2 minutes ago, fabiosun said:
In boot menu do you see macOS installer icon?
you should boot from there a couple of times and then it trasforma it’s name as your disk was named
Yes, I choose MacOS Installer... but I already let it reboots at least 8 times.....
7 minutes ago, fabiosun said:
Could you take a video before it reboots?
https://wetransfer.com/downloads/b3c19ed35823825277c9af6e7b878f1e20221103141030/4ed4e73e7b89e2143d734c69291622cc20221103141043/05fc0d
Il 1/11/2022 at 15:03, Arrakis ha scritto:
@Lorys89
Nothing has changed except the numbering of the last two lines of the report.
  Mostra contenuto nascosto
[    2.209904]: igb: start()
[    2.210042]: igb: initEventSources() ===>
[    2.210133]: igb: MSI interrupt could not be enabled.
[    2.210135]: igb: Error initializing event sources.
[    2.210136]: igb: Failed to initEventSources()
[    2.211652]: igb: start()
[    2.211685]: igb: initEventSources() ===>
[    2.211996]: igb: MSI interrupt could not be enabled.
[    2.211998]: igb: Error initializing event sources.
[    2.211999]: igb: Failed to initEventSources()
[   15.147184]: igb: start()
[   15.180226]: igb: start()
Are you willing to try another kext igb for lan? @iGPU
this
AppleIGB.kext-max mod.zip
Edited by Lorys89
5 minutes ago, fabiosun said:
I hope you does not have the same problem which users loosing m2 slot if os greater than Big Sur
I have to check you video as soon I come back in front my pc
I reupload the video, 'cause previous has poor resolution....
Also, I attach a screen capture from the final of the video.....
https://wetransfer.com/downloads/c5456ed770750f198299abf1b46fe94720221103150452/b5cb2a70fae4e9d6f6fe655136e97db520221103150508/16c465
10 minutes ago, fabiosun said:
Sorry I have deleted your message
We should take away a bad sensation that in Monterey or greater also Asus trx40 loose its sata and m2 slot as other chipset and like some psi lower chipset board
Do you mean I can't even install Monterey or newer on my mobo??
1 minute ago, Cosmin Batica said:
For me it's unclear now why Big Sur works on M2 NVME and Monterey/Ventura doesn't....
and this happens to many users
start with a bios update for x570 MSI users and it propagates to other
you could be the first trx40 user who have this problem
I hope it is not so
I hope it is not so
BIOS update you say? Then maybe I should try with an older BIOS version?
on TRX40 it is an unexplored zone
I think never happened or maybe to another Asus user with a specific disk
but do not panic..because it is not sure
