T-RyZo 3950X MSI Unify Arez56 [HS - Mojave - Catalina] + BigSur
  • iCanaro changed the title to Build Ryzen 3950X work progression [HS - Mojave - Catalina] OK
  • iCanaro changed the title to Build Ryzen 3950X MSI Unify Vega56 [HS - Mojave - Catalina] OK
@fabiosun urca! sono rimasto sorpreso, su mojave STOP perfettamente funzionante! si spegne tutto poi per riattivarlo ci si riesce con il pulsante di accensione
dopo provo high sierra e catalina... ricapitolando:
✅High Sierra >> STOP ✌️👍
✅Mojave >> STOP ✌️👍
❌Catalina >> STOP 👎😮 solo schermo nero, che non si riattiva, devo resettare, al riavvio ho visto il primo KP con questo hack, forse dovuto ai kext sensor
KP catalina:
panic(cpu 2 caller 0xffffff8012a6520a): Kernel trap at 0xffffff7f95ce61d2, type 14=page fault, registers:
CR0: 0x0000000080010033, CR2: 0x00007fff8505f9b0, CR3: 0x0000000020cbc000, CR4: 0x00000000003406e0
RAX: 0x0000000000000000, RBX: 0xffffff83c4ec4010, RCX: 0x0000000000000000, RDX: 0x00007fff8505f9c0
RSP: 0xffffff83c89b36b0, RBP: 0xffffff83c89b36b0, RSI: 0x00007fff8505f9c0, RDI: 0xffffff83b371e010
R8:  0x0000000004000002, R9:  0xffffff83c49d7000, R10: 0x0000000000000100, R11: 0xffffff8051c01000
R12: 0x0000000000000002, R13: 0xffffff83c89b3710, R14: 0xffffff83b371e010, R15: 0xffffff83c89b37cc
RFL: 0x0000000000010206, RIP: 0xffffff7f95ce61d2, CS:  0x0000000000000008, SS:  0x0000000000000000
Fault CR2: 0x00007fff8505f9b0, Error code: 0x0000000000000000, Fault CPU: 0x2, PL: 0, VF: 1
Backtrace (CPU 2), Frame : Return Address
0xffffff83c89b3110 : 0xffffff801293bb1b
0xffffff83c89b3160 : 0xffffff8012a733e5
0xffffff83c89b31a0 : 0xffffff8012a64e5e
0xffffff83c89b31f0 : 0xffffff80128e2a40
0xffffff83c89b3210 : 0xffffff801293b207
0xffffff83c89b3310 : 0xffffff801293b5eb
0xffffff83c89b3360 : 0xffffff80130d24f9
0xffffff83c89b33d0 : 0xffffff8012a6520a
0xffffff83c89b3550 : 0xffffff8012a64f08
0xffffff83c89b35a0 : 0xffffff80128e2a40
0xffffff83c89b35c0 : 0xffffff7f95ce61d2
0xffffff83c89b36b0 : 0xffffff7f95cf17eb
0xffffff83c89b36d0 : 0xffffff7f95ce4d77
0xffffff83c89b36f0 : 0xffffff7f95ce4b01
0xffffff83c89b3750 : 0xffffff7f95ac28df
0xffffff83c89b38f0 : 0xffffff7f95ac08bc
0xffffff83c89b3930 : 0xffffff7f95abf3d6
0xffffff83c89b3960 : 0xffffff7f95ab93fb
0xffffff83c89b3990 : 0xffffff7f95ab908f
0xffffff83c89b3a00 : 0xffffff7f95acf2fb
0xffffff83c89b3ae0 : 0xffffff7f95acf066
0xffffff83c89b3b00 : 0xffffff7f94cf4af8
0xffffff83c89b3b80 : 0xffffff7f94d0adf9
0xffffff83c89b3bd0 : 0xffffff7f94cf499a
0xffffff83c89b3c20 : 0xffffff7f94c9c36d
0xffffff83c89b3c60 : 0xffffff7f94c99aa0
0xffffff83c89b3d00 : 0xffffff7f94bf7534
0xffffff83c89b3d80 : 0xffffff7f94c97be6
0xffffff83c89b3de0 : 0xffffff801301ae46
0xffffff83c89b3e40 : 0xffffff801301a9f1
0xffffff83c89b3ef0 : 0xffffff8013019d3e
0xffffff83c89b3f50 : 0xffffff801301c4dd
0xffffff83c89b3fa0 : 0xffffff80128e213e
