ASUS PRO WS W790 - ACE - Any help appreciated!
DSM2
Posted (edited)
Hello Guys!
@Balamut and I try to install macOS Ventura to the new HEDT Platform. Until now we solved a couple of issue but still stuck to some.
Lets start with the Specs:
I use a ASUS PRO WS W790 ACE - with a Intel Xeon W3-2423 - Radeon VII - ADATA 960 Legend
Balamut use a ASUS W790 Sage with a W9-3475X - AMD 6900 XT - WD SSD
All components besides the CPU/Mainboard definitely work without issues under macOS.
Our problem is DSDT related... RHUB like I guess at the moment to be exactly.
We tried to create an RHUB SSDT, all paths are definitely correct but we still get this error message in the debug log:
ACPI Error: [\_SB_.PC00.XHCI.RHUB.HS01] Namespace lookup failure, AE_NOT_FOUND (20160930/dswload-292)
ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20160930/psobject-310)
ACPI Exception: AE_NOT_FOUND, (SSDT:  A M I ) while loading table (20160930/tbxfload-319)
ACPI Error: 1 table load failures, 7 successful (20160930/tbxfload-342)
The Installation stucks always on waiting for root device which is related to USB.
Tried to create an USB Kext under Windows but this still didn't solve the issue.
Attaching the full log and the acpi tables:
log.txt.zipACPI.zip
Kind Regards
Alex
PS: Please move the Thread to the right section. Just realized I posted it in the wrong section. @Gengik84
Edited by DSM2
Tags added
Ok after spending some time of poking around this I came up with.
I've had a hypothesis that the issue might not actually be the USB but deeper, so I've setup OC on the EFI partition of NVME, installed 2 separate NVME drivers with Monterey and Ventura Installed on them, also I've dusted off and old SATA drive with early version of Monterey installed on it and manage to get interesting results.
I'll attach all the logs at the end of the post.
1. Booting from OC from USB and trying to boot USB Installer, gets waiting for root device and then panics on IONVmeFamily.
[AHCI][HBA][00170000] start::512:Successfully initialized AHCI controller
Still waiting for root device
void AppleNVMeRequest::PrintRequest()::519:QID=0 fSubmissionTimeNS=0 Deadline=46420165279 DW0=00010009 DW10=00000007 DW11=00000000 DW12=00000000 DW13=00000000 DW14=00000000 DW15=00000000
panic(cpu 0 caller 0xffffff801201e674): nvme: "3rd party NVMe controller. Loss of MMIO space. Delete IO submission queue. fBuiltIn=1 MODEL=WD_BLACK SN750 SE 1TB FW=711130WD CSTS=0xffffffff US[1]=0x0 US[0]=0x0 VID=0x15b7 DID=0x501e CRITICAL_WARNING=0x0.\n" @IONVMeController.cpp:6147
Panicked task 0xffffff878b6d9698: 135 threads: pid 0: kernel_task
Backtrace (CPU 0), panicked thread: 0xffffff8c53236b30, Frame : Return Address
0xffffffa14c293a90 : 0xffffff800f8705fd mach_kernel : _handle_debugger_trap + 0x4ad
0xffffffa14c293ae0 : 0xffffff800f9c4b84 mach_kernel : _kdp_i386_trap + 0x114
0xffffffa14c293b20 : 0xffffff800f9b4619 mach_kernel : _kernel_trap + 0x3c9
0xffffffa14c293b80 : 0xffffff800f810951 mach_kernel : _return_from_trap + 0xc1
0xffffffa14c293ba0 : 0xffffff800f8708dd mach_kernel : _DebuggerTrapWithState + 0x5d
0xffffffa14c293c90 : 0xffffff800f86ff87 mach_kernel : _panic_trap_to_debugger + 0x1a7
0xffffffa14c293cf0 : 0xffffff800ffdd09b mach_kernel : _panic + 0x84
0xffffffa14c293de0 : 0xffffff801201e674 com.apple.iokit.IONVMeFamily : __ZN16IONVMeController14CommandTimeoutEP16AppleNVMeRequest.cold.1
0xffffffa14c293df0 : 0xffffff8012001852 com.apple.iokit.IONVMeFamily : __ZN16IONVMeController13FatalHandlingEv + 0xfe
0xffffffa14c293e20 : 0xffffff800ff1c936 mach_kernel : __ZN18IOTimerEventSource15timeoutSignaledEPvS0_ + 0x96
0xffffffa14c293e70 : 0xffffff800ff1c846 mach_kernel : __ZN18IOTimerEventSource17timeoutAndReleaseEPvS0_ + 0xc6
0xffffffa14c293ea0 : 0xffffff800f8c6c08 mach_kernel : _thread_call_delayed_timer + 0x508
0xffffffa14c293ee0 : 0xffffff800f8c7cb8 mach_kernel : _thread_call_delayed_timer + 0x15b8
0xffffffa14c293fa0 : 0xffffff800f81019e mach_kernel : _call_continuation + 0x2e
         com.apple.iokit.IONVMeFamily(2.1)[2C32FDE9-ECB0-310C-85D0-E87ABAF02E37]@0xffffff8011ff9000->0xffffff8012025fff
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[51EB454D-1515-39A1-A67B-305B05451E22]@0xffffff8010de2000->0xffffff8010e15fff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[98683EFC-EF7A-3169-8DD1-9227B9A27BAA]@0xffffff8012291000->0xffffff80122c1fff
            dependency: com.apple.iokit.IOReportFamily(47)[491DDA55-D371-3A28-9A77-C28DB013D8AE]@0xffffff80122d2000->0xffffff80122d4fff
            dependency: com.apple.iokit.IOStorageFamily(2.1)[EA2A9009-708A-36D7-8AD6-829DEA8C4FE3]@0xffffff80123c5000->0xffffff80123dcfff
Process name corresponding to current thread (0xffffff8c53236b30): kernel_task
Boot args: -v serial=5 keepsyms=1 debug=0x100 acpi_layer=0x8 msgbuf=1048576 root-dmg=file:///BaseSystem/BaseSystem.dmg
Mac OS version:
Not yet set
Kernel version:
Darwin Kernel Version 22.4.0: Mon Mar  6 21:00:17 PST 2023; root:xnu-8796.101.5~3/RELEASE_X86_64
Kernel UUID: CF2A42DA-3F7C-30C6-9433-6F2076FF1F94
roots installed: 0
KernelCache slide: 0x000000000f400000
KernelCache base:  0xffffff800f600000
Kernel slide:      0x000000000f4dc000
Kernel text base:  0xffffff800f6dc000
__HIB  text base: 0xffffff800f500000
System model name: MacPro7,1 (Mac-27AD2F918AE68F61)
System shutdown begun: NO
Panic diags file unavailable, panic occurred prior to initialization
Hibernation exit count: 0
System uptime in nanoseconds: 85717365498
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x00000013f5ce0bbb
  Sleep   : 0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake    : 0x0000000000000000 0x000000533bf16339 0x0000000000000000
