Moderators netgear Posted October 25, 2020 Moderators Share Posted October 25, 2020 Non ho mai installato OS X su questo Muletto (i5 3550), forse, vista la video, compatibile solo con la 10.13, siamo inoltre (Ivy Bridge) fuori per gli SSDT by @Gengik84. C'è inoltre su un RAID hardware con Windows 10, non so se OS X lo vede di Default..? - Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 25, 2020 Author Moderators Share Posted October 25, 2020 Ho buttato giù una EFI al volo, OC... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 25, 2020 Administrators Share Posted October 25, 2020 puoi comunque provare Basic anche se i test sono stati effettuati con certezze da haswell in poi 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 25, 2020 Author Moderators Share Posted October 25, 2020 Prima provo senza SSDT, il RAID lo vede..?, Che uso 10.13.6 o superiore..? dai un occhiata alla EFI se c'è qualche svarione... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 25, 2020 Administrators Share Posted October 25, 2020 raid hardware no non sono al pc adesso quindi non posso guardare... in caso dopo nel pomeriggio intanto prova 😉 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 25, 2020 Author Moderators Share Posted October 25, 2020 Ah il RAID della scheda Madre non lo vede..? 10.13 10.14 10.15..? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 25, 2020 Administrators Share Posted October 25, 2020 quella video non credo vada molto bene dopo 10.13 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 25, 2020 Author Moderators Share Posted October 25, 2020 10.13 vediamo, se mi vede un disco aggiunto per non disfare il RAID... Ora finisco di pulire il Bagno l'ingresso e la Camera e poi vedo di fare una prova forse... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 25, 2020 Author Moderators Share Posted October 25, 2020 Progetto abbandonato, la video non va, schermo nero... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 25, 2020 Supervisor Share Posted October 25, 2020 su tutti i connettori? o e' proprio rotta? 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 25, 2020 Author Moderators Share Posted October 25, 2020 No che rotta, non va come configurazione, è un ATI... Capo Verde o qualcosa del genere... 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 Ho una HD 5770, più vecchia ma non mi ricordo se supporta la 10.13..? Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 26, 2020 Administrators Share Posted October 26, 2020 era un video nativa, sinceramente non ricordo se era tutto ok sempre su 10.13 rimane solo che provare 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 Mi sa che i problemi iniziavano proprio con la 10.13 che si doveva usare quel programma per cambiare qualcosa, altrimenti i colori erano sballati... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 -raddvi Questa Opzione non l'ho provata sulla DVI per la 7770... Usato radpg=15 Anche il FakeID sembra da usare su questo modello... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 agdpmod=vit9696 Disables board-id check, may be needed for when screen turns black after finishing booting Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 Nada, Schermo Nero... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 Forse dovrei Flashare la Video con un altro Firmware..? 1 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 26, 2020 Administrators Share Posted October 26, 2020 dovresti flashare per uefi GOP e poi avviare in uefi puro 2 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 eh si e dove trovo il Firmware il programma per Flasharlo... Nulla nemmeno Vesa, niente di niente, solo e sempre schermo nero... Alla faccia delle ATI, cavolo 10.13 scheda compatibile, nemmeno a martellate va 😁... Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 26, 2020 Administrators Share Posted October 26, 2020 mai è stata compatibile la 7770... per via del chipset sempre rognosa riguardo al flash, posso guardare se ho qualcosa, di vecchia data quando flashai la 7970 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 Eh si una rogna, ho visto, no lascia fare era solo per baloccarsi :)... 1 Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted October 26, 2020 Moderators Share Posted October 26, 2020 Il 25/10/2020 at 18:26, netgear ha scritto: No che rotta, non va come configurazione, è un ATI... Capo Verde o qualcosa del genere... dovresti impostare FrameB, prova Id 0x683f1002 Cape Verde, 0x68101002 Futomaki o Curacao imposta Port2, Con OC non so, la flag npci=0x2000 provala, cerano anche dei kext 7000controller da cambiare e 4000 Oppure prova id della 7970 o la r9 270/380 2 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 26, 2020 Author Moderators Share Posted October 26, 2020 Si sono su Open Core Carlo, Clover abbandonato Definitivamente, su OC non ho capito dove mettere il Fake, i Framebuffer non saprei come funzionano su OC o etciù :)... Ultima mia EFI, dove non mi prende il Kext della Atheros, errore info.plist, ok vediamo con calma, parliamo sempre della 10.13 o si va anche più avanti..? - EFI.ZIP Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 27, 2020 Administrators Share Posted October 27, 2020 .kext non .kex 1 Link to comment Share on other sites More sharing options...
