Build Ryzen 9 7/9950X - ASUS ROG X670E Hero
Good news 🤗,
     Installed macos now after replaced nvme disk.
Thank you very much for your efforts and help.  I bought the T700 for macos because it is fast. Can mac be installed on this disk after a while?
Yep, I am using your SSDT-XHX.
Yeah I have checked Audio and Bluetooth and they work.
Thanks again your prepared EFI is working wonderfully. Macos is my main OS now. I didn't open my Windows OS since macOS was installed.
Is there any other kext etc you can recommend for the system?
On 6/11/2024 at 10:02 PM, fabiosun said:
thanks @Lorys89 he remembered me to update my basic kexts 🙂
No joy for me at the moment, I'll have to go on the hunt for the latest kexts as I thought I had the latest release versions of them all, but obviously not. Using the latest release of Opencore 1.0.0 😞
Just adding the extra patches resulted in a very unstable/unusable system.
So I deleted all existing patches and installed the ones from above along with the latest versions of the kexts. (I removed patches that were only for earlier versions of macOS - those before Sonoma)
The system is generally OK in both Sonoma & Sequoia BUT it randomly just turns off - I hear a click and the whole system is off. This results in the power buttons on the case not working.
The only way to get the system up again is to remove the power cable from the power supply and leave it for 10 seconds or so and then it will turn on again when I reconnect the power cable.
Very, very strange.
This happens in both Sonoma & Sequoia but a lot more often in Sequoia.
2 hours ago, Arrakis said:
@Ploddles
The problem you mention but I remember that I had the same problem.
It came from the PC power supply. You don't happen to have a Corsair PC power supply?
This is an intermittent failure typical of this brand.
Yes it is Corsair but it doesn't happen in Windows and didn't happen before updating to OC 1.0.0 and the new patches & Sequoia.
I do have another power supply I could try but that won't be for a few days as I am busy.
  • 4 weeks later...
  • fabiosun changed the title to Build Ryzen 9 7/9950X - ASUS ROG X670E Hero