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
  Zone map: 0xffffff810b610000 - 0xffffffa10b610000
  . PGZ   : 0xffffff810b610000 - 0xffffff812b60d000
  . VM    : 0xffffff812b60d000 - 0xffffff85f360d000
  . RO    : 0xffffff85f360d000 - 0xffffff878b60d000
  . GEN0  : 0xffffff878b60d000 - 0xffffff8c5360d000
  . GEN1  : 0xffffff8c5360d000 - 0xffffff911b60d000
  . GEN2  : 0xffffff911b60d000 - 0xffffff95e360d000
  . GEN3  : 0xffffff95e360d000 - 0xffffff9aab60e000
  . DATA  : 0xffffff9aab60e000 - 0xffffffa10b610000
  Metadata: 0xffffffca048aa000 - 0xffffffca248aa000
  Bitmaps : 0xffffffca248aa000 - 0xffffffca348aa000
  Extra   : 0 - 0
2. Booting from OC from USB booting SATA Drive with Monterey on it gets a different panic.
IOPlatformPanicAction -> AppleAHCIDiskDriver
panic(cpu 8 caller 0xffffff80171d0773): Kernel trap at 0xffffff8017169a30, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0xffffff8100000000, CR3: 0x00000000226b0000, CR4: 0x00000000003626e0
RAX: 0x0000000003992492, RBX: 0xffffff8036800000, RCX: 0x0000000000000006, RDX: 0xffffff801805cb14
RSP: 0xffffffd21499be20, RBP: 0xffffffd21499be50, RSI: 0x0000000003a4d7b2, RDI: 0xffffffd21499be2c
R8:  0x000000000055f8ea, R9:  0x0000000000000008, R10: 0xffffff80ffffffb8, R11: 0xffffff80ffffff80
R12: 0x00000000c97ffff0, R13: 0x0000000000000000, R14: 0x0000000000000000, R15: 0x0000000003a4d7b2
RFL: 0x0000000000010206, RIP: 0xffffff8017169a30, CS:  0x0000000000000008, SS:  0x0000000000000000
Fault CR2: 0xffffff8100000000, Error code: 0x0000000000000002, Fault CPU: 0x8, PL: 0, VF: 2
Panicked task 0xffffff9122d24670: 140 threads: pid 0: kernel_task
Backtrace (CPU 8), panicked thread: 0xffffff9122d04aa0, Frame : Return Address
0xffffffd21499b7d0 : 0xffffff801707fd6d mach_kernel : _handle_debugger_trap + 0x41d
0xffffffd21499b820 : 0xffffff80171e1016 mach_kernel : _kdp_i386_trap + 0x116
0xffffffd21499b860 : 0xffffff80171d0383 mach_kernel : _kernel_trap + 0x4d3
0xffffffd21499b8b0 : 0xffffff801701fa70 mach_kernel : _return_from_trap + 0xe0
0xffffffd21499b8d0 : 0xffffff801708013d mach_kernel : _DebuggerTrapWithState + 0xad
0xffffffd21499b9f0 : 0xffffff801707f8f6 mach_kernel : _panic_trap_to_debugger + 0x2b6
0xffffffd21499ba50 : 0xffffff8017914d93 mach_kernel : _panic + 0x84
0xffffffd21499bb40 : 0xffffff80171d0773 mach_kernel : _sync_iss_to_iks + 0x2c3
0xffffffd21499bcc0 : 0xffffff80171d0456 mach_kernel : _kernel_trap + 0x5a6
0xffffffd21499bd10 : 0xffffff801701fa70 mach_kernel : _return_from_trap + 0xe0
