Supervisor fabiosun Posted June 4, 2022 Supervisor Share Posted June 4, 2022 @SemanticAal centro metterei quella che ora hai a destra (di chi guarda) Link to comment Share on other sites More sharing options...
SemanticA Posted June 4, 2022 Author Share Posted June 4, 2022 1 ora fa, Ramirez71 ha scritto: Ciao immagino si riferisca all temp della gpu? No no proprio in generale... per quella, ho rimosso il no-fan-mode e mi ha abbassato di circa 10/12 gradi 😄 ventole che girano sempre ma non le senti minimamente! 😄 1 ora fa, fabiosun ha scritto: @SemanticAal centro metterei quella che ora hai a destra (di chi guarda) quindi così? Purple1 - Frankenstrat - Clapton Daphne e poi sotto BlackStrat Gilmour e Fiesta Red Knopfler ..oooook! 😄 Link to comment Share on other sites More sharing options...
Supervisor fabiosun Posted June 4, 2022 Supervisor Share Posted June 4, 2022 si e visto che hai un "occhio" grafico capisci il perche' 🙂 Nero Perla Nero oro oro 1 Link to comment Share on other sites More sharing options...
SemanticA Posted June 4, 2022 Author Share Posted June 4, 2022 ok mi resta da capire come correggere questi errori di nvram e son a posto 😄 05:707 00:001 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82 05:709 00:001 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E 05:711 00:001 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82 05:713 00:001 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E 05:715 00:002 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82 05:717 00:002 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82 05:719 00:002 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82 05:721 00:002 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82 Link to comment Share on other sites More sharing options...
Ramirez71 Posted June 4, 2022 Share Posted June 4, 2022 Perdona la incompetenza, mi chiedevo da dove vedi questi errori, sono dei file log? ci sono sempre stati? Adesso passiamo all'opera del Duomo ossia la parete fender: ottimo il discorso dei manici ma se si cerca una simmetria/composizione dei colori allora bisogna tenere di conto anche della cassa, ora degradano dai toni scuri ai chiari e può essere ottimo ma proverei anche altezze diverse. Link to comment Share on other sites More sharing options...
SemanticA Posted June 4, 2022 Author Share Posted June 4, 2022 (edited) Allora quelli son nel log di opencore debug... probabilmente ci son sempre stati e non me ne sono mai accorta....... eh discorso chitarre...purtroppo la parete c'è già con i supporti così e con sfondo colore uguale alla foto (burgundy) xD non ho spazio per rifarne un'altra con altezze diverse... quella con le altezze diverse è l'altra parete con Charvel; Jackson; Warlock; ESP messe inclinate xD LoL comunque, quella "Purple" è una Sunburst da Nero a Viola con i glitter 😍 Edited June 4, 2022 by SemanticA 1 Link to comment Share on other sites More sharing options...
Ramirez71 Posted June 4, 2022 Share Posted June 4, 2022 OK apri qui poi vado a cena 1193453214_paretechitarre1.thumb.jpg.98215dc1af510245d00dda94b3cd0951.psd.zip Link to comment Share on other sites More sharing options...
SemanticA Posted June 4, 2022 Author Share Posted June 4, 2022 36 minuti fa, Ramirez71 ha scritto: OK apri qui poi vado a cena 1193453214_paretechitarre1.thumb.jpg.98215dc1af510245d00dda94b3cd0951.psd.zip 431 kB · 1 download Si ma il problema è che ho i supporti delle chitarre già fissati al muro in quella posizione, e non posso spostarli perchè non ho più la vernice per poi poter coprire il bianco dello stucco e sta male 😄 🙂 però stavano bene anche così, vero! 😄 Link to comment Share on other sites More sharing options...
Ramirez71 Posted June 4, 2022 Share Posted June 4, 2022 3 ore fa, SemanticA ha scritto: Si ma il problema è che ho i supporti delle chitarre già fissati al muro in quella posizione Ma si lo sai che mi piace fare lo scassacaxxxxx😀😀😀😀😀 A me piacerebbe fare una parete con le bici da corsa ma poi mi toccherebbe mettere una tenda in strada: non ho pareti libere😭😭😭😭😭 Link to comment Share on other sites More sharing options...
SemanticA Posted June 12, 2022 Author Share Posted June 12, 2022 (edited) Per chi volesse provare Ventura con SMBIOS iMac19,1: EFI.zip -per tutti- impostare i vostri dati serial mlb rom smuuid e attivate la iGPU nel bios. -per NAVI- aggiungere agdpmod=pikera ai boot-arg e attivare i due kext dei sensori in foto si può fare aggiornamento diretto, installare da install.app (dalla cartella applicazioni una volta scaricato l'installer completo da 12gb), installazione pulita da USB Edited June 12, 2022 by SemanticA 1 Link to comment Share on other sites More sharing options...
rainbowflare Posted June 13, 2022 Share Posted June 13, 2022 21 ore fa, SemanticA ha scritto: Per chi volesse provare Ventura con SMBIOS iMac19,1: EFI.zip 4 MB · 2 download -per tutti- impostare i vostri dati serial mlb rom smuuid e attivate la iGPU nel bios. -per NAVI- aggiungere agdpmod=pikera ai boot-arg e attivare i due kext dei sensori in foto si può fare aggiornamento diretto, installare da install.app (dalla cartella applicazioni una volta scaricato l'installer completo da 12gb), installazione pulita da USB Già usare Hakintosh come sistema pricipale è un azzardo 😅 Addirittura metterci su la prima beta è folle, 😂 mi sembra di essere tornato indietro di 30 anni qundo sul 286 con 2Mb di RAM volevo farci girare il primo Windows 🤪 Sei mitica 🤩 1 Link to comment Share on other sites More sharing options...
SemanticA Posted June 13, 2022 Author Share Posted June 13, 2022 Ahahahah ma era solo una prova... Comunque con quella EFI parte e è stabile...ma ora mi sto incazzando perché non funziona il smbios MacPro7. 1 🤬🤬🤬🤬 Link to comment Share on other sites More sharing options...
rainbowflare Posted June 30, 2022 Share Posted June 30, 2022 Buona sera a tutti, ultimamente con il lavoro non riesco a stare più dietro a nulla (per fortuna dovrei dire ma il fisico comincia a cedere 😅) a voi come va l'A-Ventura? io sono su Montery con OC 8.0 e per ora mi godo la stabilità con smbios MacPro7,1 by SemanticA 💪 P.S. @SemanticA Ma dove è finita la chitarrista metal nell'avatar?? c'ero affezionato, la S mi ha lasciato spaesato 🤣 Link to comment Share on other sites More sharing options...
katsuja Posted September 26, 2025 Share Posted September 26, 2025 (edited) Buonasera. Per chi è interessato allego EFI funzionante con macOS Tahoe 26 (MacPro7,1) Il Pc è quello in firma, uguale a quello di SemanticA. Per l'installazione usate "config-disableSIP.plist" e rinominatelo in "config.plist". Ultimata l'installazione, usate il config.plist che si trova nella mia EFI (non quello rinominato). Ho dovuto togliere la cartella Resources per questione di spazio per poterla caricare. La trovate nel primo post di SemanticA nella sua EFI. Inseritela in OC. Per WiFi Fenvi e audio bisogna attendere. Tutto il resto è perfettamente funzionante. Saluti. EFI.zip Edited September 26, 2025 by katsuja Link to comment Share on other sites More sharing options...
