AppleALC
Release UFFICIALE
v1.3.0 https://github.com/acidanthera/AppleALC/releases">https://github.com/acidanthera/AppleALC/releases
Requires Lilu 1.2.5 and higher and enabled on 10.14 by default
Added digital audio property injection for AMD, Intel, NVIDIA
Added NVIDIA multi-gpu NVIDIA HDAU patch support
Added ALC269VC layout-id 30 for Hasee Z6SL7R3 by HF
v1.2.8 https://github.com/acidanthera/AppleALC/releases">https://github.com/acidanthera/AppleALC/releases
Added basic 10.14 compatibility via masking real layout-id
AppleALC selected layout-id is now shown as alc-layout-id in ioreg
Overriden layout-id can be passed asapple-layout-id (alcaaplid=X)
Added ALC298 layout-id 66 for MECHREVO S1 by lgs3137
Added ALC298 revision-id 0x100101 support
Added ALC892 layout-id 12 for MSI GP70/CR70 by Slava77
Added ALC257 layout-id 11 for Lenovo T480 by MacPeet
Added ALC294 layout-id 12 for Lenovo M710Q by MacPeet
Added ALC298 layout-id 30 for Xiaomi Mi Notebook Air 13.3 by Constanta
v1.2.7 https://github.com/vit9696/AppleALC/releases">https://github.com/vit9696/AppleALC/releases
Added NVIDIA HDMI patch for GP107 and GP108 for 10.13.4+
Added NVIDIA HDMI patch for GP104 for 10.13.4+
Added ALC898 layout-id 98 for MSI GE62 7RE Apache Pro by spectra
Added ALC1220 layout-id 13 for Clevo P950HR by MacPeet
Added ALC888 layout-id 27 for Acer Aspire 7738G by MacPeet
Added 300 Series PCH HD Audio Controller patch by chrome
Added ALC269 layout-id 66 for Clevo N155RD by DalianSky
Added ALC285 layout-id 11 for Lenovo ThinkPad X1C6th by Rover
Added ALC294 layout-id 11 for Asus FL8000U by Rover
Added ALC269 layout-id 58 for HASEE Z6-i78154S2 by lianny
Added ALC233 layout-id 32 for ASUS VIVOBOOK S301LA by MacPeet
v1.2.6 https://github.com/vit9696/AppleALC/releases">https://github.com/vit9696/AppleALC/releases
Fixed a rare kernel panic due to use-after-free in verb code at waking from sleep
v1.2.4
Added ALC269 layout-id 10 (toleda) for Brix by ttimasdf
Added ALC663 layout-id 99 for ASUS N71J by alex1960
Added CX20641 layout-id 11 and layout-id 13 for Dell OptiPlex 3010 or compatible by MacPeet
Added CX20642 layout-id 11 and layout-id 13 for Fujitsu ESPRIMO E910 E90+ or compatible by MacPeet
Added NVIDIA HDMI patches for GK208, GM206, GP102, GP106 for 10.13.4+ by FredWst
Added Intel HDMI patches for Haswell 0x0A260005 by Andrey1970
Added NVIDIA HDMI patch for GM200 by al3xtjame
v1.2.3
Added alcid=layout boot argument for testing purposes
Added automatic rename for HDEF device
Added ALC255 layout-id 18 for Aorus X5V7 by DuNe
Change Platforms18.xml.zlib for ALC255 by DuNe
Added ALC898 layout-id 101 by Andrey1970 (4 Line Out)
Added ALC262 layout-id 28 for HP Z800-Z600 series by MacPeet
Added ALC225 layout-id 33 by ChalesYu
Added ALC282 layout-id 127 No input boost Acer Aspire on IvyBridge by Andrey1970
Added ALC294 layout-id 13 by InsanelyDeepak
Added IDT92HD91BXX layout-id 13 for HP Envy 6 1171-SG by MacPeet
Quindi se non ho capito male possiamo eliminare il rename dal conf???
Added automatic rename for HDEF device...
hoff topic : ho visto che è disponibile anche intelGraphicFixup e anche qui dice :
Add GFX0 -> IGPU automatic rename
Add MEI/HECI -> IMEI automatic rename
Anche qui possiamo eliminarli dal config ????
