Just updated to Ventura without a single issue, tried a fresh install which worked fine including wifi / BT / 2.5G network and just updated my main drive also without any issue.
Attached my EFI, @fabiosun feel free to add to OP. (boots Monterey and Ventura flawless only removed audio files from Resources to limit filesize)
(I did a small tweak to the SSDT-TRX40-USB-Port_R88.aml initial version by @Rocket88 and now have all my USB (including front USB-C) working fine and also sleep is working without an issue.)
Thanks all for sharing your results and tweaks with this community.
EFI OC 0.8.5 Rox67er.zip
  • +1 2
On 10/21/2022 at 6:33 PM, fabiosun said:
@trx40 and also all others  AMD users 🙂
What does it happen to your rig if you press for a click your case power button?
here happens this:
Did you need a tweak for this? Mine does not respond to the power button at all.
20 hours ago, shrisha said:
Guys, I can't boot into safe mode. Holding shift in OC canopy menu selecting disk, just showing apple URL and kick back to selecting menu. Is there anything  have to be adjusted in config.plist? Thank you.
Is anybody know what could be a cause of this?
Edited by shrisha
On 10/27/2022 at 1:05 PM, Lorys89 said:
For a complete log put this kext and this bootarg
https://github.com/acidanthera/DebugEnhancer
And the bootarg msgbuf=1048576
@Lorys89By adding the kext, AppleIGB.kext and DebugEnhancer.kext
This changes the behavior of my configuration,
Intel I210 modules are not even detected by Ventura anymore.
When I turn off it causes the hack to restart with the Kernel Panic logo...
I tried the command but it fails.
I entered the bootarg msgbuf=1048576
Here is the result in the terminal :
[    2.225085]: igb: start()
[    2.225165]: igb: initEventSources() ===>
[    2.225244]: igb: MSI interrupt could not be enabled.
[    2.225246]: igb: Error initializing event sources.
[    2.225247]: igb: Failed to initEventSources()
[    2.226842]: igb: start()
[    2.229221]: igb: initEventSources() ===>
[    2.229317]: igb: MSI interrupt could not be enabled.
[    2.229319]: igb: Error initializing event sources.
[    2.229321]: igb: Failed to initEventSources()
[    9.525729]: igb: start()
[    9.527501]: igb: start()
@Lorys89
Nothing has changed except the numbering of the last two lines of the report.
[    2.209904]: igb: start()
[    2.210042]: igb: initEventSources() ===>
[    2.210133]: igb: MSI interrupt could not be enabled.
[    2.210135]: igb: Error initializing event sources.
[    2.210136]: igb: Failed to initEventSources()
[    2.211652]: igb: start()
[    2.211685]: igb: initEventSources() ===>
[    2.211996]: igb: MSI interrupt could not be enabled.
[    2.211998]: igb: Error initializing event sources.
[    2.211999]: igb: Failed to initEventSources()
[   15.147184]: igb: start()
[   15.180226]: igb: start()
Edited by Arrakis
  Nascondi Contenuti
I sent the log to dev
Rad, been having a lot of issues going to Ventura with my ASRock TRX40 Creator machine.
Are you saying BT/WIFI (the Intel AX200 on the board) works flawlessly, without itlwm/airportitlwm and bluetooth kexts, or have you replaced the wifi/bt module?
I have replaced the onboard wifi / BT with an Apple compatible one. Details below:
Ah, gotcha. I did that and then swapped back, as the WiFi in that module is extremely slow compared to AX200 or AX210... Stable bluetooth was nice though...
1 hour ago, fabiosun said:
Hi @Cosmin Batica
could you post a photo before it reboots (adding -V in your bootarg)
have you tried to install with Ethernet cable disconnected?
This efi boots with previous Os in your pc?
Yes, I will post a photo right now. I tried with ethernet disconnected, the same result.
I doesn't try to boot actual Big Sur installation with this EFI... Update: it doesn't boot.
Edited by Cosmin Batica
@Cosmin Batica
this was your previous working EFi updated with new patches and Ppencore stuff
try it and post photo of your hang and debug txt
it should also work with your Big Sur installation
your opencore debug txt is weird in one MMIO (it is correct in your config..but it gives skip 0 on debug txt
You do not have to change any bios parameter in your motherboard till a solution is found to boot again
I used a limited set of kext for now (no wifi/BT and ethernet) in Ventura and in Monterey ethernet could be a pain for many trx40 users
Cosmin EFI Asus ROG Strix TRX40 E-Gamming.zip
have you added NVME disk in your previous working rig?
if my previous updated EFi produces this same error
try to add SSDT-EC in your ACPI folder and overwrite your config .plist with attached one
Archive.zip
