Administrators Gengik84 Posted October 14, 2020 Author Administrators Share Posted October 14, 2020 quanti GB ti dava? 3 oppure 12? 1 Link to comment Share on other sites More sharing options...
tuxy Posted October 14, 2020 Share Posted October 14, 2020 Just now, Gengik84 said: quanti GB ti dava? 3 oppure 12? 3,84 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 14, 2020 Author Administrators Share Posted October 14, 2020 Ecco ok... a qualcuno da 12gb 1 Link to comment Share on other sites More sharing options...
tuxy Posted October 14, 2020 Share Posted October 14, 2020 2 minutes ago, Gengik84 said: Ecco ok... a qualcuno da 12gb In questo momento ho avuto il primo KP del mio Hack da quando ho installato Big Sur. Mai successo prima. Speriamo non sia una beta cazzara. La 9 viaggiava bene.... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 14, 2020 Supervisor Share Posted October 14, 2020 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 14, 2020 Author Administrators Share Posted October 14, 2020 2 minuti fa, tuxy ha scritto: In questo momento ho avuto il primo KP del mio Hack da quando ho installato Big Sur. Mai successo prima. Speriamo non sia una beta cazzara. La 9 viaggiava bene.... eheheheh per ora siamo sempre più su Bug Sur che Big Sur 😄 1 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 15, 2020 Moderators Share Posted October 15, 2020 LA 10 :)... Solo 4 Gb di aggiornamento, come BUG va peggio della 9..?, ma hanno fatto una nuova iso anche..? Quella piccolina di appena 12 Gb 😁... Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted October 15, 2020 Supervisor Share Posted October 15, 2020 Secondo me la 11 sará quella buona fanno scopa con il nome e via male che vada invece ne mancano 6😂 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted October 15, 2020 Support Team Share Posted October 15, 2020 19 ore fa, tuxy ha scritto: Di norma aggiorno appena , possibile , sto scaricando infatti , ma iCanaro mi precede....Nessuna paura 🙂 ho fatto la finta 😈 visto che prima propongono 12Gb, poi si ravvedono e cambiano a 3.8Gb sai che ti dico... aspettiamo 😁 19 ore fa, A23SS4NDRO ha scritto: 19 ore fa, iCanaro ha scritto: nuovo Clover Il nuovo OCLover intendi forse tu intanto pigia il tasto funzione per avviare windows lo sai che la prima beta di OClover senza lover avviava qualsiasi windows senza problemi?! e non solo quella.... ma forse era un BUg come BUg Fart Link to comment Share on other sites More sharing options...
Agostino94 Posted October 15, 2020 Share Posted October 15, 2020 22 hours ago, Gengik84 said: Ecco ok... a qualcuno da 12gb io faccio parte del programma di public beta e mi da 12gb...bisogna che scarico tutti e 12 oppure vi è una soluzione? Link to comment Share on other sites More sharing options...
T19 Posted October 15, 2020 Share Posted October 15, 2020 ed anche questo decimo suppostone è andato😁 Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted October 15, 2020 Support Team Share Posted October 15, 2020 10 minuti fa, Agostino94 ha scritto: io faccio parte del programma di public beta e mi da 12gb...bisogna che scarico tutti e 12 oppure vi è una soluzione? bella domanda... tu inizia a scaricare, poi magari si interrompe e invece di 12Gb poi te ne propone 3.8GB Link to comment Share on other sites More sharing options...
Agostino94 Posted October 15, 2020 Share Posted October 15, 2020 vorrei anche scaricarlo ma è di una lentezza allucinante Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 L'installer della 10 non si avvia in Italiano, schermata grigia, quello della 9 andava bene, in Inglese si avvia... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 Fisicamente con la EFI OC della b9 va in KP, ma non ho visto il motivo... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 LA Recovery invece si avvia ma con il settaggio di OC indirizzato in italiano, schermata grigia a conferma... Link to comment Share on other sites More sharing options...
AlexAMD Posted October 16, 2020 Share Posted October 16, 2020 (edited) Sono riuscito ad aggiornare anche io con Clover 5124 ultimo postato da @iCanaro, su Asus in firma .... ha scaricato 12 gb .... Edited October 16, 2020 by AlexAMD Link to comment Share on other sites More sharing options...
AlexAMD Posted October 16, 2020 Share Posted October 16, 2020 Ciao a tutti, voi riuscite ad avviare con OC quest'ultima beta di BS??? dopo aver aggiornato tramite clover ho voluto riprovare OC su Huawei sia 0.6.1 che la 0.6.2 ma ora vanno in KP e nel menù del boot vedo che ancora c'è un installer BigSur .... Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 Io ho provato Clover v5125 e OC 0.6.2, la b9 si avvia la b10 non si avvia, KP e riavvio, ma non ho visto la causa, le installazioni sono fatte entrambi dall'installer... Il fatto che cmq non si riesca a partire in Italiano rispetto alla b9 è strano, e cmq la Recovery che invece si avvia la devi avviare in inglese... Link to comment Share on other sites More sharing options...
AlexAMD Posted October 16, 2020 Share Posted October 16, 2020 Quindi per OpenCore dovremo aspettare la prossima .... anche io non vedo la causa del KP .... grazie Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 Basta vedere che origine ha il KP e avere altri riscontri... Ora ho delle cose nel mezzo, dopo verifico... Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted October 16, 2020 Support Team Share Posted October 16, 2020 SecureBoot --> Disabled con OC Con Clover 5124/5125 nella GUI pigiare F3 ed avviare/installare da preboot SIP 0x67 o 0x01 1 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 Accidenti volevo riprovare ma ho cancellato tutto 😄, che mania di mettere subito ordine... Vabbè alle fini non mi sembrava una grande Release, non si partiva nemmeno in Italiano :)... Link to comment Share on other sites More sharing options...
AlexAMD Posted October 16, 2020 Share Posted October 16, 2020 Il securboot si trova in Misc-> security-> securbootmodel??? questo è il KP con OC062 Link to comment Share on other sites More sharing options...
Moderators netgear Posted October 16, 2020 Moderators Share Posted October 16, 2020 SI devi modificare, infatti quelli che hanno Disabled avviano 🙂 <key>SecureBootModel</key> <string>Disabled</string> Link to comment Share on other sites More sharing options...
