Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Vuoi che faccia la prova con il nuovo DSDT che hai fatto? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 si certo poi allega ioreg Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Eccolo, con il nuovo DSDT non vedo più la batteria MacBook Pro di Roberto.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 ah...pardon la batteria era ok prima? Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Tranquillo, sisi prima funzionava con l'altro DSDT 🙂 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 allora mantieni il primo il trackpad come va? Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Si, adesso si, ho aggiornato all'ultima versione di Catalina aggiornato il driver i2c adesso sembra andare bene sai? i Tasti FN + Luminosità + e - non mi vanno Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 prova aggiungi questo kext: https://github.com/hieplpvip/AsusSMC/releases/download/1.2.2/AsusSMC-1.2.2-RELEASE.zip EDIT: prima prova solo DSDT DSDT.aml.zip DSDT-2 con il kext sopra linkato DSDT.aml 2.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) Il primo DSDT è andato subito la luminosità con i tasti, ma l'icona della batteria è saltata 🙂 Edited July 21, 2020 by Roberto Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 mea culpa, devo aver modificato l'ultimo dsdt e non il primo con la batt funzionante riprova rinominalo tu a modo il dsdt DSDT 4.aml.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Perfetto, adesso funziona anche la batteria di nuovo :). Direi che ci siamo no? manca solo una Wifi compatibile, quale mi consigli? C'è una nativa? interna? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 allega ioreg, anche se dovrebbe essere tutto ok, ricontrollo il wifi se guardi nella sezione hardware c'è una lista per quelli compatibili ovviamente in caso meglio interno e broadcom Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Ecco l'ioreg :). Adesso controllo la sezione Wifi 🙂 MacBook Pro di Roberto.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 Ok ma il wifi è intel? in caso puoi provare dei kext, c'è il relativo topic fatto da @iCanaro 1 Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Si è intel, adesso funziona??? TOP Dove trovo il kext da provare? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 non sempre oppure non al 100% comunque si Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Si può provare 🙂 1 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 21, 2020 Support Team Share Posted July 21, 2020 https://www.macos86.it/topic/3093-intelwifi-for-macos-beta-test/ https://www.macos86.it/topic/2260-intelbluetoothfirmware/ Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 il Bluetooth sembra che a me vadi nitivamente, sembra funzionare Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 ci sono kext anche per quello il funzionamento nativo che menzioni, dipende dal firmware... molto probabilmente grazie a windows ma è molto probabile che smetta poi di funzionare dei BT intel questa è un funzionamento parziale accaduto da anni Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 i kext devo provarli uno ad uno? perché provandoli singolarmente non compare l'icona wifi sulla barra... devo fare qualcosa di particolare? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 21, 2020 Support Team Share Posted July 21, 2020 se non compare l'icona, oltre che abilitarne la visualizzazione, probabile che devi aggiungere anche l'injector che appunto serve a questo scopo PS: ops io mi son cofuso, mi riferisco al BT per il wi-fi scorri e leggi il thread che ti ho linkato, in fondo ho messo un'app oggi inserita da altro utente sul forum Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 allora forse non ho capito io.... Quale kext mi consigli di mettere in Other? Per il Wifi? adesso c'erco l'app che dici Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 l'app intendi Heliport? Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Ok, confermo che con il Kext AppleIntelWiFi.kext + itlwm.kext + Heliport (copiato nella cartella Applicazioni) il wifi funziona, si collega alle rete Si, diciamo che la velocità non è delle migliori, ma funziona 🙂 su 300mbps che mi fa sui windows, su osx ne 40mbps, poteva andare peggio dai 🙂 Link to comment Share on other sites More sharing options...
