MacOS Updater [Mojave +]
  • Contributor
allora ho scaricato una versione sbagliata ? l'ho presa dal tuo github....comunque questa va diversamente, sta scaricando un solo file di 1,6 Gb circa mentre prima in totale erano diversi file per 370 mega circa...
  • Contributor
Niente da fare...
HFS/CS EnsureRecoveryPartition: Copying base system version plist
HFS/CS EnsureRecoveryPartition: Copying platform support plist
HFS/CS EnsureRecoveryPartition: Copying system image chunk list
HFS/CS EnsureRecoveryPartition: Creating boot plist
HFS/CS EnsureRecoveryPartition: Operation 80.0% complete
HFS/CS EnsureRecoveryPartition: Operation 95.0% complete
HFS/CS EnsureRecoveryPartition: Mounting recovery partition
HFS/CS EnsureRecoveryPartition: Blessing boot file
HFS/CS EnsureRecoveryPartition: Marking recovery partition
HFS/CS EnsureRecoveryPartition: Detaching Base System disk image
HFS/CS EnsureRecoveryPartition: Operation fully complete
HFS/CS EnsureRecoveryPartition: Operation finished
"disk2" unmounted.
"disk2" ejected.
UPDATING PRIMARY SYSTEM
productbuild: Wrote product to /tmp/041-39674/installer.pkg
installer: Package name is macOS Mojave 10.14.4 Developer Beta
installer: Upgrading at base path /
installer: The upgrade failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Do you want to backup installer.pkg? (y/N) y
BACKING UP
/Users/eniac/Desktop/MacOS_Updater: line 645:   922 Illegal instruction: 4  hdiutil create -format UDZO -srcfolder "${gWorkDir}/${gInstallerPackage}" "${gUserPath}/Installer_${gVersion}_${build}"
CLEANING UP
Ha scritto dopo 40 minuti 8 secondi:
Sia benedetto Time machine...sono riuscito a ripartire incolume emoticon-personaggi_89
Edited by foskvs
  • 6 months later...
ciao
wow , anche se mi perdo sempre nei forum , lo ho trovato
posso chiedere una cosa?
oppure è come un'applicazione che il check e i lascia vedere e caso mai decidere cosa installare ,intendo 3 aggiornmanti sarebbe bello se si potesse scegliere uno dei tre?
ho visto un video su utube , con la colonna sonora dei Led Zeppelin 3
quì trovo la versione più aggiornata?
Ciao, cosa dovrebbe lasciarti vedere?
scusa ma non capisco
riguardo all'update non puoi scegliere perchè ovviamente ti porta direttamente al'ultima versione disponibile.
Comunque per versioni release puoi usare anche il combo update Apple dopo averlo sbloccato
Ha scritto dopo 52 secondi:
Riguardo alla versione dello script non ci sono problemi perchè se anche tu avessi una vecchia ti sarebbe notificato e si auto-aggiornerebbe
ciao
ho messo mojave in HFS+
quindi non posso aggiornare tramite apple store
quindi se volessi aggiornate safari oppure l'aggiornamento di mojave o altri componenti come itunes
uso lo script , ma non mi da la possibilità di scegliere cosa voglio aggiornare
grazie
Edited by foskvs
intendi quale disco?
quello te lo dice dopo aver scaricato l'update
se intendi aggiornare singola app..beh questo proprio non esiste :D
ciao
forse sono stata poco chiara
mojave su HFS+
il programma da scritto aggiorna mojave vero ? E per aggiornare safari o itunes posso usare app store?
grazie
Edited by foskvs
  • 2 months later...
ciao a tutti
ho provato la prima volta e ha funzionato , per sbaglio ho spento la finestra del terminale durante il download dell'aggiornamento
ora non vuole partire , lo ho cancellato
e mi da questo errore
MacOS_Updater must be run as ROOT!
>>> /private/etc/sudoers.d/MacOS_Updater: syntax error near line 1 <<<
sudo: parse error in  near line 1
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
lo ho cercato ed è in /users/gaia
se ci clicco due volte mi da questo errore
sudo: parse error in parse error in parse error in doers.d/MacOS_Updater near line 1 near line 1
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Processo completato]
ho provato a cancellarlo , riscaricarlo ma mi da sempre lo stesso errore
perchè?
grazie
