App Utility developers InsanelyMac
Su insanely Mac sono state aggiornate diverse app che possono essere più o meno utili dipende dalle capacità e dall'approccio che ognuno di noi ha con macOS, ne elenco alcune ma ce ne sono diverse altre... buona ricerca :)
GetmacOS https://www.insanelymac.com/forum/files/file/872-getmacos/">https://www.insanelymac.com/forum/files ... -getmacos/">https://www.insanelymac.com/forum/files/file/872-getmacos/
The tool supports OS X 10.10 - 10.14 and capable of searching the following OSes in Appstore:
~ Mojave
~ High Sierra
~ Sierra
~ El Capitan
NVRAM and Kext Cache Cleanup and Rebuilding PrelinkedKernel Tool https://www.insanelymac.com/forum/files/file/790-nvram-and-kext-cache-cleanup-and-rebuilding-prelinkedkernel-tool/">https://www.insanelymac.com/forum/files ... rnel-tool/">https://www.insanelymac.com/forum/files/file/790-nvram-and-kext-cache-cleanup-and-rebuilding-prelinkedkernel-tool/
- Bug fix for macOS Mojave
- The new version will automatically closes all the open applications and will ask the users to save the open documents before restarting.
- I reverted back the app to Automator Application so the spinning wheel will be shown in the menu bar to show that the app is still running.
- New feature added to rebuild prelinkedkernel along with the NVRAM and Kext Cache cleanup.
- Some improvements and fixes for macOS Mojave compatibility
Software Update Switcher 10.8-10.14 SWUSwitcher.app https://www.insanelymac.com/forum/files/file/467-software-update-switcher-108-1014-swuswitcherapp/">https://www.insanelymac.com/forum/files ... itcherapp/">https://www.insanelymac.com/forum/files/file/467-software-update-switcher-108-1014-swuswitcherapp/
- Get a seed updates for macOS 10.8-10.14 without first having to sign up for Apple programs.
- (Completely replaces macOSPublicBetaAccessUtility.)
Gatekeeper Toggler https://www.insanelymac.com/forum/files/file/793-gatekeeper-toggler/">https://www.insanelymac.com/forum/files ... r-toggler/">https://www.insanelymac.com/forum/files/file/793-gatekeeper-toggler/
- Bug Fix for macOS Mojave
- In this version the app will check the status of the gatekeeper and it will prompt the user to change the gatekeeper accordingly.
- Some changes in the app's messages.
QuickESP https://www.insanelymac.com/forum/files/file/660-quickesp/">https://www.insanelymac.com/forum/files ... -quickesp/">https://www.insanelymac.com/forum/files/file/660-quickesp/
- Added support for macOS Mojave.
aggiornati:
iMessageFixer https://www.insanelymac.com/forum/files/file/946-imessage-fixer/">https://www.insanelymac.com/forum/files ... age-fixer/">https://www.insanelymac.com/forum/files/file/946-imessage-fixer/
MacOptimizer https://www.insanelymac.com/forum/files/file/790-mac-optimizer-nvram-and-kext-cache-cleanup-and-rebuilding-prelinkedkernel-tool/">https://www.insanelymac.com/forum/files ... rnel-tool/">https://www.insanelymac.com/forum/files/file/790-mac-optimizer-nvram-and-kext-cache-cleanup-and-rebuilding-prelinkedkernel-tool/
AirPortAtheros40.kext installer for macOS Mojave
https://www.insanelymac.com/forum/files/file/956-airportatheros40kext-installer-for-macos-mojave/">https://www.insanelymac.com/forum/files ... os-mojave/">https://www.insanelymac.com/forum/files/file/956-airportatheros40kext-installer-for-macos-mojave/
Mac Tweaks
https://www.insanelymac.com/forum/files/file/961-mac-tweaks/">https://www.insanelymac.com/forum/files ... ac-tweaks/">https://www.insanelymac.com/forum/files/file/961-mac-tweaks/
Intel FB-Patcher https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v137/">https://www.insanelymac.com/forum/topic ... cher-v137/">https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v137/
Features
- Supports Sandy Bridge, Ivy Bridge, Haswell, Broadwell, Skylake, Kaby Lake, Coffee Lake, Cannon Lake and Ice Lake generations
- Create All, Connectors or VRAM patches
- Detect Changes for auto patch creation
- Create Clover patches in hex, base64 or Devices/Properties formats
- Displays native GPU and Model identifiers
- Display and edit Memory Info such as Stolen, Framebuffer, VRAM, Cursor etc.
- Roll over some items for additional info (Tooltips)
- Reads "live" data directly from Framebuffer kexts (if available; see Mojave note below)
- File->Open framebuffer file generated by WhateverGreen's -igfxdump boot flag
- File->Export->Clover config.plist / File->Export->Framebuffer.txt file
- Patch audio layout id
- Add USB port limit patch
- Plug and unplug USB2 / USB3 devices and set port connector types then generate a USBPower.kext
- Advanced patching options (DVMT-prealloc 32 MB, VRAM 2048 MB, Disable eGPU, Enable HDMI20 (4K), Spoof SKL Audio, DP -> HDMI, USB port Limit, FB Port Limit)
Old App Store for Mojave
The High Sierra version of the App Store that can run in Mojave. According to my tests they can run in parallel, downloads work, access to purchased tab works.
You can easily access old macOS downloads.
It doesn't need to modify anything on the system.
You might have to open the Terminal and
xattr -r -d com.apple.quarantine in order to run it
* Note: The bundle is named Old App Store.app but it will appear as App Store
Info & Download https://www.insanelymac.com/forum/files/file/973-old-app-store-for-mojave/">https://www.insanelymac.com/forum/files ... or-mojave/">https://www.insanelymac.com/forum/files/file/973-old-app-store-for-mojave/
Ha scritto dopo 7 minuti 27 secondi:
Rinominato in App Store Old e messo in applicazioni di mojave HFS dell'hack 5 e funziona regolarmente :)
La versione di Clover Theme Manager 0.77 beta3 pare abbia risolto un bug in cui non rilevava correttamente nel sistema la https://www.macos86.it/viewtopic.php?f=42&t=37">NVRAM nativa
https://www.insanelymac.com/forum/topic/302674-clover-theme-manager/?do=findComment&comment=2647298">https://www.insanelymac.com/forum/topic ... nt=2647298">https://www.insanelymac.com/forum/topic/302674-clover-theme-manager/?do=findComment&comment=2647298
Verificato nei miei hack 2 e 3 ed effettivamente il problema pare risolto
https://postimg.cc/SYd43Q1y">LINK_TEXT>
  • 8 months later...
Gatekeeper Toggler 3.0 https://www.insanelymac.com/forum/files/file/793-gatekeeper-toggler/?page=2">https://www.insanelymac.com/forum/files ... er/?page=2">https://www.insanelymac.com/forum/files/file/793-gatekeeper-toggler/?page=2
New Interface and all new design
A new menu bar Feature for easy access.
A new feature for enabling Read/Write Access for macOS Catalina
MojaveMockup.png.eaace5e7356c042f939f8f6https://www.insanelymac.com/forum/uploa ... 27c64e.png">https://www.insanelymac.com/forum/uploads/monthly_2019_08/MojaveMockup.png.eaace5e7356c042f939f8f611d27c64e.png' alt='LINK_TEXT>'>
