Molte cose non le capisco e impiego molto a metterle in pratica... Dove si trova generate g&p states? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 30, 2021 Administrators Share Posted January 30, 2021 dunque il drop table va a sinistra nell'omonima tabella mentre a destra, in SortedOrder devi elencare i due ssdt, prima Basic, secondo l'altro 10 minuti fa, Nikino ha scritto: Dove si trova generate g&p states? sempre nella parte ACPI del config Link to comment Share on other sites More sharing options...
Nikino Posted January 30, 2021 Author Share Posted January 30, 2021 ho rimesso come in foto eliminando Port limit e UsbInjectall, messo SSDTin patched avvio ok ma non funzionano le usb3. ho postato le ACPI appena estratte origin.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 30, 2021 Administrators Share Posted January 30, 2021 ok ti ci guardo Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted January 30, 2021 Administrators Share Posted January 30, 2021 Sostituisci, riavvia e posta ioreg Archivio.zip Link to comment Share on other sites More sharing options...