         com.apple.iokit.IOAcceleratorFamily2(438.2.8)[9176E894-E24A-36BA-AFDA-0DB11F3F512A]@0xffffff7f94bbf000->0xffffff7f94c82fff
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[2FAEE793-59BC-3ADF-A5E2-3BC8760AFE0B]@0xffffff7f93fbe000
            dependency: com.apple.iokit.IOPCIFamily(2.9)[1286D5E5-A6A1-3C44-A244-04C068903DB2]@0xffffff7f9332f000
            dependency: com.apple.iokit.IOSurface(269.6)[640503DC-6033-3EF6-85F4-F48282EF48DD]@0xffffff7f94b8e000
            dependency: com.apple.iokit.IOGraphicsFamily(569.3)[7B5CA52B-0BD1-34AB-BFC9-7D5C3A0DBE7C]@0xffffff7f93b54000
            dependency: com.apple.iokit.IOReportFamily(47)[E3C37E96-3AFA-301F-B89C-719FB3D4DA53]@0xffffff7f9396f000
         com.apple.kext.AMDRadeonX5000(3.0.4)[87CDB366-A19F-3F74-B5DA-226A8DD578D2]@0xffffff7f94c97000->0xffffff7f94e9cfff
            dependency: com.apple.iokit.IOAcceleratorFamily2(438.2.8)[9176E894-E24A-36BA-AFDA-0DB11F3F512A]@0xffffff7f94bbf000
         com.apple.kext.AMDRadeonX5000HWLibs(1.0)[18A474BD-0435-3DFB-99B0-6702332B060B]@0xffffff7f95a3b000->0xffffff7f9822ffff
BSD process name corresponding to current thread: kernel_task
Boot args: npci=0x2000 -v
Mac OS version:
19C57
Kernel version:
Darwin Kernel Version 19.2.0: Sat Nov  9 03:47:04 PST 2019; root:xnu-6153.61.1~20/RELEASE_X86_64
Kernel UUID: C3E7E405-C692-356B-88D3-C30041FD1E72
Kernel slide:     0x0000000012600000
Kernel text base: 0xffffff8012800000
__HIB  text base: 0xffffff8012700000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: NO (0xe00002bc)
System uptime in nanoseconds: 5642491569
last loaded kext at 5547883574: >!AUpstreamUserClient    3.6.8 (addr 0xffffff7f955a1000, size 36864)
loaded kexts:
org.mozodojo.W836x    1.3.4
org.slice.sensor.AmdCPUMonitor    1.0.2
org.netkas.FakeSMC    3.5.3
as.vit9696.!AALC    1.4.5
as.vit9696.WhateverGreen    1.3.6
as.vit9696.Lilu    1.4.1
>!AMCCSControl    1.13
@kext.AMDFramebuffer    3.0.4
>!AHDAHardwareConfigDriver    283.15
>!AHDA    283.15
@kext.AMDRadeonServiceManager    3.0.4
@kext.AMDRadeonX5000    3.0.4
>!AGraphicsDevicePolicy    4.5.21
@AGDCPluginDisplayMetrics    4.5.21
>!AHV    1
|IOUserEthernet    1.0.1
|IO!BSerialManager    7.0.2f4
@kext.AMD10000!C    3.0.4
>pmtelemetry    1
@Dont_Steal_Mac_OS_X    7.0.0
>!AGFXHDA    100.1.422
>!A!IMCEReporter    115
>!AFIVRDriver    4.1.0
>!A!ISlowAdaptiveClocking    4.0.0
>ACPI_SMC_PlatformPlugin    1.0.0
@filesystems.apfs    1412.61.1
>!AFileSystemDriver    3.0.1
>!AVirtIO    1.0
@filesystems.hfs.kext    522.0.9
@!AFSCompression.!AFSCompressionTypeDataless    1.0.0d1
@BootCache    40
@!AFSCompression.!AFSCompressionTypeZlib    1.0.0
>!AAHCIPort    341.0.2
@private.KextAudit    1.0
>!AHPET    1.8
>!AACPIButtons    6.1
>!ARTC    2.0
>!ASMBIOS    2.1
>!AAPIC    1.7
$!AImage4    1
@nke.applicationfirewall    303
$TMSafetyNet    8
@!ASystemPolicy    2.0.0
>!A!ICPUPowerManagement    222.0.0
|EndpointSecurity    1
>!ASMBus!C    1.0.18d1
|IOSMBus!F    1.1
