backinblackx86
7 minutes ago, backinblackx86 said:
Okay, I will give it a try on a USB.
pay attention
SSDT TB4 is a bit problematic and read well the instructions and overall the disclaimer said @by Lorys 🙂
https://www.bhphotovideo.com/c/search?q=thunderbolt 4 dock
sure are a lot of options, expensive yet nothing too exciting, but I did spot one with a NVmE slot...this display LG does have USB-C input and a USB-A 3.1 ports along with a KVM switch...the motherboard features a "DP In" port that I suppose is for passing through the GPU output to the TB connection...I have never used it.
i would check your BIOS option for TB4 and then to see if it is possible to use thunderbolt like it happens on AM5
I mean i use it without HotPlug feature 🙂
i use this :
https://www.amazon.com/gp/product/B08LYQPRPJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
i bought only to do some test with my TB4
and now i use it for windows OS (windows 11 installed there)
i use a dock kensingon, is top.
1 minute ago, fabiosun said:
pay attention
I will also try and backup my BIOS settings. I concur that TB4 is experimental and could reset the entire system. I don't particularly have a need for the feature set of USB4. The LG monitor I have is connected to an X670E motherboard to the rear I/O USB-C port, without using any DP patch cable to the GPU, it displays the X11 Linux GUI from an Nvidia GPU, has been a bit inconsistent, however.
If I do get back into video editing, I could see TB being useful. I will look into the options available. A decade ago, I used TB2 with a SATA enclosure with an iMac/Mac Book Pro for Multicam 1080p editing, it was hot enough to fry an egg.
1 minute ago, Lorys89 said:
bios reset? or all ok 2 reboot?
ALL IS OKAY, the BIOS did NOT reset!
I moved the updated TB4 SSDTs to my SATA disks EFI...reboots much faster than the random 2.0 flash drive. System appears stable, I will try and source a TB device for further testing. Besides "Geekbench" are there other stress testing tools to use? In the past when I was not so familiar with the CLI, I would use Black Magic's Read/Write test, https://benchmark.unigine.com/heaven, Cinebench https://www.maxon.net/en/tech-info-cinebench, and Prime 95 https://www.mersenne.org/download/
VERY GOOD ❤️  🙂  IT IS A BIG HACK TRX50
  • Thanks 2
Just now, backinblackx86 said:
SMCAMDProcessor.kext
No need of this
only the other one if you use that app
You can monitor also in a better way using some kexts lorys89 has modified for amd motherboard🥹
