4 hours ago, fabiosun said:
@Jaidytake look to this latest revision for both (Opencore and Clover)
As mainteiner of the Clover ones, we deleted a patch which is possible also to delete in OpenCore:
algrey | _cpuid_set_generic_info | Replace rdmsr(0x8B) with constant 186 | 10.13+
other patches are the same
Clover needs to use two patches in another config.plist's section
AMD_Vanilla-master 2.zip 9.22 kB · 1 download AMD_Vanilla-clover 2.zip 14.82 kB · 1 download
Thanks for your prompt reply, but I can not find any modification in these two config.plist.
Did I miss something because patch 6 & patch 7 still enabled in OC ?
In my FX6300 hackintosh these two patches only required at High Sierra (10.13) & Mojave (10.14) if booted by legacy OC 0.9.5.
However patch 9 & 12 are required from High Sierra to Sonoma if booted by legacy Clover 5155/5156/5157.
No such an issue in my Ryzen 1700X hackintosh booted by UEFI OpenCore or UEFI Clover.
That confused me a lot !
Edited by jsl2000
Sorry maybe i do not understand well
i do not use patches 7 in OC
also i do not use it in clover
No one has explained well where and in which contition OSX needs of it
I mean this patches:
I do not use legacy system in OSX so i can't say more
So the conclusion is that only patch 6 is essential in both OpenCore and Clover bootloaders for AMD hackintoshs, no need for patch 7 at all !
in the past i have asked where could it be useful..no answer
So i prefer to have disabled or deleted in my config.plist
it is the same also for "Visual patches" (no real answer to my question where do they could be useful...so deleted also them 🙂
  • 1 year later...
I'm so happy to say that after struggling for almost 4 weeks my Ryzen 1700X hackintosh can boot Tahoe beta2 by the newest Clover 5162 now.
The only issue was unable to enable its internal I211 adapter as AppleIGB which cause very slow boot to desktop and very unstable system soon later !
Also AMDRyzenCPUPowerManagement.kext must be disabled to prevent KP with Lilu.kext.
config.plist.zip
EFI-5162.zip
Edited by jsl2000
  • 3 weeks later...
It's a pity booted by Clover 5162/5163 I always got very poor crack sound output from Firefox.
No such an issue from Safari and less severe from Google Chrome.
Maybe it due to loss of boot-args booted by Clover and no such an issue booted by OpenCore in my AMD Hackintoshs.
  • 4 months later...
