3 hours ago, fabiosun said:
@Cosmin Batica
this was your previous working EFi updated with new patches and Ppencore stuff
try it and post photo of your hang and debug txt
it should also work with your Big Sur installation
your opencore debug txt is weird in one MMIO (it is correct in your config..but it gives skip 0 on debug txt
You do not have to change any bios parameter in your motherboard till a solution is found to boot again
I used a limited set of kext for now (no wifi/BT and ethernet) in Ventura and in Monterey ethernet could be a pain for many trx40 users
have you added NVME disk in your previous working rig?
I correct the MMIO values. Debug and photo attached. Thanks.
My previous rig (Big Sur) doesn't have NVMEfix.kext...
opencore-2022-11-03-095639.txt.zip
@Cosmin Batica
22:878 00:019 OCABC: MMIO devirt 0xCB100000 (0x81 pages, 0x8000000000000001) skip 0
22:899 00:020 OCABC: MMIO devirt 0xD7180000 (0x81 pages, 0x8000000000000001) skip 0
22:983 00:084 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 1
23:010 00:026 OCABC: MMIO devirt 0xE3300000 (0x100 pages, 0x8000000000000001) skip 0
23:037 00:026 OCABC: MMIO devirt 0xEF100000 (0x181 pages, 0x8000000000000001) skip 1
23:063 00:026 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 1
23:097 00:034 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 1
23:123 00:026 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 1
23:149 00:026 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 1
23:175 00:026 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 1
23:202 00:027 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 1
23:233 00:031 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 1
23:259 00:025 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 1
23:283 00:024 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0
23:309 00:026 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 1
23:340 00:030 OCABC: MMIO devirt 0x1840000000 (0x10400 pages, 0x8000000000000001) skip 0
23:365 00:024 OCABC: MMIO devirt 0x5170000000 (0x10400 pages, 0x8000000000000001) skip 0
23:391 00:026 OCABC: MMIO devirt 0x8AA0000000 (0x10400 pages, 0x8000000000000001) skip 0
23:415 00:024 OCABC: MMIO devirt 0xC3D0000000 (0x10400 pages, 0x8000000000000001) skip 0
23:444 00:029 OCABC: MMIO devirt end, saved 1068040 KB
it seems worst than before
have you tried my archive.zip?
19:035 00:016 OCABC: MMIO devirt 0xCB100000 (0x81 pages, 0x8000000000000001) skip 0
19:053 00:017 OCABC: MMIO devirt 0xD7180000 (0x81 pages, 0x8000000000000001) skip 0
19:070 00:016 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 1
19:088 00:018 OCABC: MMIO devirt 0xE3300000 (0x100 pages, 0x8000000000000001) skip 0
19:110 00:022 OCABC: MMIO devirt 0xEF100000 (0x181 pages, 0x8000000000000001) skip 1
19:125 00:014 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 1
19:139 00:014 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 1
19:154 00:014 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 1
19:168 00:014 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 1
19:184 00:015 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 1
19:204 00:020 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 1
19:219 00:014 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 1
19:233 00:014 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 1
19:248 00:014 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0
19:263 00:015 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 1
19:331 00:067 OCABC: MMIO devirt 0x1840000000 (0x10400 pages, 0x8000000000000001) skip 0
19:350 00:019 OCABC: MMIO devirt 0x5170000000 (0x10400 pages, 0x8000000000000001) skip 0
19:367 00:016 OCABC: MMIO devirt 0x8AA0000000 (0x10400 pages, 0x8000000000000001) skip 0
19:383 00:016 OCABC: MMIO devirt 0xC3D0000000 (0x10400 pages, 0x8000000000000001) skip 0
you shouldn't change stuff in your Bios....
6 minutes ago, Cosmin Batica said:
here if you have used my archive , zip try in the boot menu to reset Nvram
and we have to understand why your MMIO change (if you do not touch bios or you do not add any M2 drive while we are trying things)
I always reset Nvram before trying with modified EFI...
My MMIO is changing indeed, and I don't know why, my BIOS is untouched (by me), and entire hardware configuration stays unchanged...
Are you sure you are booting always from the same EFI?
if conditions are as you say MMIO must not change
in your BIOS 4g and resize bar are on or OFF?
Uefi ON?
And so on...other parameters are as usual they must be?
Uefi ON?
4g and resize bar are both ON
UEFI is on... all other parameters are correct (from Dortania guide)
I  try to start from scratch with Dortania with OC 0.8.5 debug, and then put MMIO and ACPI files from working BigSur EFI...
Leave Dortania guide 🙂
So do you have now a working EFI in Big Sur?
I f so we have to modify it in a debug version and see if BigSur boots fine
then check MMIO and Update your (probably old kernel patches)
Yes, I have a working EFI for BigSur. Here it is - attached...removed big kexts for space reason, but all files showed in screenshot
And I suppose I must remove all kexts incompatible with Ventura...