Se te lo ha detto Gengik, hai già avuto il sigillo di garanzia :) io penso che se tu hai già configurato il tuo sistema nella maniera ottimale, meglio lasciarlo così. Tutte questi autocheck sui rename etc... sono molto utili quando uno senza arte ne parte comincia a farsi un hack; ma quando si sa dove e come mettere le manine, molto meglio la configurazione personalizzata :)
"iCanaro" post_id="1465" time="1520623234" user_id="57">
Appunto per questi motivi , stanno facilitando ogni individuo a fare hack anche i meno esperti , ovvio x noi abbiamo gia messo a punto è ininfluente emoticon_thanks
  • 3 weeks later...
v1.2.4
1.2.5 https://github.com/vit9696/AppleALC/releases">https://github.com/vit9696/AppleALC/releases
Implemented verb execution after wake (via WakeVerbReinit in PinConfigs), obsoletes CodecCommander in fixed resources
Implemented custom verbs for wake (via WakeConfigData in PinConfigs), ConfigData is used by default
Merged PinConfigs into AppleALC main binary by default for compatibility reasons
Hardened solved symbol verification to avoid panics with broken kext cache
Added PinConfigurations injection, since they provide useful debugging info
Added NVIDIA HDMI patch for GM204 for 10.13.4+
Added ALC233 layout-id 33 for ASUS VIVOBOOK S451LA by MacPeet
Added HD3000 desktop and laptop HDMI patches
Added wake verbs for ALCS1220A layout-id 1, 2, 5, 7 to avoid the need of CodecCommander
Added EAPD wake verbs to all ALC 221, 225, 233, 235, 236, 255, 256, 270, 271, 272, 284, 286, 288, 290, 293, 295 by Vandroiy
Added EAPD wake verbs to some ALC 269, 275, 280, 282, 283, 292, 294, 298, 662, 663, 668, 887, 888, 889, 892, 898, 1150 by Vandroiy
Fixed broken AFGLowPowerState, LayouID and other fields in several PinConfigs info.plist
Fixed kernel rare kernel panics due to short incompatible HDEF controller patches affecting other code
Ti ringrazio Alex, ma se lo ha tolto evidentemente sarà stato scoperto qualche grave bugs che ha preferito rimuovere e rimettere poi una versione corretta se non una nuova release :)
PS: ecco fatto, d'altronde la penultima versione la comprimo e la lascio in EFI in caso la nuova dia problemi ;)
Che figata i kext in EFI, ci metti un'attimo ad aggiornare/ripristinare emoticon-personaggi_89
"iCanaro" post_id="3848" time="1523181712" user_id="57">
si certo e che la smania di provare supera tutto .... emoticon_linguaccia
Hack 2 con nuovi appleALC e Shiki, sierra schermo nero e higt sierra 10.13.6 tranne hdmi niente periferiche audio... lavori in corso
come non detto... ho fatto una operazione alla: installo clover in un mac vero (se stai leggendo, non te la prendere :D) avevo spostato anche LILU emoticons_triste ora tutto OK
Release versione 1.2.8
    [list=]
"Gengik84" post_id="9436" time="1530798262" user_id="2">
    [list=]
Significa che non bisogna più settare il layout-id ma lo fa in automatico? (Un po' come è successo con il rename di HDEF?)
"marco.pisellonio80" post_id="9468" time="1530826323" user_id="59">
Ciao..su 10.14 alcuni layout (a ora) sono stati rimossi
Questa è la lista
[code]layout10.xml.zlib	layout100.xml.zlib	layout101.xml.zlib
layout102.xml.zlib	layout107.xml.zlib	layout108.xml.zlib
layout113.xml.zlib	layout114.xml.zlib	layout120.xml.zlib
layout121.xml.zlib	layout122.xml.zlib	layout123.xml.zlib
layout124.xml.zlib	layout125.xml.zlib	layout126.xml.zlib
layout127.xml.zlib	layout128.xml.zlib	layout129.xml.zlib
layout130.xml.zlib	layout131.xml.zlib	layout14.xml.zlib
layout15.xml.zlib	layout16.xml.zlib	layout16392.xml.zlib
layout17.xml.zlib	layout19.xml.zlib	layout2.xml.zlib
layout20.xml.zlib	layout21.xml.zlib	layout33.xml.zlib
layout35.xml.zlib	layout4.xml.zlib	layout40.xml.zlib
layout5.xml.zlib	layout51.xml.zlib	layout54.xml.zlib
layout57.xml.zlib	layout59.xml.zlib	layout6.xml.zlib
layout66.xml.zlib	layout7.xml.zlib	layout82.xml.zlib
layout83.xml.zlib	layout85.xml.zlib	layout86.xml.zlib
layout88.xml.zlib	layout90.xml.zlib	layout92.xml.zlib
layout93.xml.zlib	layout94.xml.zlib	layout95.xml.zlib
[/code]
Se per esempio usi 1.. AppleALC lo "falsifica" andando a prendere uno di quelli apple presenti
quindi si potrebbe vedere per esempio
layout-id=1 alc-layout-id 7 etc...
esempio
Release UFFICIALE