0xffffffd21499bd30 : 0xffffff8017169a30 mach_kernel : _vm_free_delayed_pages + 0x190
0xffffffd21499be50 : 0xffffff80171698b7 mach_kernel : _vm_free_delayed_pages + 0x17
0xffffffd21499be70 : 0xffffff80170b6c2a mach_kernel : _max_valid_stack_address + 0x145a
0xffffffd21499bfa0 : 0xffffff801701f19e mach_kernel : _call_continuation + 0x2e
Process name corresponding to current thread (0xffffff9122d04aa0): kernel_task
Mac OS version:
21G72
Kernel version:
Darwin Kernel Version 21.6.0: Sat Jun 18 17:07:25 PDT 2022; root:xnu-8020.140.41~1/RELEASE_X86_64
Kernel UUID: E3E2BC4D-7B6F-39CC-8890-73A6FB513830
KernelCache slide: 0x0000000016e00000
KernelCache base:  0xffffff8017000000
Kernel slide:      0x0000000016e10000
Kernel text base:  0xffffff8017010000
__HIB  text base: 0xffffff8016f00000
Panic diags file available: YES (0x0)
System uptime in nanoseconds: 21948109058
  Uptime  : 0x000000051cdbf330
  Wake    : 0x0000000000000000 0x000000539ee677f7 0x0000000000000000
Zone info:
  Zone map: 0xffffff8112da7000 - 0xffffffa112da7000
  . PGZ   : 0xffffff8112da7000 - 0xffffff8132da4000
  . VM    : 0xffffff8132da4000 - 0xffffff85fada4000
  . RO    : 0xffffff85fada4000 - 0xffffff8792da4000
  . GEN0  : 0xffffff8792da4000 - 0xffffff8c5ada4000
  . GEN1  : 0xffffff8c5ada4000 - 0xffffff9122da4000
  . GEN2  : 0xffffff9122da4000 - 0xffffff95eada4000
  . GEN3  : 0xffffff95eada4000 - 0xffffff9ab2da5000
  . DATA  : 0xffffff9ab2da5000 - 0xffffffa112da7000
  Metadata: 0xffffffd153bf7000 - 0xffffffd173bf7000
  Bitmaps : 0xffffffd173bf7000 - 0xffffffd193bf7000
** In Memory Panic Stackshot Succeeded ** Bytes Traced 85745 (Uncompressed 214944) **
IOPolledInterface::startIO[0] 0xe00002c7
IOPolledFileWrite(0x0xffffff8c5b245a00, 0x0, 0, 0x0) : IOStartPolledIO(0x0xffffff95eaaf7f80, kIOPolledWrite, 0, 0x1b9520000, 8192) returned 0xe00002c7
IOPolledFileWrite(gIOPolledCoreFileVars, 0, 0x0, NULL) returned 0xe00002c7
progress_notify_stage_outproc (during forwarding) returned 0xe00002c7
(kern_dump_write_public_key) outproc data flush returned 0xe00002c7
(do_kern_dump write public key) returned 0xe00002c7
IOPolledFileWrite(0x0xffffff8c5b245a00, 0x0, 0, 0x0) : IOStartPolledIO(0x0xffffff95eaaf7f80, kIOPolledWrite, 0, 0x1b9520000, 8192) returned 0xffffffff
IOPolledFileWrite (during EOF) returned 0xffffffff
progress_notify_stage_outproc (during forwarding) returned 0xffffffff
(do_kern_dump close) outproc(KDP_EOF, NULL, 0, 0) returned 0xffffffff
Attempting system restart...
