Supervisor fabiosun Posted Friday at 04:41 PM Author Supervisor Share Posted Friday at 04:41 PM @Ploddles@Arrakis https://github.com/acidanthera/Lilu/actions in the action..this is only for lilu also for others like weg and virtualsmc you must update 🙂  Archive 2.zipi use these  Link to comment Share on other sites More sharing options...
Arrakis Posted Friday at 06:50 PM Share Posted Friday at 06:50 PM @fabiosun I tried with your kexts and it's identical. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted Friday at 07:33 PM Author Supervisor Share Posted Friday at 07:33 PM Try to disable all kexts you can and use only a minimal combination of them  i use the same EFI with Sonoma and sequoia using min and max kernel option for kexts Link to comment Share on other sites More sharing options...
Ploddles Posted Friday at 09:07 PM Share Posted Friday at 09:07 PM Mine is now installed. The main problem was I had accidentally not increased one of the max settings in the patch list.  However it is very unstable even after updating Lilu. I couldn’t find updated versions of WEG or Virtualsmc. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted Saturday at 04:31 AM Author Supervisor Share Posted Saturday at 04:31 AM @Ploddlesyou can find kexts  i use  in a my previous post have you also updated leaf and fix pat kernel patches? Link to comment Share on other sites More sharing options...
Arrakis Posted Sunday at 06:20 AM Share Posted Sunday at 06:20 AM @fabiosunI did the test with the minimum of kext (Lilu.kext, Smc.kext, AppleMcereporterdisable.kext). All other kexts disabled. I'm doing a clean install and I still have the same problem. After creating the user account. The session created never manages to open. I do an installation test on a classic hard drive plugged into a USB dock, it's the same result. Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted Sunday at 07:11 AM Author Supervisor Share Posted Sunday at 07:11 AM Try to use also fix pat (I know it was not usefull for trx40) it is a desperate test🥹 Link to comment Share on other sites More sharing options...
Arrakis Posted Sunday at 02:18 PM Share Posted Sunday at 02:18 PM @fabiosun I tried with the new fix pat, it's identical. For information, in the notes of the new patches for Sequoia, it is indicated that it is not necessary for TRX40. I tried to update from Sonoma 14.5, same result. Attached my config plist and the log. TRx40 arrakis Sequoia.zip Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted Sunday at 03:04 PM Author Supervisor Share Posted Sunday at 03:04 PM @Arrakissystem output some info in a next boot on a valid system? could you try to flag this? I do not remember if also for trx40 it was useful to avoid some weirdness Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted Sunday at 03:10 PM Author Supervisor Share Posted Sunday at 03:10 PM @Arrakisin your "old" EFI in OP you have the dummy enabled....i dont think your problem is for this but it could be worth to try  Link to comment Share on other sites More sharing options...
Arrakis Posted Sunday at 03:54 PM Share Posted Sunday at 03:54 PM (edited) @fabiosun Yes, on my config it was mandatory until Ventura, otherwise Opencore would not load completely. Currently in Sonoma, it may be disabled. I tried activated and it's the same. Edited Sunday at 03:55 PM by Arrakis Link to comment Share on other sites More sharing options...
Posted by fabiosun,
Recommended by fabiosun
2 reactions
Go to this post
