GA-Z390 M Gaming , CPU 8700 , SSD M2 970 Pro
Baio77
Eccomi ragazzi ce l'ho fatta ...
Caratteristiche HW :
SK Madre GA-Z390 M Gaming Bios F7 https://www.gigabyte.com/Motherboard/Z390-M-GAMING-rev-10#kf">https://www.gigabyte.com/Motherboard/Z3 ... -rev-10#kf">https://www.gigabyte.com/Motherboard/Z390-M-GAMING-rev-10#kf
CPU I7 8700 + Integrata UHD630 https://ark.intel.com/it/products/126686/Intel-Core-i7-8700-Processor-12M-Cache-up-to-4-60-GHz-">https://ark.intel.com/it/products/12668 ... -4-60-GHz-">https://ark.intel.com/it/products/126686/Intel-Core-i7-8700-Processor-12M-Cache-up-to-4-60-GHz-
RAM 32GB 3200 Mhz Corsair https://www.corsair.com/it/it/Memory-Size/vengeance-lpx-black/p/CMK16GX4M2B3200C16">https://www.corsair.com/it/it/Memory-Si ... M2B3200C16">https://www.corsair.com/it/it/Memory-Size/vengeance-lpx-black/p/CMK16GX4M2B3200C16
SSD 970 Pro 512 GB NVMe M2 Mojave 10.14.x\ Beta MacOS https://www.samsung.com/semiconductor/minisite/ssd/product/consumer/970pro/">https://www.samsung.com/semiconductor/m ... er/970pro/">https://www.samsung.com/semiconductor/minisite/ssd/product/consumer/970pro/
SSD 970 EVO PLUS 250 GB Win 10 https://www.samsung.com/semiconductor/minisite/ssd/product/consumer/970evoplus/">https://www.samsung.com/semiconductor/m ... 70evoplus/">https://www.samsung.com/semiconductor/minisite/ssd/product/consumer/970evoplus/
VGA RX560 OC 4GB https://www.asus.com/it/Graphics-Cards/ROG-STRIX-RX560-O4G-GAMING/specifications/">https://www.asus.com/it/Graphics-Cards/ ... fications/">https://www.asus.com/it/Graphics-Cards/ROG-STRIX-RX560-O4G-GAMING/specifications/ sostituita successivamente con RX 590 Nitro OC http://sapphirenitro.sapphiretech.com/en/590-8.html">http://sapphirenitro.sapphiretech.com/en/590-8.html
WI-FI + BT WiFi + Bluetooth:BCM94360CD (Fenvi FV-T919 / WTXUP BCM94360CD / Scheda per Mac + adattatore per PCIe x1):
Chipset:BCM4360 Vendor-id:14E4 Device-id:43A0 (WiFi abgn+ac 2.4/5 GHz + BT 4.0) Supporto:nativo
Posto dati che sono riuscito a recuperare , devo aggiornare il Bios ho la V F2 ed ho avuto rogne con le RAM quindi devo passare a V F5 dove sono stati risolti dei problemi con DDR4
LINK_TEXT>LINK_TEXT>
Pannello Mobo USB + Connettori Video Integrata
EDIT del 31\3\2019
Allego la cartella EFI con raccolte le impostazioni della Clover utilizzo + DriverUEFI in uso
Inserita Patch WEG in configplist per sfruttare le uscite video della GPU Integrata della Mobo
*nov*
EDIT del 14\09\2019
BIOS F7 istallato = NVRAM nativa con uso di Aptiomemoryfix sembra una delle poche Z390 dove funzioni in maniera nativa la NVRAM
Istallata scheda WI-FI + BT aggiornato SSDT USB - Clover bootloader 5082 - Kext aggiornate - Codifica HW attiva ........
*nov*
EDIT del 2\11\2019
Bios F8 istallato = tutto funziona come sopra Clover 5098 -Kext aggiornate
Ioreg WI-FI + BT .zip
Edited by Baio77
allora... non vorrei fare il gufo :D 2 cose:
ho già provato su un paio di hack diversi, ho riscaricato ioreg 2.1 da qui su macOS86 ma me lo da sempre corrotto
la seconda... @Baio77[/mention] era partito per aggiornare il BIOS, sarà mica venuto un temporale? emoticon_varie1 imbarazzati32
butta gli hack da uno a 4 :)
"iCanaro" post_id="22998" time="1547145730" user_id="57">
la seconda... @Baio77 era partito per aggiornare il BIOS, sarà mica venuto un temporale? emoticon_varie1 imbarazzati32
https://postimg.cc/vcTPwgHV">LINK_TEXT>
Ha scritto dopo 2 minuti 25 secondi:
o usa la versione 3.02 per aprirlo :P
OK Passato alla V F5 del Bios ...https://postimg.cc/5Q6kg6XL">LINK_TEXT>
L'ho vista davvero buia ....
