On AM5, security updates in BIOS also brought some breaking changes in DSDT; maybe similar issues are at play here?
Have you tried to compare ACPI tables from the older and nwer BIOS, or re-checked memory whitelisting?
3 hours ago, fabiosun said:
a simple video could help to understand if it is an ACPI problem as AM5 users have
i do not think it is the same ..but with a video it is possible to understand better
@fabiosun video of the reboot?
@subbanator
a bios is version F6
Disable all kexts except Lilu.kext, Smc.kext, AppleMcereporterdisable and retry the installation after checking the points below.
Have you entered your values in the MmiolWhiteList?
Do you have the correct number of CPU cores in the first two patches?
Are you using Thunderbolt card if not deleted SSDT-DTGP.aml and SSDT-TBOLT3-NVM23.aml in ACPI folder.
ResizeAppleGpuBars is enabled in config. plist, have you activated this in the bios?
Is the bios configured correctly?
By the way, what is your graphics card?
Just installed it
OK will do it
Im still trying to wrap my head around this.  I see that you have 15 items in t your list but I cannot figure how to do that specific part.
Yes.  I changed it to the 3790x
Will remove them for now.  I have a Thunderbolt card but it's not in the computer
Yes but I will double check
6800xt.
BTW thanks alot for your help
Its REALLY appreciated!
Edited by subbanator
On 9/13/2024 at 3:08 PM, Arrakis said:
@Jaidy
Yes, it works for wifi and Bluetooth.
Download my EFI here
There are the following kexts:
AirportItlwm, BlueToolFixup, IntelBluetoothFirmware, IntelBTPatcher.
Previously I needed to disable BTPatcher kext in config.plist and add revpatch=sbvmm in boot arguments to make the upgrade appear in the Software Updates section of System Settings. After applying changes to my config.plist using your EFI, the update is appearing without these two changes. Can you please confirm you don’t need to to do these either and you can upgrade your system from within Software Updates section section of System Settings?
  • 2 months later...
Is anyone here facing trouble with macOS updates? I’m trying to update my system to 15.1.1. It downloads the update, and while preparing, the system just hangs and needs a cold boot. I have tried four times already
Edited by Jaidy
  • 5 weeks later...