>DspFuncLib    283.15
@kext.OSvKernDSPLib    529
@kext.AMDRadeonX5000HWLibs    1.0
|IOAccelerator!F2    438.2.8
@kext.AMDRadeonX5000HWServices    3.0.4
>!AGraphicsControl    4.5.21
>!ASSE    1.0
>!AHDA!C    283.15
|IOHDA!F    283.15
@kext.AMDSupport    3.0.4
|IO!BHost!CUSBTransport    7.0.2f4
|IO!BHost!CTransport    7.0.2f4
|IO!B!F    7.0.2f4
|IO!BPacketLogger    7.0.2f4
>!ASMBusPCI    1.0.14d1
@!AGPUWrangler    4.5.21
@!AGraphicsDeviceControl    4.5.21
|IONDRVSupport    569.3
|IOGraphics!F    569.3
|IOSlowAdaptiveClocking!F    1.0.0
>IOPlatformPluginLegacy    1.0.0
>IOPlatformPlugin!F    6.0.0d8
>!AXsanScheme    3
|IOAHCIBlock!S    316.40.3
>usb.IOUSBHostHIDDevice    1.2
>usb.cdc    5.0.0
>usb.networking    5.0.0
>usb.!UHostCompositeDevice    1.2
>usb.!UHub    1.2
|IOAudio!F    300.2
@vecLib.kext    1.2.0
|IOSerial!F    11
|IOSurface    269.6
@filesystems.hfs.encodings.kext    1
>usb.!UHostPacketFilter    1.0
|IOUSB!F    900.4.2
>usb.!UXHCIPCI    1.2
>usb.!UXHCI    1.2
|IOAHCI!F    290.0.1
>!AEFINVRAM    2.1
>!AEFIRuntime    2.1
|IOHID!F    2.0.0
$quarantine    4
$sandbox    300.0
@kext.!AMatch    1.0.0d1
>DiskImages    493.0.0
>!AFDEKeyStore    28.30
>!AEffaceable!S    1.0
>!AKeyStore    2
>!UTDM    489.60.3
|IOSCSIBlockCommandsDevice    422.0.2
>!ACredentialManager    1.0
>KernelRelayHost    1
>!ASEPManager    1.0.1
>IOSlaveProcessor    1
|IOUSBMass!SDriver    157.40.7
|IOSCSIArchitectureModel!F    422.0.2
|IO!S!F    2.1
|IOUSBHost!F    1.2
>!UHostMergeProperties    1.2
>usb.!UCommon    1.0
>!ABusPower!C    1.0
|CoreAnalytics!F    1
>!AMobileFileIntegrity    1.0.5
@kext.CoreTrust    1
|IOTimeSync!F    800.14
|IONetworking!F    3.4
|IOReport!F    47
>!AACPIPlatform    6.1
>!ASMC    3.1.9
>watchdog    1
|IOPCI!F    2.9
|IOACPI!F    1.4
@kec.pthread    1
@kec.corecrypto    1.0
@kec.Libm    1
aggiunta scheda di rete RTL8111G PCIe
https://www.amazon.it/gp/product/B078GJ1594/
perfettamente riconosciuta e funzionante da ✅mojave e ✅catalina
❌high sierra non la vede
sia in mojave che catalina era en4 built-in
con fix en0 >> en0 built In ✅👍
271905612_Schermata2019-12-24alle10_19_23.thumb.png.6592ee9c091e91ab43d42626cdd76e0f.png
PS: usato script FIX en0 anche su high sierra e al riavvio la RTL8111G è stata caricata e ha iniziato a funzionare correttamente ✅ risolto 👍✌️
  • Like 3
🤨interferenze tra OS: stavo testando driver realtek per l'audio e ho riscontrato che con una release installata pure l'audio dai macOS installati, in tutti si era notevolmente abbassato.. a questa considerazione sono arrivato poi alla fine dei test.
Resettato NVRAM, cambiati serie kext poi ho pensato di rimuovere i driver realtek e di lasciare quelli di serie microsoft, tanto sono recentissimi... beh pure l'audio è ritornato a livelli normali nei macOS :classic_blink:✌️
  • iCanaro changed the title to T-RyZo 3950X MSI Unify Arez56 [HS - Mojave - Catalina] + BigSur