Il problema con le Ram e l'istallazione su SSD M2 mi hanno ostacolato e NON poco ....
Se provo a lanciare l'istallazione da USB si blocca al Verbose sempre in posti diversi , ma deduco ho problemi di USB ........
Invece con le medesime impostazioni in Clover e vecchio SSD con OS del vecchio Z77 arrivo al Desktop in pochi secondi e va da dio ......
Apparte tutto , da GRAN smanettone , devo riuscire a istallare senza problemi , quindi devo trovare l'ostacolo e neutralizzarlo ....
NON ho nulla sul SSD in particolare , ho i dati mi servono su HD archivio da 3TB quindi , necessito di istallare OS nuovi sia Mac che Win .....
Sappiamo che patch Port limit NON funzionano più , in 10.14.2 e in verbose mi da info anche in merito a ciò ......
ioreg di veri mac non saprei dove pescarli
dal tuo hack_info vedo che stai usando fakesmc + relativi sensor, per me puoi cestinarli tutti e provare
virtualSMC, SMCprocessor, SuperIO
io li uso dall'hack più veccio al più recente e vanno bene
per HWMonitor l'ultima versione beta di vector sigma su IM va + che bene
Ha scritto dopo 6 minuti 24 secondi:
PS: puoi usare tranquillamente l'ultimo pacchetto di kext che ho uppato che vanno ottimamente
vedo che ci stà WEG, senza non va la RX560? se hai schermo nero prendi l'SSDT che fece gengik
E' probabile siano i sensor come ha detto iCanaro oppure potrebbero essere le ram
Lascia solo Fake o prova l'alternativa
Ha scritto dopo 4 minuti 50 secondi:
Cancella il contenuto di origin, estrai nuovamente ma aspetta 30 secondi prima di avviare
  • Supervisor.
Non fidarti troppo dell'ioreg dei 18,x. Hanno chipset Z170, tu hai Z390 e nel frattempo è cambiato molto, ad esempio PPMC che tu non hai.
Gigabyte era famoso per essere l'unico produttore con cui non era necessario modificare il DSDT, a quanto pare ora è peggiorata...
OK ,grazie delle info
@iCanaro[/mention] sto facendo prove , ho usato sia i Virtual che i Fake sensor , WEG è inserito come garanzia , diciamo sono impostazioni base da migliorare col tempo..........
@foskvs[/mention] In effetti pensandoci hai perfettamente ragione , diciamo che ho visto varie differenze , manca EC0 e queste periferiche NON caricano alcuna Kext di sistema tramite DCPIManager
https://postimg.cc/svZVNj84">LINK_TEXT>https://postimg.cc/VJQYQyPQ">LINK_TEXT>https://postimg.cc/sMY33n3B">LINK_TEXT>
"Gengik84" post_id="23030" time="1547194933" user_id="2">
Mica c'è sempre EC0.. E anche se ci fosse come altri.. Molto probabilmente il semplice rename non basterebbe..
Assai frequente su desktop emoticon_risata
Si Boss , lo scopo era usare un tuo SSDT , ma credo NON sia idoneo x la struttura delle mie ACPI .....
Editato mess precedente con Origin allegate
ma hai anche già installato windows? se si e hai gli stessi problemi che hai con macOS probabile sia la RAM o BIOS immaturo; se invece con windows va tutto bene, dovrà maturare kext e impostazioni dell'hack
"Baio77" post_id="23033" time="1547195354" user_id="55">
Ho detto una eresia??
Diciamo intuito informatico , mi ha fatto pensare ciò , comunque sono curioso di provarli nel caso a tempo debito ovvio default_wink_anim
Appena riesco a guardare le nuove acpi.. Ti faccio sapere anche per il discorso usb e mappatura
