Administrators Gengik84 Posted July 19, 2020 Administrators Share Posted July 19, 2020 config.plist.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 19, 2020 Author Share Posted July 19, 2020 è normale che il campo ig-platform-id lo vedo vuoto? nel config? c'è da specificare che io sono con Catalina 10.15.2 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 19, 2020 Administrators Share Posted July 19, 2020 si ti ho messo vesa... se hai avviato prova adesso a rimuovere dalle boot-arg -igfxvesa Link to comment Share on other sites More sharing options...
Roberto Posted July 19, 2020 Author Share Posted July 19, 2020 purtroppo non parte Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 19, 2020 Administrators Share Posted July 19, 2020 allora ti servono patch al framebuffer Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 19, 2020 Administrators Share Posted July 19, 2020 prova config.plist 2.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 19, 2020 Support Team Share Posted July 19, 2020 @Roberto divertiti Archivio.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 20, 2020 Author Share Posted July 20, 2020 (edited) Grazie, tra poco provo 🙂 Edited July 20, 2020 by Roberto Link to comment Share on other sites More sharing options...
Roberto Posted July 20, 2020 Author Share Posted July 20, 2020 Eccomi, allora ho appena provato il primo config di Gengik, e all'avvio mi da schermo nero. Provato con il comando dart=0 ma non ho risolto Link to comment Share on other sites More sharing options...
Roberto Posted July 20, 2020 Author Share Posted July 20, 2020 invece nell'archivio di iCanaro: 1) schermo nero 2) si avvia, ma rimane bloccato alla mela 3) schermo nero Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 21, 2020 Support Team Share Posted July 21, 2020 @Roberto prova, ma oltre al config, aggiungi anche questo kext https://www.macos86.it/topic/3062-cputscsync/ config-4.plist.zip 1 Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Adesso si è avviato correttamente e la intel HD viene riconosciuta correttamente 1 Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Allego ioreg e DSDT.dls per eventuale compilazione del DSDT. Ho messo il kext della batteria, si carica, ma non vedo l'indicatore della batteria. Per il trackpad il link del mouse sono sfalsati, forse devo usare un altro driver più appropriato Archivio.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Per quanto riguarda l'audio invece, ho provato tutti i loyout ma non sono riuscito a trovare quello corretto... nel senso che nessuno di quelli che ho provato è andato... Realtek ALC256/ALC3246 layout 5, 11, 13, 14, 21, 22, 28, 56, 57, 66, 97 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 21, 2020 Support Team Share Posted July 21, 2020 inseriscili da properties, clicca su audio in firma per come fare Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 48 minuti fa, Roberto ha scritto: Ho messo il kext della batteria quale kext? Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 quello che danno insieme al VirtualSMC Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 quello che danno insieme al VirtualSMC 16 minutes ago, iCanaro said: inseriscili da properties, clicca su audio in firma per come fare inserendo il layout 28 mi esce l'audio con le uscite altoparlanti interni e auricolari, ma non sento l'audio Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 strano, quasi doveva funzionare senza nulla. Prova, sostituisci se è tutto ok al boot, fai ioreg Archivio.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 La cosa divertente e che avendo spento e riacceso il Mac l'audio a adesso va hahahaha ioreg con dsdt di gengik MacBook Pro di Roberto.zip Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 Per caso c'è la possibilità di far andare l'impronta digitale? mini rimane da sistemare solo la luminosità del pannello, cambiare driver i2c e forse basta, il lettore SD dovrebbe andare con un kext che adesso non ricordo come si chiama Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted July 21, 2020 Support Team Share Posted July 21, 2020 Adesso, Roberto ha scritto: Per caso c'è la possibilità di far andare l'impronta digitale? mmmmm non credo, meglio forse inserisci il kext NoTouchId 1 minuto fa, Roberto ha scritto: l lettore SD dovrebbe andare con un kext che adesso non ricordo come si chiama SinetekRTSX Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 sostituisci prima mi ero dimenticato di dirlo, rimuovi ssdt-basic rifai ioreg DSDT.aml.zip 1 Link to comment Share on other sites More sharing options...
Roberto Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) 19 minutes ago, Gengik84 said: sostituisci prima mi ero dimenticato di dirlo, rimuovi ssdt-basic rifai ioreg DSDT.aml.zip 51.46 kB · 0 downloads L'avevo tolto sai? immaginavo che si dovesse togliere... provo comunque? Edited July 21, 2020 by Roberto Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted July 21, 2020 Administrators Share Posted July 21, 2020 si hai fatto bene a toglierlo 1 Link to comment Share on other sites More sharing options...
