emiliano Posted September 20, 2020 Share Posted September 20, 2020 Buondì a tutti e buona domenica. Mi potete indicare una guida per patch grafica. Vorrei duplicare schermo laptop in firma tramite hdmi. Grazie Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 20, 2020 Support Team Share Posted September 20, 2020 ❇️. https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md Link to comment Share on other sites More sharing options...
emiliano Posted September 20, 2020 Author Share Posted September 20, 2020 Grazie @iCanaro. Posso disturbare se ho problemi? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 20, 2020 Support Team Share Posted September 20, 2020 se ho tempo e se ho la risposta... si PS: altra cose che meglio studi, i boot-arg https://github.com/acidanthera/WhateverGreen 1 Link to comment Share on other sites More sharing options...
emiliano Posted September 20, 2020 Author Share Posted September 20, 2020 @iCanaro come mai una patch con Clover che mi fa funzionare hdmi non va bene per oc? Da qui nasce il bisogno di rifare patch . Grazie mille Inoltre patch grafica e abilitare connettori sono due cose diverse @iCanaro ? Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 20, 2020 Support Team Share Posted September 20, 2020 risposta certa non ho, magari dipende dal modo di iniettare i kext e framebuffer.. di solito è più efficiente OC provato ad aggiungere boot-arg igfxonln=1 1 Link to comment Share on other sites More sharing options...
emiliano Posted September 20, 2020 Author Share Posted September 20, 2020 @iCanaro provo Link to comment Share on other sites More sharing options...
emiliano Posted September 20, 2020 Author Share Posted September 20, 2020 @iCanaro boot arg già è impostato. C’è differenza tra patch grafica e mappatura connettori ? Grazie Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 20, 2020 Support Team Share Posted September 20, 2020 detta alla buona, in pratica il corretto framebuffer attiva la grafica, ma questa va poi incanalata nei giusti connettori (cioè uscite video fisiche) qui son tutti concetti e tecniche che per chi non è del settore, ovvero un dev, un programmatore, è tutta roba ostica... io per iniziare a capirci un minimo, ci ho messo 1 anno a smanettare nei miei sistemi e preparare efi altrui. 1 Link to comment Share on other sites More sharing options...
emiliano Posted September 20, 2020 Author Share Posted September 20, 2020 Arabo per me. Tento. Ma non sono del mestiere, speriamo. Grazie ancora @iCanaro intanto con Clover (definita dopo varii problemi da @Gengik84 ) va. con OC non ne vuole sapere Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 20, 2020 Support Team Share Posted September 20, 2020 @emiliano prova... con un plist editor dovrai inserire/sostituire i 3 plist con i soli framebuffer Archivio.zip Link to comment Share on other sites More sharing options...
emiliano Posted September 21, 2020 Author Share Posted September 21, 2020 buona sera @iCanaro. scusami se ci ho messo quasi una giornata per provare. risultato è che con il primo ho avuto schermo nero mentre con gli atri due sono arrivato a scrivania ma senza ottenere il risultato ricercato e cioè duplicazione schermo. ho tralasciato una cosa. nel passaggio da clover a oc è stato creato un solo ssdt per la efi oc mentre nella clover in acpi si trovano un dsdt ed un ssdt. ti allego le due efi per renderti la cosa piu comprensibile. grazie ancora per il tempo che mi dedichi. EFI OC vivobook.zip CLOVER macbook pro 2018.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 21, 2020 Support Team Share Posted September 21, 2020 se sono la medesima macchina, stai usando SMBIOS differenti; il che potrebbe essere determinante.... magari se usi con OC lo stesso che stai usando con Clover 🤭 1 Link to comment Share on other sites More sharing options...
emiliano Posted September 21, 2020 Author Share Posted September 21, 2020 @iCanaro andata. Avevo cambiato smbios perché i3 8130u e in sostanza un processore di settima e quindi volevo facendo una efi oc rispettare questo parametro. Però il pallino lo tenevo sempre. Il confronto è importante. Grazie mille di tutto. Non so come ringraziarti Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 21, 2020 Support Team Share Posted September 21, 2020 9 minuti fa, emiliano ha scritto: Però il pallino lo tenevo sempre e pallino era d'accordo? 😁 quando io o gengik diciamo di trasbordare la propria configurazione funzionante con Clover, su OC... quale è la parte che non risulta chiara??? spero ti renderai conto che ci sei stato dietro a questa cosa per un bel po', e il problema principe è risultato sempre il solito.... quello tra sedia e tastiera 1 Link to comment Share on other sites More sharing options...
emiliano Posted September 21, 2020 Author Share Posted September 21, 2020 @iCanaro quello che dite tu e @Gengik84 è sempre tutto chiaro. Hai perfettamente ragione. il problema è sempre il solito. quello che c'è tra sedia e tastiera. 🤦♂️ Mea culpa. GRAZIEEEEE 1 Link to comment Share on other sites More sharing options...
