Support Team iCanaro Posted September 11, 2020 Support Team Share Posted September 11, 2020 @Nikino sostituisci config, ti ho modificato in drop tables da tablet a lengt in merito alle USB config.plist.zip Link to comment Share on other sites More sharing options...
Nikino Posted September 12, 2020 Author Share Posted September 12, 2020 Ok grazie Link to comment Share on other sites More sharing options...
Nikino Posted September 12, 2020 Author Share Posted September 12, 2020 Buongiorno, ho fatto tutto ma si pianta lo stesso all’avvio Link to comment Share on other sites More sharing options...
Nikino Posted September 12, 2020 Author Share Posted September 12, 2020 dopo 4 riavvii è partito Sembra esserci un problema legato a fakesmc e nvram Link to comment Share on other sites More sharing options...
Nikino Posted September 12, 2020 Author Share Posted September 12, 2020 Adesso si è anche riavviato da solo e ha dato il messaggio di riavvio per kernel panic Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 12, 2020 Support Team Share Posted September 12, 2020 aggiungi questo kext in EFI https://github.com/acidanthera/NVMeFix/releases/download/1.0.3/NVMeFix-1.0.3-RELEASE.zip @Nikino Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 12, 2020 Support Team Share Posted September 12, 2020 11 minuti fa, Nikino ha scritto: Adesso si è anche riavviato da solo e ha dato il messaggio di riavvio per kernel panic e salva report in txt del KP Link to comment Share on other sites More sharing options...
Nikino Posted September 12, 2020 Author Share Posted September 12, 2020 (edited) Scusami ma come si fa? Si avvia solo dopo vari tentativi Edited September 12, 2020 by Nikino Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 12, 2020 Support Team Share Posted September 12, 2020 @Nikino sostituisci EFI ti ho compilato tutti i kexts ora e sostituito FakeSMC con VirtualSMC EFI 3.zip Link to comment Share on other sites More sharing options...
Nikino Posted September 12, 2020 Author Share Posted September 12, 2020 Ok proverò dopo. Grazie mille Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Ciao. Ho provato. Adesso va un po’ avanti nel post ma si blocca qua Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Ho provato più volte e si blocca sempre allo stesso punto Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Prima del post escono le++++++ per pochi secondi. parte e si blocca qua Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 a me fa specie che non ti si avvii ne con SSDT-Basic, non va con tuo DSDT.... non è che hai una mobo strana, semplice Z370 seppur gigio... boh controlla che il setup del BIOS sia a posto Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 ti preparo EFI con ssdt x hack poi vediamo Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 @Nikino altro test EFI 4.zip Link to comment Share on other sites More sharing options...
Moderators netgear Posted September 14, 2020 Moderators Share Posted September 14, 2020 On 9/11/2020 at 4:07 PM, Nikino said: Ma la mia novo non è uguale alla tua? Mobo Ah no..? Mi pareva la stessa, io ho questa BIOS F14: - http://it.gigabyte.com/products/page/mb/z370_aorus_gaming_5rev_10#kf Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Ho aggiornato a F14 il bios, fatte le impostazioni come nella guisa apposita e all’avvio con la efi7 si blocca qua Anche con efi4 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 1 minuto fa, Nikino ha scritto: all’avvio con la efi7 si blocca qua quale EFI7 prova EFI 4 ultima postata e le altre precedenti Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Provata l’ultima Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 a me pare impossibile che con nessuna EFI tu vada... vediamo se @netgear ti passa la sua e se questa ce la fa Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 5 ore fa, iCanaro ha scritto: questa è la efi della chiavetta di emergenza che avvia regolarmente, se può essere d'aiuto. EFI.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted September 14, 2020 Support Team Share Posted September 14, 2020 un bel mistero che avvi con quel casotto di EFI, ma almeno qualcosa con cui parte ci stà dal mio punto di vista, si tratta solo di trovare quale ssdt funzioni a modo da te... diciamo che sarebbe anche facile fare le prove, ma ti passo efi completa con ssdt diversi e riproviamo il basic @Nikino test in caso non avvii, prova a copiare in questa EFI, BOOTX64.efi e CLOVERX64.efi della tua con cui avvii EFI 5.zip Link to comment Share on other sites More sharing options...
Nikino Posted September 14, 2020 Author Share Posted September 14, 2020 Questa arriva qua Link to comment Share on other sites More sharing options...
