@Arrakisdownloaded your EFI, there is a minimal correction on it you can do
I think patches maintainer will update as soon they can also their GitHub:
algrey - _cpuid_set_info - GenuineIntel to AuthenticAMD - 10.13/10.14/10.15/11.0/12.0
21.99.99 should be 20.99.99 (maxKernel)
this has already been reported and will be corrected shortly
Edited by fabiosun
I changed the value of MaxKernel and already change the EFI on my post above.
@Arrakis
with your previous EFi if you like try this
obviously before with systems working with your EFI then if It works also for more complicated one 🙂
Backup your 😉
I noticed what you modified in the patch. How I could not understand ..... your explanation however precise.😒
I tested. with your modified config.plist and I can't boot Big Sur 4. The change stops after selecting the system.
Attached is the debug file.
 opencore-2021-07-22-171457.txt.zip
@Arrakis
if you have enough patience ..
try this:
with BS an Monterey if you have
Still not possible to boot on Big Sur 11.4 or 11.5.
When I try to install Monterey Beta 3 from a stick. I get an endless sequence (See Capture).
During my test day I already had this and I had disabled all kexts concerning Airport, bluetooth, wifi without result.
Tomorrow I will try to build a minimal working Efi for you
if you can post only config ok for you for both 11.4 and 11.5 os
thank you and sorry but we will win also in this hard task😂
This may be of interest to few, but I've updated this post on the TRX40 EFI structure, specifically to show how to completely remove a device through an SSDT file.
[The EFI itself is somewhat out-of-date due to the recent Patch incorporation, but the other sections are still applicable.]
While the earlier post did accurately show how to remove the USB power from the internal AX200 WiFi/BT device, the WiFi portion was still attached at BYS4. Through the use of an SSDT file, the whole device can be completely removed.  These results are shown in the Update, using HackCheck, at the bottom of the post.
10 hours ago, fabiosun said:
@Arrakis
when you have time this is a "clean" config.plist taken from your EFI
if system starts the same..I will proceed in a further step.
I have only disabled stuff
Starts well Big Sur 11.4 and 11.5 but for the installation of Monterey B3 it stops there.
 I call back on the off chance with all of the patches, I can install Monterey B1.
3 hours ago, fabiosun said:
step 2 @Arrakis
Previous system should work the same, test in Monterey to see if it passes previous hang you posted
and this should be last step...
added these two patches and disable a lot of them...
PR_Algrey Force set cpuid_cores_per_package-10.15.x -11.x
PR_Algrey Force set cpuid_cores_per_package-12.x
I use "18" that is your exdecimal cores count (24 cores)
let we see if it could work now
The config-arrakis-2 step starts Big Sur but I get the same error as the onfig-arrakis-1 step config for the Monterey installation.
The config-arrakis-3 step starts Big Sur but very unstable restarts or freezes.
On the other hand, starts the installer Monterey Beta 3 and begins the installation but freezes at various stages. (I tried several times without changing anything)
One other thing to consider from Intel experience, if weird things happen, your BIOS may be corrupted. The solution is to re-flash BIOS, then re-do you settings.
Next, I would literally remove as many things from your computer as possible. Only USB-2 KB/mouse, no other USB connections. Also, look at Energy Saver setting inside System Preferences. I would check Prevent your Mac... and uncheck the others.
Finally, boot into your most recently stable OS (Big Sur 11.4?), let it run for several minutes to see if re-boots or freezes. If okay, then proceed with booting into Monterey on another disk.
23 hours ago, fabiosun said:
Lastr test if you want for tonight @Arrakis
if weird frezee you have are not related to your thunderbolt card...there is a problem with topology patch i think (included in ProvvideCPuCountInfo)
The Arrakis config - step4 starts Big Sur but restarts but less often The Arrakis config - step3
Starts Monterey Beta 3 installer and begins installation but hangs ... with the message "An error occurred while preparing for installation….."
For Opencore users:
I have not tested this new and shining set of patches , I will do later
I see they left some not useful patch as the "leaf"one we demonstrated here we can skip (trx40, x570, x370 chipset)
Same typo as:
1877172035_Screenshot2021-07-27at6_03_12AM.thumb.png.8569583220fb319eed197db70f985abd.png
For Clover users:
for now I will stay with this set:
it misses in my case HighSierra boot in clover bootloader, all others newer system from Mojave are fine IT WORKS! 🙂
Edited by fabiosun
Tested in a rush Opencore new Patches!
Work fine
"algrey - _cpuid_set_generic_info - Disable check to allow leaf7 - 10.13/10.14/10.15/11.0/12.0"
as before is not needed to boot..
I have asked if there is some unknown reason to maintain it
As always thanks to the devs and patches maintainers!