BigSurStable_03nov2022 2.zip
Edited by Cosmin Batica
11 minutes ago, fabiosun said:
fix pat is not needed for you (for all trx40 users)
in this EFI you have 3 ethernet kext
could you try to boot with this config always in BigSur?
do you know which OpenCore version is in this EFI?
thank you
I successfully boot with your config, but ethernet doesnt' work
I don't remember what OC version is, sorry...
I have disabled all lan kext
in Monterey and Ventura, only one of these ethernet will work
RTL8125 ones
upload on mega or we transfer your fully and working and updated EFI (completed of all kexts)
then I will try to see how to have it working in Ventura
but no i211At ethernet works in Monterey or Ventura
RTL8125 ones
Here it is the fully updated and working EFI, now ethernet works (realtek).
Thanks
https://we.tl/t-IF0VpqfJ8p
https://mega.nz/file/gDdVFYYS#90FU6tIrIGqMvsy7BHmzMsxujNngiKaBRfbkxlhMrC0
try this before in big sur and post debug txt
it should also work in Ventura!
It boots in BigSur, attached is debug file
opencore-2022-11-03-120508.txt.zip
Should I try to update to Ventura, or install from external USB (with erase the BigSur disk, and so on) ?
18:467 00:016 OCABC: MMIO devirt 0xCB100000 (0x81 pages, 0x8000000000000001) skip 0
18:481 00:014 OCABC: MMIO devirt 0xD7180000 (0x81 pages, 0x8000000000000001) skip 0
18:496 00:014 OCABC: MMIO devirt 0xE3180000 (0x81 pages, 0x8000000000000001) skip 1
18:510 00:014 OCABC: MMIO devirt 0xE3300000 (0x100 pages, 0x8000000000000001) skip 0
18:525 00:014 OCABC: MMIO devirt 0xEF100000 (0x181 pages, 0x8000000000000001) skip 1
18:542 00:017 OCABC: MMIO devirt 0xFEA00000 (0x100 pages, 0x8000000000000001) skip 1
18:557 00:014 OCABC: MMIO devirt 0xFEC00000 (0x1 pages, 0x8000000000000001) skip 1
18:572 00:014 OCABC: MMIO devirt 0xFEC10000 (0x1 pages, 0x8000000000000001) skip 1
18:587 00:015 OCABC: MMIO devirt 0xFED00000 (0x1 pages, 0x8000000000000001) skip 1
18:661 00:074 OCABC: MMIO devirt 0xFED40000 (0x5 pages, 0x8000000000000001) skip 1
18:732 00:070 OCABC: MMIO devirt 0xFED80000 (0x10 pages, 0x8000000000000001) skip 1
18:744 00:011 OCABC: MMIO devirt 0xFEDC2000 (0xE pages, 0x8000000000000001) skip 1
18:759 00:014 OCABC: MMIO devirt 0xFEDD4000 (0x2 pages, 0x8000000000000001) skip 1
18:774 00:015 OCABC: MMIO devirt 0xFEE00000 (0x100 pages, 0x8000000000000001) skip 0
18:793 00:018 OCABC: MMIO devirt 0xFF000000 (0x1000 pages, 0x8000000000000001) skip 1
18:808 00:015 OCABC: MMIO devirt 0x1840000000 (0x10400 pages, 0x8000000000000001) skip 0
18:823 00:014 OCABC: MMIO devirt 0x5170000000 (0x10400 pages, 0x8000000000000001) skip 0
18:838 00:015 OCABC: MMIO devirt 0x8AA0000000 (0x10400 pages, 0x8000000000000001) skip 0
18:852 00:014 OCABC: MMIO devirt 0xC3D0000000 (0x10400 pages, 0x8000000000000001) skip 0
before we have to solve this
it is not mandatory to have Ventura working well but it could help to have others features working well
are you able to correct by yourself this MMIO in bold character style?
I would try to update from Big Sur, if you can recover some errors could happen!
are you able to correct by yourself this mmil in bold character style?
Yes, I put disable when skip 0, see image2142403621_Screenshot2022-11-03at14_16_43.png.e06d06c59c698e33bdd46c743654bec7.png
no it is wrong @Cosmin Batica
you have to have them enabled and then check if MMI in debug are properly seen with skip 1
sorry I have no checked there 😉
put them on true and check again MMIO debug list
if they are always in skip 0 we have to calculate better their addresses
Ok, now they seems all in skip 1 in MMIO debug list...
opencore-2022-11-03-122326.txt.zip
15 minutes ago, fabiosun said:
ok now they are perfect
try to update your Venura without touching or adding kexts
if system hangs disconnect also your rtl 8125  ethernet cable
Ok, I just launch update from System Preferences -> Software Update, and I'l come back with feedback right after, thanks
  • Cross Finger 1
Doesn't work, during first installation stage from first reboot it reboots continuously.... the the attached debug file....
opencore-2022-11-03-125246.txt.zip
