Big Sur Panic e Usb 3.0 che non va
nicozan
Ho il seguente Pc:
Core i7 4790k
Gaz97x-ud5h
32 Gb Ram
Geforce 760
Ho creato l usb dall'installar da App Store e l'installazione si è conclusa ok. A parte qualche kets che ho sistemato, ho avuto un riavvio per Panic dopo un po che er avviato:
panic(cpu 5 caller 0xffffff800e09f6b6): [APFS_TREE_LOOKUP_ZONE]: element modified after free (off:144, val:0x0000000000000008, sz:4640, ptr:0xffffff86b372acc0, prot:zero)
  144: 0x0000000000000008
Backtrace (CPU 5), Frame : Return Address
0xffffffa103d12be0 : 0xffffff800d88e02d mach_kernel : _handle_debugger_trap + 0x3fd
0xffffffa103d12c30 : 0xffffff800d9d48e3 mach_kernel : _kdp_i386_trap + 0x143
0xffffffa103d12c70 : 0xffffff800d9c4eda mach_kernel : _kernel_trap + 0x55a
0xffffffa103d12cc0 : 0xffffff800d832a2f mach_kernel : _return_from_trap + 0xff
0xffffffa103d12ce0 : 0xffffff800d88d84d mach_kernel : _DebuggerTrapWithState + 0xad
0xffffffa103d12e00 : 0xffffff800d88db43 mach_kernel : _panic_trap_to_debugger + 0x273
0xffffffa103d12e70 : 0xffffff800e09d68a mach_kernel : _panic + 0x54
0xffffffa103d12ee0 : 0xffffff800e09f6b6 mach_kernel : _kheap_temp_leak_panic + 0x1b7c
0xffffffa103d13360 : 0xffffff800d8ec816 mach_kernel : _work_interval_port_type_render_server + 0x4446
0xffffffa103d133d0 : 0xffffff8010a3a81c com.apple.filesystems.apfs : __apfs_zalloc + 0x29
0xffffffa103d133f0 : 0xffffff8010a3c9ac com.apple.filesystems.apfs : _iterate_raw_jobjs_with_hint + 0x6c
0xffffffa103d134a0 : 0xffffff8010a4050d com.apple.filesystems.apfs : _fs_lookup_name_with_parent_id + 0x251
0xffffffa103d13590 : 0xffffff8010a50623 com.apple.filesystems.apfs : _fs_lookup_name_and_hash + 0x3f
0xffffffa103d135c0 : 0xffffff80109f9161 com.apple.filesystems.apfs : _apfs_lookup_name_with_alt_name + 0x43
0xffffffa103d13600 : 0xffffff80109fa96b com.apple.filesystems.apfs : _apfs_internal_lookup + 0xec
0xffffffa103d13680 : 0xffffff80109e6b6d com.apple.filesystems.apfs : _apfs_vnop_lookup + 0x3ec
0xffffffa103d13790 : 0xffffff800db1116e mach_kernel : _lookup + 0x36e
0xffffffa103d138f0 : 0xffffff800db10454 mach_kernel : _namei + 0x1124
0xffffffa103d13b10 : 0xffffff800db2bfd9 mach_kernel : _vnode_getfromfd + 0x129
0xffffffa103d13b70 : 0xffffff800db385e9 mach_kernel : _mkdir_extended + 0x269
0xffffffa103d13d60 : 0xffffff800db38a70 mach_kernel : _mkdirat + 0xb0
0xffffffa103d13f40 : 0xffffff800df40dae mach_kernel : _unix_syscall64 + 0x2ce
0xffffffa103d13fa0 : 0xffffff800d8331f6 mach_kernel : _hndl_unix_scall64 + 0x16
         com.apple.filesystems.apfs(1677.100.114)[0F8B7E4F-B9D1-3025-8BD2-8B61FF0C7408]@0xffffff801099a000->0xffffff8010b08fff
            dependency: com.apple.driver.AppleEFINVRAM(2.1)[C6EE02AA-79D2-3EF8-83A6-9E52549E16D9]@0xffffff800ecfe000->0xffffff800ed07fff
            dependency: com.apple.driver.AppleEffaceableStorage(1.0)[76C6AF60-9B70-3605-A55D-2CFD5A9A9119]@0xffffff800ed11000->0xffffff800ed16fff
            dependency: com.apple.iokit.CoreAnalyticsFamily(1)[D5B09BBE-AC6C-341E-A9FE-B37DF7FDCE68]@0xffffff800f165000->0xffffff800f16bfff
            dependency: com.apple.iokit.IOStorageFamily(2.1)[58EA4506-4E6B-3AC3-A70D-ED35EE2C381D]@0xffffff8010462000->0xffffff8010473fff
            dependency: com.apple.kec.corecrypto(11.1)[00A376AB-A0BD-3B83-A12D-A7039E31BD9B]@0xffffff8010b36000->0xffffff8010bc7fff
            dependency: com.apple.security.AppleImage4(3.0.0)[3B0BB671-CB78-3004-8A3A-D18783570E64]@0xffffff800ed75000->0xffffff800ed85fff
Process name corresponding to current thread: trustd
Boot args: -v keepsyms=1 alcid=1
Mac OS version:
20E241
Kernel version:
Darwin Kernel Version 20.4.0: Thu Apr 22 21:46:47 PDT 2021; root:xnu-7195.101.2~1/RELEASE_X86_64
Kernel UUID: 068F99A3-1DB3-31C0-87D5-09942F122BB6
KernelCache slide: 0x000000000d600000
KernelCache base:  0xffffff800d800000
Kernel slide:      0x000000000d610000
Kernel text base:  0xffffff800d810000
__HIB  text base: 0xffffff800d700000
System model name: iMac15,1 (Mac-42FD25EABCABB274)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 11243697656614
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x00000a39e09ad63a
  Sleep   : 0x00000a39dea1da68 0x00000001c55c09f1 0x00000a2c3c4da69e
  Wake    : 0x00000a39df99120b 0x00000001c5fb18a5 0x00000a39deb9b9c1
Poi ho una USB 3.0 che non va!
Potete aiutarmi?
3 minuti fa, nicozan ha scritto:
seeee....nn ci riuscirò mai
you can do it , sei avvantaggiato questi 2 passaggi non li devi fare 😆
Aggiungiamo la patch per aumentare il port limit sul config
Aggiungiamo usbinjectall.kext nella EFI
Non è proprio basilare injectall ma in caso può metterlo per mappare
il discorso della mappatura col fatto che il port limit non funziona, va fatta in più volte
@nicozan in caso tu mappa le usb, alla fine salva e allega ioreg
allora vi aggiorno ho usato Hackintool mi sembrava più semplice
non avevo il Port limit sul config.plist .  ho scollegato le chiavette
da tutte le porte e le usb rimaste bianche le ho tolte da Hackintool.
poi ho esportato e ottenuto il kekt delle porte usb, che ho messo
nella eri nell'opportuno percorso e aggiornato il plist. allego schermata.
puo essere corretto il procedimento?
Per quanto riguarda il Panic da cosa è stato causato?
per iniziare, ma non è il caso che applichi le patch
EHC1 to > EH01
EHC2 to EH02
anche se esulano dal discorso delle 15 porte
da ultimo ioreg, poi come dice gengik, è presente una sola SS01, quindi una sola USB3, ma non vedo USBinjectall per attivarle prima tutte e poi mapparle; per cui anche se usi hackintool, serve poco. Inoiltre per la precisione, spero hai usato il solo kext che produce e non anche l'SSDT