3. Booting from OC from USB booting Ventura from NVME I've once manage to almost get to the login scree but reboot, I've got a feeling that this one might have been a fluke.
IOG flags 0x3 (0x51)
ACMRM: _mapAndPublishTRM: set TRM_CacheMiss = False.
ACMRM: _mapAndPublishTRM: sending kIOMessageServicePropertyChange(n=1) while LOCKED, TRM: 259200 U/0 172800 -/ff miss=0 (CUR: 259200 U/0 172800 X/0).
ACMRM: _logPolicy: SAVING (sync): ver=8 smTm=0 poRsn=0 gpTm=0 smExp=NO gpBlk=NO suTm=0 svTm=1684374591 gpRsn=0 cMs=NO.
ACMRM-S: setData: saving policy (len=41) in 1 seconds.
ACMRM: _registerBioNotifier: Biometric driver not detected.
awdd[239] triggered unnest of range 0x7ff842000000->0x7ff842200000 of DYLD shared region in VM map 0x6ec4e9f63ca8830d. While not abnormal for debuggers, this increases system memory footprint until the target exits.
AppleKeyStore:11114:246: operation failed (sel: 17 ret: e00002f0, 205, 100005)
virtual bool CoreAnalyticsUserClient::initWithTask(task_t, void *, UInt32, OSDictionary *)::165:success
IOReturn CoreAnalyticsHub::setClientGated(CoreAnalyticsUserClient *)::321:adding userClient
IOReturn CoreAnalyticsHub::__newUserClientGated(task_t, void *, UInt32, OSDictionary *, IOUserClient **)::276:Successfully opened
virtual IOReturn CoreAnalyticsUserClient::clientMemoryForType(UInt32, IOOptionBits *, IOMemoryDescriptor **)::269: got memory descriptor with 16432
ACMRM-S: _saveAll: pushing policy -> daemon (gen=1 len=41).
apfs_keybag_init:2214: failed to initialize volume keybag, err = 2
EXC_RESOURCE -> coreduetd[108] exceeded mem limit: ActiveSoft 50 MB (non-fatal)
KextLog: kernelmanagerd is not active
cryptoAlloc:676: Using 64 buffers with size 16384, 512 buffers size 65536
dev_init:314: disk2s2 device accelerated crypto: 0 (compiled @ Jul 13 2022 22:54:35)
dev_init:317: disk2s2 device_handle block size 4096 block count 122092289 features 0 internal
nx_mount:1184: disk2s2 initializing cache w/hash_size 8192 and cache size 32768
nx_mount:1460: disk2s2 checkpoint search: largest xid 15296, best xid 15296 @ 111
nx_mount:1462: disk2s2 reloading after unclean unmount, checkpoint xid 15296, superblock xid 15294
nx_get_volume_group:7912: disk2s2 volume groups tree is not setup yet
getVolumeGroupMountFrom:7453: disk2s2 nx_get_volume_group(49712122-1B10-4BB8-9EFB-55D91655A2DF) failed with error 2
KextLog: Loading FileSet KC(s)
KextLog: Loading Pageable KC from file /System/Library/KernelCollections/SystemKernelExtensions.kc
KextLog: Collection UUID matches with loaded KCs.
deferred rematching count 0
Apple16X50ACPI1: Identified Serial Port on ACPI Device=UAR2
PROGRESS CODE: V00061000 I0
Plus many, many versions, File name kind of explains what they are.
