Administrators Gengik84 Posted February 14, 2019 Administrators Share Posted February 14, 2019 Metti direttamente la efi funzionante Link to comment Share on other sites More sharing options...
maxxxy Posted February 14, 2019 Share Posted February 14, 2019 "Gengik84" post_id="26051" time="1550179957" user_id="2"> Metti direttamente la efi funzionante Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 14, 2019 Author Administrators Share Posted February 14, 2019 Non carica il kernel, hai messo kcsuffix=boot in Clover nelle custom boot flags? @maxxxy[/mention] Link to comment Share on other sites More sharing options...
maxxxy Posted February 14, 2019 Share Posted February 14, 2019 "Ciro82" post_id="26055" time="1550182150" user_id="48"> Non carica il kernel, hai messo kcsuffix=boot in Clover nelle custom boot flags? @maxxxy NO come consigliato ho copiato la cartella clover del vecchio hackintosh (mojave che funzionava) sovrascrivendo clover attuale Ha scritto dopo 2 minuti 41 secondi: ho controllato ....si cè Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 14, 2019 Author Administrators Share Posted February 14, 2019 Allora fai la prova a sostituire Kernel e Prelinkedkernel rinominando quelli .boot e rendendoli senza estensione (esempio quindi da kernel.boot a kernel) fai una copia di sicurezza dei file originali. Link to comment Share on other sites More sharing options...
Shaneee Posted February 14, 2019 Share Posted February 14, 2019 "maxxxy" post_id="26054" time="1550181118" user_id="993"> "Gengik84" post_id="26051" time="1550179957" user_id="2"> Metti direttamente la efi funzionante photo_2019-02-14_22-51-03.jpg photo_2019-02-14_22-51-07.jpg Questo è un problema USB. Prova a fare il boot con l'USB in una porta 2.0 e una volta che macOS inizia a caricare in verbose passa l'USB a una porta 3.0. Link to comment Share on other sites More sharing options...
maxxxy Posted February 14, 2019 Share Posted February 14, 2019 "Shaneee" post_id="26058" time="1550183272" user_id="1001"> "maxxxy" post_id="26054" time="1550181118" user_id="993"> "Gengik84" post_id="26051" time="1550179957" user_id="2"> Metti direttamente la efi funzionante photo_2019-02-14_22-51-03.jpg photo_2019-02-14_22-51-07.jpg Questo è un problema USB. Prova a fare il boot con l'USB in una porta 2.0 e una volta che macOS inizia a caricare in verbose passa l'USB a una porta 3.0. cioè mentre carica lo stacco e lo attacco... scusa ma se lo metto dentro al pc nella porta sata'?? Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 14, 2019 Author Administrators Share Posted February 14, 2019 "maxxxy" post_id="26059" time="1550183510" user_id="993"> scusa ma se lo metto dentro al pc nella porta sata'?? Si anche Link to comment Share on other sites More sharing options...
maxxxy Posted February 15, 2019 Share Posted February 15, 2019 "Shaneee" post_id="26058" time="1550183272" user_id="1001"> "maxxxy" post_id="26054" time="1550181118" user_id="993"> "Gengik84" post_id="26051" time="1550179957" user_id="2"> Metti direttamente la efi funzionante photo_2019-02-14_22-51-03.jpg photo_2019-02-14_22-51-07.jpg Questo è un problema USB. Prova a fare il boot con l'USB in una porta 2.0 e una volta che macOS inizia a caricare in verbose passa l'USB a una porta 3.0. @Shaneee[/mention] @Ciro82[/mention] messo nella porta sata interna ....un po meglio ....non va in panic...ma dopo un po di scritte si riavvia il pc Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 15, 2019 Administrators Share Posted February 15, 2019 allega l'attuale cartella clover Link to comment Share on other sites More sharing options...
maxxxy Posted February 15, 2019 Share Posted February 15, 2019 "Gengik84" post_id="26064" time="1550214068" user_id="2"> allega l'attuale cartella clover Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 15, 2019 Administrators Share Posted February 15, 2019 Hai i kext sono nella cartella 10.14 Spostali tutti nella cartella other Link to comment Share on other sites More sharing options...
