Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Ah si pensavo ad altro, ora le metto... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 SSDT che posso usare..? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 Basic 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 VIA VT1708S dici va... Basic senza DMZ ecc... il PM..? ssdt per il PM..? Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Sembra limitato ad haswell... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 allora x86 è caricato, quindi sta nel Basic :)... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 bene... poi fai ioreg 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 iMac di Admin.zip Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 le usb come vanno? vedo hai messo il rename 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 invece di una funzionano anche le posteriori, mi sembrano poche nella lista..? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 no... tu hai guardato solo XHC ma ivy non ha un unico controller ha XHC per le usb 3 e EHCx per le usb 2 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 config.plist.zip Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 SysReport.zip Smonto il Raid di Windows e mi sposto su un HDD diverso per vedere se cambiando Periferica il Disco ha un comportamento diverso... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 VT1708S non lo vedo tra i codec, mi pareva che c'era..? Mi sbaglio allora... Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Ho messo un Disco più veloce, la situazione è migliorata, ma non mi convince pienamente, come non sapesse bene dove andare a cercare quando si avvia un applicazione... La macchina non è un fulmine, il Secondo stage è bianco, e ci mette un po' a passarlo, non è complice l'HDD in questo caso, ci mette ad elaborare gli input... Ci sono 6 Gb di RAM sulla Macchina... Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Per l'attivazione uso: - radpg=15 agdpmod=vit9696 forse la parte di vit posso eliminarla..? Queste due opzioni ci vogliono entrambi, le ho messe insieme, magari ne basta una: - Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 L'Audio, forse con Voodoo, ma ho ricordi poco felici di questo kext, ora cmq ho Audio HDMI... Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Visto che ho 2 Dischi c'è la possibilità di Installare il Sistema su un RAID Software, credo di si..? Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted November 1, 2020 Moderators Share Posted November 1, 2020 2 ore fa, netgear ha scritto: Visto che ho 2 Dischi c'è la possibilità di Installare il Sistema su un RAID Software, credo di si..? e se non lo sai tu?😂 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Eh RAID Software Apple che ne so io... Quelli Windows ne faccio tanti, si proverà appena la config è al 100%... Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Allora ci siamo manca solo VooDoo per l'Audio :)... 10.14 per ora perfetta... la 10.15 si vedrà... Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 EFI Ultima, l'appoggio qui almeno la ritrovo... - EFI_P8H77-V_Deb_0.6.2.zip Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Installato in RAID 0, ma al Boot OpenCore non lo vede, ma siccome lo vede dopo ora verifico che non sia escluso dallo Scan... @Gengik84, noto una piccola imperfezione nella configurazione Installer/Recoveri, si avvia con tatsiera Italiana Macchina da scrivere, invece di Italiana... - Lo Scan è a 0, allora come mai non lo vede bootable..? Link to comment Share on other sites More sharing options...
Moderators netgear Posted November 1, 2020 Author Moderators Share Posted November 1, 2020 Lo riconosce addirittura R/Drive Image: - Quindi è il Boot che non lo gestisce o ci vuole un Driver, probabilmente al BOOT rimangono due Dischi separati... Link to comment Share on other sites More sharing options...
