Support Team Lorys89 Posted August 1 Support Team Share Posted August 1 test app : https://github.com/LorysMay/AppleMonitorCenter/releases/ for intel user, install this tool https://software.intel.com/file/843900/downloaduDdQ7iKU for amd user, use this kext AMDRyzenCPUPowerManagement.kext.zipSMCAMDProcessor.kext.zip 2 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 Intel Power Gadget is back ! 😆 Bella ... moderna 👏 Spoiler GPU : Intel KBL Unknown ? AppleMonitorCenter-Diagnostics-2026-08-01_1255.txt.zip Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 Ancora devo sistemare un po di letture di sensori e nome igpu corretto, ma pian piano li sistemo ma servono test poiché ho solo Mac veri silicon, e il ryzen. 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 Mi pare che avevi accennato di voler implementare dei Widget sul Desk ? 😝 ... Sarebbe ottimo , se nn comporta tanto lavoro Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 No i widget li lascio perdere perché non avrebbero i valori live in meno di 1 sec e non hanno senso Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 😆 avere piu' fan disponibili sulla barra , cosi d averle sott occhio senza aprire la dash ? Questo con Stats Comunque aggiornato tramite app, ma mi dava errore sull Helper delle ventole , quindi l ho scaricato Adesso mostra l igpu correttamente E' normale che frequenza e temp. non venga mostrata ... essendo integrata e' normale forse 🤔 Spoiler Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 Installa intel power gadget e riprova, forse oltre al kext EnergyDriver.kext ha bisogno del framework che installa l app Link to comment Share on other sites More sharing options...
morfy Posted August 1 Share Posted August 1 5 ore fa, Lorys89 ha scritto: test app : AppleMonitorCenter_V1.0.zip 4.66 MB · 1 download for intel user, use this kext EnergyDriver.kext.zip for amd user, use this kext AMDRyzenCPUPowerManagement.kext.zipSMCAMDProcessor.kext.zip Bellissima complimenti. Allego qualche screen. Mi vede in automatico cpu e gpu ma non riesce a leggere nessuna ventola. Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 Ora mando l ultima versione, quella attuale la eliminate e svuotare cestino, e mettere questa https://github.com/LorysMay/App-Center/raw/refs/heads/main/macOS/AppleMonitorCenter/AppleMonitorCenter_V1.0.zip 1 Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 35 minuti fa, Anto65 ha scritto: 😆 avere piu' fan disponibili sulla barra , cosi d averle sott occhio senza aprire la dash ? Questo con Stats Comunque aggiornato tramite app, ma mi dava errore sull Helper delle ventole , quindi l ho scaricato Adesso mostra l igpu correttamente E' normale che frequenza e temp. non venga mostrata ... essendo integrata e' normale forse 🤔 Mostra contenuto nascosto non c e bisogno di aprile da dash basta guardare qui ho evitato di metter troppa roba in barra in alto basta veder la temp cpu e la ventola che piu ti piace o la temp che preferisci ed appena ci clicci sopra hai una visione dettagliata delle cose più importanti Link to comment Share on other sites More sharing options...
morfy Posted August 1 Share Posted August 1 1 ora fa, Lorys89 ha scritto: Ora mando l ultima versione, quella attuale la eliminate e svuotare cestino, e mettere questa https://github.com/LorysMay/App-Center/raw/refs/heads/main/macOS/AppleMonitorCenter/AppleMonitorCenter_V1.0.zip Mi compare sto messaggio. Mi sono accorto che legge pure la temperatura del mio nvme interno 🙂 Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 clicca riprova e poi riavvia il pc ma smc superio kext lo hai? Link to comment Share on other sites More sharing options...
morfy Posted August 1 Share Posted August 1 16 minuti fa, Lorys89 ha scritto: clicca riprova e poi riavvia il pc ma smc superio kext lo hai? Ho questi Kext caricati su una chiavetta usb che mi fa da boot. Ho riavviato e il messaggio di errore è scomparso ma sempre non vede nessuna ventola. Se non ricordo male non vedevano nessuna ventola manco altri programmi...non so il perché. Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 il tuo chip della mobo non è stato mai implementato su scmsuperio.. 1 Link to comment Share on other sites More sharing options...
morfy Posted August 1 Share Posted August 1 2 minuti fa, Lorys89 ha scritto: il tuo chip della mobo non è stato mai implementato su scmsuperio.. Ecco svelato l'arcano 🙂 thx dell'info 🙂 Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 aggiornamento @Anto65 https://github.com/LorysMay/App-Center/raw/refs/heads/main/macOS/AppleMonitorCenter/AppleMonitorCenter_V1.0.zip Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 Fra un po' so a casa 🥵 ... Thx 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 ma so tutte vers. 1.0 😆 ( irrilevante ) Senza IPG Spoiler Con Spoiler AppleMonitorCenter-Diagnostics-2026-08-01_2116.txt.zip Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 disinstalla intel power gadget, li voglio sistemare senza usarlo 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 Gia' fatto 😀 AppleMonitorCenter-Diagnostics-2026-08-01_2221.txt.zip Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 Senza non va solo la temp igpu? Manda screen pagina sensori Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 ma anche con IPG nn andava la temp della igpu 🤷♂️ Spoiler Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 Nei test l ho fatta andare prima senza ipg, quindi cerco nei commit e ripristino la chiave che funzionava. 1 Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted August 1 Author Support Team Share Posted August 1 1 ora fa, Anto65 ha scritto: ma anche con IPG nn andava la temp della igpu 🤷♂️ Mostra contenuto nascosto prova la nuova versione https://github.com/LorysMay/App-Center/raw/refs/heads/main/macOS/AppleMonitorCenter/AppleMonitorCenter_V1.0.zip e fammi sapere 1 1 Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted August 1 Support Team Share Posted August 1 🤔 ho l impressione che legge la temp della CPU , sono uguali e' normale cosi ? Spoiler Link to comment Share on other sites More sharing options...
