Supervisor fabiosun Posted October 31, 2020 Supervisor Share Posted October 31, 2020 Ci sono allinizio dei valori altini di clock ma potrebbero essere di override di overclock standard 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 UEFI spuntato... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 31, 2020 Supervisor Share Posted October 31, 2020 Si vedi hai spunta su uefi e se vedi il bios è piú nuovo 1 Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted October 31, 2020 Moderators Share Posted October 31, 2020 015.041 l'ho appena trovato ed 😀è quello flashato da te dovrebbe andare e della flex https://www.techpowerup.com/vgabios/151230/151230 151230.rom.zip 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Ora che faccio avvio una 10.13 e vedo se ho sempre lo schermo Nero, dite che sta modifica sia risolutiva, poi se va provo una 10.14 e 10.15, ma non allarghiamoci ora che abbiamo avuto cul@... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 31, 2020 Supervisor Share Posted October 31, 2020 Per me si se la scheda è compatibile con i sistemi piu nuovi bast che trovi i flag giusti ma il grosso lo hai fatto Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Avvio sta Open Core allora... 10.13.6... La Avvio da USB perché su questa macchina ho un RAID e pasto a rismontarlo... Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted October 31, 2020 Moderators Share Posted October 31, 2020 lilu, weg, e non dimenticare flag npci=0x2000 e cavo hdmi 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 a lettura da Disco è molto lenta, swappa un casino: - Sono sulla porta SATA... 1 Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted October 31, 2020 Moderators Share Posted October 31, 2020 bè quanta riguarda la scheda è riconosciuta😀 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Le porte USB posteriori non me le vede, ma questo lo vediamo poi... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 La video alla prima con la EFI dell'altra volta, non ho toccato nulla... Ora che faccio Mojave o Catalina direttamente..? Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted October 31, 2020 Moderators Share Posted October 31, 2020 yesse Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 OK passo il Disco all'aggiornamento... @Gengik84, gurdami la EFI è postata all'inizio, quando puoi, anche tra un ora :)... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Ora ho un impedimento, dopo provo la 10.15.7... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 cosa dovrei guardare? per le usb? prova a mettere il rename EHCx to EH0x 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 La video non ha problemi nemmeno sulla 10.15, le USB ora mancano proprio, altra stranezza, il disco come arriva nel Desktop rallenta paurosamente, se poi lo riformatto in Windows mantiene quella bassa velocità circa 1/4, devo rinizializzarlo più volte con un format particolare per riavere la velocità originale, l'avevo già visto fare in passato su hardware più vecchio... Potrebbe essere anche la "Tipologia" di Disco, cmq... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 31, 2020 Supervisor Share Posted October 31, 2020 ma sei sicuro che non ti sta facendo l'indicizzazione? qui me ne accorgo anche io su NVME... 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 NO no, quando torno su Windows il Disco quasi nn si scrive, fidati... C'è un motivo per cui va ad 1/4 della velocità, ma anche meno... 43 minutes ago, Gengik84 said: cosa dovrei guardare? per le usb? prova a mettere il rename EHCx to EH0x Non la vedo c'è una preimpostazione... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 1 minuto fa, netgear ha scritto: Non la vedo c'è una preimpostazione... No devi mettere la patch tu in acpi/patch 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Cmq ora sulla 10.15 mi da schermo nero al secondo riavvio... L'attivazione video cmq era presente... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 La 10.14 in HFS+ va come la 10.13... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 1 hour ago, Gengik84 said: No devi mettere la patch tu in acpi/patch Non la trovo in giro... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 31, 2020 Author Moderators Share Posted October 31, 2020 Ora sono sulla 10.14 dove la video sembra andare bene, poi vedo a EFI sistemata il problema della lentezza Disco, ma l'avevo avuta anche con il Lenovo Haswell... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 31, 2020 Administrators Share Posted October 31, 2020 cosa la patch? dai su la trovi anche nel menù a tendina di clover configurator sono due ehc1 to eh01 ehc2 to eh02 comunque prova prima basic e fai ioreg anche 1 Link to comment Share on other sites More sharing options...