If I stable the DisableIoMapper Quirk I get instant panic.
So I've disabled the DisableIoMapper quirk, dropped DMAR and Replaced it with the Fixed DMAR table still gets panic.
pci (build 20:54:36 Mar  6 2023), flags 0xc3080
panic(cpu 0 caller 0xffffff8005bb4ad3): Kernel trap at 0xffffff80084a8d5f, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0xffffff91000000b4, CR3: 0x0000000021fe0000, CR4: 0x00000000003606e0
RAX: 0x00000000000c3080, RBX: 0xffffffdde1b9e000, RCX: 0x000000000000000a, RDX: 0x0000000000000008
RSP: 0xfffffff4ac4f3c40, RBP: 0xfffffff4ac4f3c80, RSI: 0xffffff9100000030, RDI: 0x0000000000000200
R8:  0x000000000000ffff, R9:  0x00000000ffffffff, R10: 0x0000000000000001, R11: 0x0000000000001001
R12: 0xffffff8c5a85c900, R13: 0x00000000d4f52801, R14: 0xffffff80084c9b88, R15: 0xffffff9ab2250e00
RFL: 0x0000000000010286, RIP: 0xffffff80084a8d5f, CS:  0x0000000000000008, SS:  0x0000000000000000
Fault CR2: 0xffffff91000000b4, Error code: 0x0000000000000000, Fault CPU: 0x0, PL: 0, VF: 1
Panicked task 0xffffff95ea506bf8: 28 threads: pid 0:
Backtrace (CPU 0), panicked thread: 0xffffff8c5a3deb30, Frame : Return Address
0xfffffff4ac4f3600 : 0xffffff8005a705fd mach_kernel : _handle_debugger_trap + 0x4ad
0xfffffff4ac4f3650 : 0xffffff8005bc4b84 mach_kernel : _kdp_i386_trap + 0x114
0xfffffff4ac4f3690 : 0xffffff8005bb4619 mach_kernel : _kernel_trap + 0x3c9
0xfffffff4ac4f36f0 : 0xffffff8005a10951 mach_kernel : _return_from_trap + 0xc1
0xfffffff4ac4f3710 : 0xffffff8005a708dd mach_kernel : _DebuggerTrapWithState + 0x5d
0xfffffff4ac4f3800 : 0xffffff8005a6ff87 mach_kernel : _panic_trap_to_debugger + 0x1a7
0xfffffff4ac4f3860 : 0xffffff80061dd09b mach_kernel : _panic + 0x84
0xfffffff4ac4f3950 : 0xffffff8005bb4ad3 mach_kernel : _sync_iss_to_iks + 0x2c3
0xfffffff4ac4f3ad0 : 0xffffff8005bb47c4 mach_kernel : _kernel_trap + 0x574
0xfffffff4ac4f3b30 : 0xffffff8005a10951 mach_kernel : _return_from_trap + 0xc1
0xfffffff4ac4f3b50 : 0xffffff80084a8d5f com.apple.iokit.IOPCIFamily : __ZN8AppleVTD12initHardwareEP9IOService + 0x127
0xfffffff4ac4f3c80 : 0xffffff800612277a mach_kernel : __ZN8IOMapper5startEP9IOService + 0x1a
0xfffffff4ac4f3cb0 : 0xffffff80084a5dd7 com.apple.iokit.IOPCIFamily : __ZN8AppleVTD7installEP10IOWorkLoopjP9IOServicePK6OSDataP32IOPCIMessagedInterruptController + 0xdb
0xfffffff4ac4f3cf0 : 0xffffff80084b86e4 com.apple.iokit.IOPCIFamily : __Z23IOPCIPlatformInitializev + 0x21c
0xfffffff4ac4f3d40 : 0xffffff80069690c3 com.apple.driver.AppleACPIPlatform : __ZN23AppleACPIPlatformExpert21initPCIExpressSupportEv + 0x19f
0xfffffff4ac4f3d90 : 0xffffff8006962788 com.apple.driver.AppleACPIPlatform : __ZN23AppleACPIPlatformExpert5startEP9IOService + 0x2c4
0xfffffff4ac4f3dd0 : 0xffffff80060ec991 mach_kernel : __ZN9IOService14startCandidateEPS_ + 0xd1
0xfffffff4ac4f3e30 : 0xffffff80060ec50a mach_kernel : __ZN9IOService15probeCandidatesEP12OSOrderedSet + 0xdba
0xfffffff4ac4f3ef0 : 0xffffff80060eb5bf mach_kernel : __ZN9IOService14doServiceMatchEj + 0x3af
0xfffffff4ac4f3f50 : 0xffffff80060ee5f7 mach_kernel : __ZN15_IOConfigThread4mainEPvi + 0x157
0xfffffff4ac4f3fa0 : 0xffffff8005a1019e mach_kernel : _call_continuation + 0x2e
