Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 I also believe that with the practical demonstration that TRX50 can work too.... you will make several people here spend a lot of money 🙂 1 Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 (edited) I have had this system assembled since December but it was on the back burner…Opencore does take a real long time to load the boot picker fyi. It is in an old case with a Volkswagon Type2 style theme, even the side panel has wheels. Previously this case was home to an Intel 3rd Gen…long due for an upgrade. Edited January 24, 2024 by backinblackx86 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 I appreciate in other forum your patience and calm to setup well this system Wonderful case I think that this PC deserves a good NVME disk for OSX 🙂 Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 Okay, this is it everybody… Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 7 minutes ago, backinblackx86 said: Opencore does take a real long time to load the boot picker fyi if it starts it will be possible to adjust all things Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 drum roll….Probably need to add RestrictEvents.kext and some other tweaks but we have reached the desktop! 2 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 Yes, i used few kexts to boot try audio from backplane and front i think your backplane audio should work without any kext Colors seems a bit weird Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 Colors are fine, it is my camera photographing the screen. Sound is working via the HDMi output to the display’s built in speakers. Analog audio output is working through the back I/O panel. Case’s audio out connected to the motherboard header is not working…could be the old wiring. Need to find a microphone to test input. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 Ok, restrictevents will help for CPU name as you know Do you see clicking in audio icon on the bar other devices? to grab a part of your screen you can click Option shift 4 and drag a box Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 I’lo need to log in via the Trx50 system, I have been using the mobile device. 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 Yes you have also USB audio as TRX40 and some AM5 motherboard. very good The good things you doesnt need of fix patch and this is good for GPU performance i hope when you are ready you will share some cpu Benchmark 🙂 very curious because i think you are the first one with thi platform to boot in OSX Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 Couldn't have done it without you fabiosun! I am interested in what you changed to make the system boot. I will add Restrict Events kext to correct the CPU name and the Memory error notification as I am familiar with it from my recent 5900x AM4 system. I do have an AMD 6800 XT that I can add to the system as this 560 was pulled from the previous 3rd Gen Intel system and of course, for performance sake, I will source a Western Digital NVMe. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 Important thing wrong was SSDT part I added one created by@Lorys89which has inside many things you need (CPU rename and other stuff) I think you can try also TB4 ports because they should be identical to mine Wireless could be problematic , but if it is an intel wifi you can try adding some kext test also front speaker port and headphone if you can post also an IOREG of your system to see better You can also adjust orange icon if you have 1 Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted January 24, 2024 Support Team Share Posted January 24, 2024 He mounts wifi 7 qualcom, it doesn't compatible 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 I also added a flag on a patch we use on AM5 platform Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 Yes this board is Qualcomm Wi-Fi 7, my PopOS linux does not detect it either. The board does have the 10GbE NIc, I believe similar to the ASUS X670E board, I am aware of CaseySJ patches for it. I will try enabling the Maple Ridge USB4 and see if it boots next. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 now i think you should backup this EFI/Config and try things you only can do 🙂 Maybe, something could be unflagged in your new TRX50 platform Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 https://github.com/CaseySJ/Aquantia-macOS-Patches Yes, I intend on backing this up. Can’t understand why loading the boot picker is so long, over 45 seconds Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 1 minute ago, backinblackx86 said: https://github.com/CaseySJ/Aquantia-macOS-Patches there is also a quirk you can try before I do not have modern experience on acquantia ethernet Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 config.plist.zip @backinblackx86here i added the quirk and the set 2 of the caseys's patches for aquantia if you like to try then we should do another tries disabling a patch 😉 let me now if you want to try Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 Okay, I backed up the EFI and swapped out the config.plst, going to reboot now. Stand By... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 from my latest config put yes on two acquantia patches if only the quirk is not enough then disable algrey patch (i hope it will work without it) Link to comment Share on other sites More sharing options...
backinblackx86 Posted January 24, 2024 Author Share Posted January 24, 2024 your plist boots but the Aq controller does not appear. I am going to attempt enabling the two patches now 1 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted January 24, 2024 Supervisor Share Posted January 24, 2024 is it enabled in moherboard bios? Link to comment Share on other sites More sharing options...
Support Team Lorys89 Posted January 24, 2024 Support Team Share Posted January 24, 2024 50 minuti fa, backinblackx86 ha scritto: drum roll….Probably need to add RestrictEvents.kext and some other tweaks but we have reached the desktop! please send ioreg log , thanks 🙂 Link to comment Share on other sites More sharing options...
