chris1111 Posted March 10, 2018 Share Posted March 10, 2018 Super forum grazie a tutti emoticon_thanks Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted March 10, 2018 Support Team Share Posted March 10, 2018 Ciao zao e grazie alle tue utility carillon e tutte le altre Link to comment Share on other sites More sharing options...
chris1111 Posted March 10, 2018 Author Share Posted March 10, 2018 "iCanaro" post_id="1510" time="1520687700" user_id="57"> Ciao zao e grazie alle tue utility carillon e tutte le altre Grazie per il benvenuto emoticon_sorriso2 emoticon_41 Link to comment Share on other sites More sharing options...
Baio77 Posted March 10, 2018 Share Posted March 10, 2018 emoticons_welcome emoticons_welcome Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 10, 2018 Administrators Share Posted March 10, 2018 hallo emoticons_welcome Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted March 10, 2018 Moderators Share Posted March 10, 2018 emoticon_applausi2 Benvenuto Chris1111 Link to comment Share on other sites More sharing options...
marzillo Posted March 10, 2018 Share Posted March 10, 2018 hello criss emoticon_festa Link to comment Share on other sites More sharing options...
chris1111 Posted March 10, 2018 Author Share Posted March 10, 2018 Thank You emoticon_applausi Ti ho fatto un piccolo widget per il forum Il fronte è il link del Forum, il retro è il link per Argomenti Attivi Per tornare clicca su Ritorno Installare il widget e quindi fare clic su di esso per aprirlo in Dashboard Buon divertimento! Grazie alla tua comunità Grazie ha tutto ha Gengik84 Dimmi se vuoi che corregga qualcosa? https://i62.servimg.com/u/f62/18/50/18/69/12313.png' alt='12313.png'> https://i62.servimg.com/u/f62/18/50/18/69/123410.png' alt='123410.png'> English: I made you a small widget for the forum The front is the link of the Forum, the back is the link for Active Topics To return click on Retorno Install the widget and then click on it to open it in the Dashboard PS: Tell me if you want me to correct something? Good fun! Thanks to your community and Thanks to Gengik84 macOS86.wdgt.zip Link to comment Share on other sites More sharing options...
Support Team iCanaro Posted March 10, 2018 Support Team Share Posted March 10, 2018 emoticon_41 emoticon_41 emoticon_41 emoticon_thanks Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 10, 2018 Administrators Share Posted March 10, 2018 @chris1111[/mention] Adesso non sono a casa, rientro domani. Controllo e di faccio sapere con precisione emoticon_thanks Link to comment Share on other sites More sharing options...
kernele Posted March 10, 2018 Share Posted March 10, 2018 emoticon_thanks zao emoticon_urca Link to comment Share on other sites More sharing options...
chris1111 Posted March 12, 2018 Author Share Posted March 12, 2018 "Gengik84" post_id="1554" time="1520698148" user_id="2"> @chris1111 Adesso non sono a casa, rientro domani. Controllo e di faccio sapere con precisione emoticon_thanks Ciao Gengik84 questo è solo un semplice widget utile per accedere al forum senza dover mettere i link sul desktop o in altri luoghi. grazie per il tuo forum emoticon_sorriso2 Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 12, 2018 Administrators Share Posted March 12, 2018 L'ho aggiunto ieri sera é veramente molto comodo... emoticon_thanks Link to comment Share on other sites More sharing options...
chris1111 Posted March 12, 2018 Author Share Posted March 12, 2018 Thank You emoticon_thanks Le aspetto è carino Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted March 12, 2018 Administrators Share Posted March 12, 2018 "chris1111" post_id="1806" time="1520859288" user_id="109"> Thank You emoticon_thanks Le aspetto è carino L'ho uppato in download, riconoscendoti i giusti credits.. Link to comment Share on other sites More sharing options...
chris1111 Posted March 12, 2018 Author Share Posted March 12, 2018 Thank you emoticon_applausi È possibile che il widget sia fluttante e sovrapposto nel controllo della missione emoticon_winner https://i62.servimg.com/u/f62/18/50/18/69/captu377.png' alt='captu377.png'> https://i62.servimg.com/u/f62/18/50/18/69/sans_133.png' alt='sans_133.png'> Link to comment Share on other sites More sharing options...
