34 minutes ago, Cosmin Batica said:
I'm not panic, but I want to know if I should try anymore or stop...
I would try on USB as I said
and if you have the same hang we have to understand why
as latest resources downgrade your bios to previous agesa
Just now, Cosmin Batica said:
I 've just trying to install to a SATA SSD drive, same result...
connected to a sata controller? if so no good (if the errors is the same) I do not think your EFI miss something to boot in Monterey or Ventura (if it is booting well in Big Sur)
have you an usb disk enclosure to try?
It was connected to internal SATA controller, indeed, same errors.
Yes, I'm trying right now with an USB 3 enclosure... feedback soon.
Edited by Cosmin Batica
  • Cross Finger 1
If it'll work, the question will be: then if I'll do a clone from external USB SSD to internal NVME, then Ventura will boot from that NVME? 😄
No it shouldn't (if it is not an EFI problem but deeper problem in ACPI)
27 minutes ago, fabiosun said:
this is not complete..but more useful could be error you see on video (is it always the same?)
Yes it's the same on video.
Too bad, because threadripper platform is really fast and stable, and I think I'm loosing my patience 😄
  • Sad 1
the only think I could think is to clone a working Monterey or Ventura from a real Mac or from a working Hackintosh and see if it works with your EFi (in my opinion that EFI is good)
I dont know how to improve it
Do you mean, clone an entire disk from a real Mac, and then put this EFI on the cloned SSD ?
@fabiosun I know 🙂
Now I have on an USB SSD drive an exact clone from Ventura - real Mac - MacBook Pro M1 Pro
I put on EFI partition of the USB drive the EFI folder, but when OC boots from USB drive it shows me the following options:
1. Windows (from another NVME)
2. EFI (from USB SSD)
3. Install Mac OS (from BigSurSSD)
4. BigSurSSD
If I choose 2. EFI doesn't work
How can I select to boot the existing installlation of Ventura from USB drive?
4. BigSurSSD
It seems you do not see cloned partition with Ventura
Scanpolicy is set to zero?
if you press space bar in boot menu stage do you see others options to boot?
try also to disable or enabled SecureBootModel in misc/boot config.plist section
Yes, I don't see cloned partition, even after SpaceBar press.
Scanpolicy is set to zero.
I try with SecoreBootModel - both Enabled and Disabled, the same result: the cloned partition doesn't show...
have you used carbon copy cloner latest 5xxx version? it seems 6 version have had some problem