         com.apple.iokit.IOPCIFamily(2.9)[98683EFC-EF7A-3169-8DD1-9227B9A27BAA]@0xffffff8008491000->0xffffff80084c1fff
         com.apple.driver.AppleACPIPlatform(6.1)[19DE4373-3744-3B75-A4EE-3C799E649D8F]@0xffffff8006961000->0xffffff80069d8fff
            dependency: com.apple.driver.AppleSMC(3.1.9)[DD55DA6A-679A-3797-947C-0B50B7B5B659]@0xffffff80070c3000->0xffffff80070dffff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[D342E754-A422-3F44-BFFB-DEE93F6723BC]@0xffffff8008021000->0xffffff8008022fff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[98683EFC-EF7A-3169-8DD1-9227B9A27BAA]@0xffffff8008491000->0xffffff80084c1fff
Process name corresponding to current thread (0xffffff8c5a3deb30): Unknown
Mac OS version:
Not yet set
Kernel version:
roots installed: 0
KernelCache slide: 0x0000000005600000
KernelCache base:  0xffffff8005800000
Kernel slide:      0x00000000056dc000
Kernel text base:  0xffffff80058dc000
__HIB  text base: 0xffffff8005700000
System uptime in nanoseconds: 4470827513
  Uptime  : 0x000000010b20cf88
  Wake    : 0x0000000000000000 0x00000061110c5657 0x0000000000000000
Zone info:
  Zone map: 0xffffff81124a1000 - 0xffffffa1124a1000
  . PGZ   : 0xffffff81124a1000 - 0xffffff813249e000
  . VM    : 0xffffff813249e000 - 0xffffff85fa49e000
  . RO    : 0xffffff85fa49e000 - 0xffffff879249e000
  . GEN0  : 0xffffff879249e000 - 0xffffff8c5a49e000
  . GEN1  : 0xffffff8c5a49e000 - 0xffffff912249e000
  . GEN2  : 0xffffff912249e000 - 0xffffff95ea49e000
  . GEN3  : 0xffffff95ea49e000 - 0xffffff9ab249f000
  . DATA  : 0xffffff9ab249f000 - 0xffffffa1124a1000
  Metadata: 0xffffffd760fd3000 - 0xffffffd780fd3000
  Bitmaps : 0xffffffd780fd3000 - 0xffffffd790fd3000
  Extra   : 0 - 0
** In Memory Panic Stackshot Succeeded ** Bytes Traced 4801 (Uncompressed 11408) **
Please go to https://panic.apple.com to report this panic
The region in DMAR is this correct?
[180h 0384   2]                Subtable Type : 0001 [Reserved Memory Region]
[182h 0386   2]                       Length : 0020
[184h 0388   2]                     Reserved : 0000
[186h 0390   2]           PCI Segment Number : 0000
[188h 0392   8]                 Base Address : 000000006EF67000
[190h 0400   8]          End Address (limit) : 000000006EF8CFFF
[198h 0408   1]            Device Scope Type : 01 [PCI Endpoint Device]
[199h 0409   1]                 Entry Length : 08
[19Ah 0410   2]                     Reserved : 0000
[19Ch 0412   1]               Enumeration ID : 00
[19Dh 0413   1]               PCI Bus Number : 00
[19Eh 0414   2]                     PCI Path : 14,00
Also in the DMAR there is this weird part that I had to remove.
[2B8h 0696   2]                Subtable Type : 0005 [Unknown Subtable Type]
[2BAh 0698   2]                       Length : 0010
**** Unknown DMAR subtable type 0x5
Tried every possible combination,  no go.
Also attaching the ACPI Dump from Clover with the latest BIOS.
origin.zip
LOGS.zip
hi DSM2
I see no AppleMCEReporterDisabler.kext used (and you have MacPro7.1 SMBIOS)
Also Kernel/quirk ProvideCurrentCPUInfo is unflagged
Is there a reason for these two not used option?