maxxxy Posted February 15, 2019 Share Posted February 15, 2019 "Gengik84" post_id="26066" time="1550215081" user_id="2"> Hai i kext sono nella cartella 10.14 Spostali tutti nella cartella other fatto non è cambiato nulla Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 15, 2019 Author Administrators Share Posted February 15, 2019 Quindi facciamo ordine e torniamo alla situazione iniziale: -Rimetti Kernel e Prelinkedkernel originali al loro posto; -Ridai estensione .boot a quelli modificati; Mentre per il problema del riavvio sarebbe necessario tu riuscissi a vedere in che momento specifico accade. @maxxxy[/mention] aggiungi la scheda video nella tua firma Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 15, 2019 Administrators Share Posted February 15, 2019 @maxxxy[/mention] puoi dire esattamente quale kernel e nel caso prelinked hai messo? Link to comment Share on other sites More sharing options...
maxxxy Posted February 15, 2019 Share Posted February 15, 2019 allora kernel e prelinked ho messo quelli dello zip che mi avete postato voi qualche post indietro......... credo fossero per mojave...esistono differenti per highsierra ho fatto una registrazione dello schermo in moviola... questi sono gli ultimi fotogrammi prima del riavvio Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 15, 2019 Administrators Share Posted February 15, 2019 no.. non va bene quello adesso sei su 10.13.6 Ha scritto dopo 36 secondi: leggi, scarica e esegui con cura https://github.com/Shaneee92/AMD-High-Sierra-XNU/releases">https://github.com/Shaneee92/AMD-High-S ... U/releases">https://github.com/Shaneee92/AMD-High-Sierra-XNU/releases Link to comment Share on other sites More sharing options...
maxxxy Posted February 15, 2019 Share Posted February 15, 2019 @Shaneee[/mention] @Gengik84[/mention] allora seguendo le istruzioni .... lancio il primo sudo ma non rinomina il file in backup.... potrebbe essere perchè il mio sistema è in italiano...comunque l'ho fatto a mano.... secondo sudo mette errore kernel filename invalid....nel sudo il nome è kerncache.... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 15, 2019 Administrators Share Posted February 15, 2019 1 rinomini il kernel originale 2 aggiungi il kernel scaricato 3 comandi sul terminale riavvia Ha scritto dopo 28 secondi: ah dimenticavo, rimuovi la boot-arg dal config Ha scritto dopo 1 minuto : intendo questo kcsuffix=boot Link to comment Share on other sites More sharing options...
maxxxy Posted February 18, 2019 Share Posted February 18, 2019 MI SONO ARRESO Link to comment Share on other sites More sharing options...
dadal75 Posted February 18, 2019 Share Posted February 18, 2019 "maxxxy">MI SONO ARRESO NOOOOOOOOOOOO!!!!!!!!!! Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted February 18, 2019 Administrators Share Posted February 18, 2019 "maxxxy" post_id="26238" time="1550484328" user_id="993">MI SONO ARRESO Perchè? Link to comment Share on other sites More sharing options...
maxxxy Posted February 18, 2019 Share Posted February 18, 2019 "Gengik84" post_id="26241" time="1550487118" user_id="2"> "maxxxy" post_id="26238" time="1550484328" user_id="993">MI SONO ARRESO Perchè? perchè non riuscivo e devo continuare a chiedere e rompere le scatole qui sul forum è il primo hackintosh che mi "batte" anche se in effetti è il primo amd emoticon-occhi_51 emoticon-occhi_51 Link to comment Share on other sites More sharing options...
dadal75 Posted February 18, 2019 Share Posted February 18, 2019 "maxxxy">"Gengik84" post_id="26241" time="1550487118" user_id="2"> "maxxxy" post_id="26238" time="1550484328" user_id="993">MI SONO ARRESO Perchè? perchè non riuscivo e devo continuare a chiedere e rompere le scatole qui sul forum è il primo hackintosh che mi "batte" anche se in effetti è il primo amd emoticon-occhi_51 emoticon-occhi_51 Ma un hack funzionante lo hai quindi non desistere! Ricomincia da capo e con calma! Repetita iuvant [emoji12] Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted February 18, 2019 Support Team Share Posted February 18, 2019 prenditi una pausa e rileggi un po' che occorre fare, rinominare cosa e come questi kernel, che patch etc... che mi sono perso pure io :D vai avanti che ti seguiro' appena arrivano dei ZEN2 ryzen3000 e servono cavie _whaa emoticon_urca emoticon_panic emoticon_ahahaha Link to comment Share on other sites More sharing options...