Posted (edited)
it was a left over which I forgot to remove during all the configurations I tried.
AppleMCEReporterDisabler.kext is not necessary exactly like providecurrentcpuinfo for a successful boot and install.
I can still provide a log with it but it won't change anything in the log/boot process from my experience (Kext/providecurrentcpuinfo)
Edited by DSM2
have you tried a bit of these booster quirks combinations (the selected ones in different combinations I mean)?
I don't see in log MAT value
@Lorys89 shuts down:
09:253 05:061 AAPL: #[EB|MBA:CL] <"-v serial=5 keepsyms=1 debug=0x100 acpi_layer=0x8 msgbuf=1048576 slide=193">
09:423 00:170 AAPL: #[EB|MBA:NV] <"<null string>">
09:584 00:161 AAPL: #[EB|MBA:KF] <"<null string>">
09:654 00:069 AAPL: #[EB|MBA:OUT] <"-v serial=5 keepsyms=1 debug=0x100 acpi_layer=0x8 msgbuf=1048576 slide=193">
09:711 00:057 AAPL: #[EB|KMR] 597229568
09:755 00:043 AAPL: #[EB.CS.CSKSD|+]
09:806 00:051 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
09:863 00:056 AAPL: #[EB|WL] 0 0 0x01 0x01   6 0x0E
09:907 00:044 AAPL: #[EB.CS.LFC|+]
10:001 00:093 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey"> <"0">
10:109 00:108 AAPL: #[EB.FS.AGSVH|PU] 23F8F1EF-1E73-42E9-B834-11398FCEDA38
10:166 00:056 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
10:223 00:056 AAPL: #[EB.G.CS|-?] Ok(0)
10:276 00:052 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
10:333 00:057 AAPL: #[EB.B.SBS|SZ] 739896
10:392 00:059 AAPL: #[EB|B:SHA] <55e1fe2c48b5541698b030ac8eaf88d65fe0935c>
10:449 00:056 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
10:506 00:057 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
10:565 00:059 AAPL: #[EB.WL.PWLFRTC|NONE]
10:617 00:051 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
10:672 00:054 AAPL: #[EB.LD.LKC|D] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development">
10:734 00:062 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
10:797 00:062 AAPL: #[EB.LD.LKC|R.2] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc">
11:719 00:922 AAPL: #[EB.LD.LKFS|-?] Ok(0)
11:770 00:050 AAPL: #[EB.LD.LKC|-?] Ok(0)
11:816 00:046 AAPL: #[EB|FWFM] 0x00000008FFFFFF7F
11:866 00:049 AAPL: #[EB|FWFT] 0x00000008FDAFF066
11:955 00:088 AAPL: #[EB|BST:REV1]
12:006 00:050 AAPL: #[EB|CSR:OUT] 0x00000867
12:057 00:051 AAPL: #[EB.BST.FBS|+]
12:109 00:051 AAPL: #[EB.BST.FBS|ADSZ] 0
12:160 00:051 AAPL: #[EB.BST.FBS|KSSZ] 0
12:211 00:051 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
12:265 00:053 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
12:314 00:049 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">
12:385 00:070 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
12:494 00:109 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m"> <"0">
12:552 00:058 AAPL: #[EB.BST.FBS|RHPSZ] 229
12:603 00:050 AAPL: #[EB.BST.FBS|RHMSZ] 3627
12:654 00:050 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0
12:707 00:052 AAPL: #[EB|LOG:DT] 2023-09-18T03:51:49
12:761 00:053 AAPL: #[EB|LOG:EXITBS:START] 2023-09-18T03:51:49
#[EB|LOG:EXITBS:END] _
#[EB.MM.FMM|!] Err(0x9) <- RT.SVAM
#[EB|WL] 0 0 0x01 0x41   6 0x0E
#[EB|REBOOT] 2
#[EB|LOG:RESET:FAIL] 2023-09-18T03:51:49
Small update, I've got the kernel debugger running and boy did it threw up data.
OC from USB and booting from USB Installer 13.4.
IOResources: family specific matching fails
From my limited understanding maybe we can fake device ID ands if it works?
Full log attached.
CoolTerm Capture 2023-05-18 14-06-42.txt.zip
Will try that attached EFI in a bit.
