[BETA] Clover Bootloader
Clover BETA
v2.4k_r4564
svg: implement rest functions correct mistakes, create test by F8 key - slice2009
v2.4k_r4563
 Fixes commit 4562 - philippetev
v2.4k_r4561
svg: add functions implementation - slice2009
v2.4k_r4559
Review XCODE settings in tools_def.txt and Clover.dsc - zenith432
Clover BETA
v2.4k_r4569
Remove include statements from .h files in clover-genconfig - zenith432
v2.4k_r4568A
fixed duplicate function declaration in clover-genconfig and refit/IO.h - vectorsigma
v2.4k_r4565
svg: debugging - slice2009
Clover BETA
v2.4k_r4577
fixed external drivers copy, allow duplicate optional drivers - vectorsigma
v2.4k_r4576
Set LANInjection default to TRUE, as it used to be before r4497, to prevent changes in system identification for iMessage - asava
v2.4k_r4575
rudimentary support for 'image' element. aspect ratio not fixed to 1 when rendering, by aksdfauytv - slice2009
v2.4k_r4574
basic text parsing by jamislike - slice2009
v2.4k_r4573
implement features by porglezomp, darealshinji, tesch1, boris-ulyanov - slice2009
v2.4k_r4572
Revert regression from r4559 - workaround does not work (makes macros always blank) - zenith432
v2.4k_r4571
Minimize dependencies in clover-genconfig; revert part of 4569 - zenith432
Clove BETA
v2.4k_r4581
more nanosvg fixes - slice2009
v2.4k_r4580
fix several bugs in nanosvg - slice2009
v2.4k_r4579
specific qsort will be faster then common - slice2009
v2.4k_r4578
multiple qsort - zenith432
Clocer BETA
v2.4k_r4586
correct group attribute to show Tiger - slice2009
v2.4k_r4585
correct float math - slice2009
v2.4k_r4584
sync edk2 svn r27429 - zenith432
v2.4k_r4583
correct sign print - slice2009
v2.4k_r4582
testing float - slice2009
Clover release ufficiale 4586 https://sourceforge.net/projects/cloverefiboot/files/?source=navbar">https://sourceforge.net/projects/clover ... rce=navbar">https://sourceforge.net/projects/cloverefiboot/files/?source=navbar
Clover BETA
v2.4k_r4592
draft font support - slice2009
v2.4k_r4591
text formatting - slice2009
v2.4k_r4590
patch for ticket 485, by nms42 - slice2009
v2.4k_r4589
allow chained gradients - slice2009
v2.4k_r4588
gradients repaired - slice2009
v2.4k_r4587
fix that causes a hang on boot in 10.14 beta when using Kaby Lake-R UHD Graphics - sherlocks
Clover BETA
v2.4k_r4596
speedup rasterizer by MalcolmMcLean - slice2009
v2.4k_r4595
fix mistakes in previous commit - slice2009
v2.4k_r4593
CSS class of style supported - slice2009
Clover BETA
v2.4_r4600
some debugging - slice2009
v2.4_r4599
vector font support - slice2009
v2.4_r4598
implement missing glyphs - slice2009
v2.4_r4597
move path chain to glyph - slice2009
Clover BETA v2.4k_r4601
 update platformdata and add MacBookPro15,x info - sherlocks
Clover BETA v2.4k_r4600
Installato con successo negli hack 1, 2, e 3 in firma la v4600
CLOVER BETA
v2.4k_r4606
add coffeelake framebuffer info - sherlocks
v2.4k_r4605
IPF support was dropped from EDK2 in r27483 - zenith432
v2.4k_r4604
correct memory allocation - slice2009
v2.4k_r4603
Update to binutils 2.31; sync UDK2018 branch - zenith432
v2.4k_r4602
padding structures to eliminate allocation bugs - slice2009
Clover BETA
v2.4k_r4612
Clover.PrefPane and CloverUpdater updated with moder objective-c code. xibs requires Xcode 5.1+ - vectorsigma
v2.4k_r4611
introduced clip-path, by poke1024 - slice2009
v2.4k_r4610
implement links to shapes and gradients - slice2009
v2.4k_r4609
correct wrong part from r4608 - sherlocks
v2.4k_r4608
cleanup all framebuffer info. thanks to vit9696 - sherlocks
v2.4k_r4607
correct font drawing: inner holes - slice2009
Installato con successo il 4609 negli hack 1, 2 e 3
CLOVER BETA
v2.4k_r4618
 added AptioFix3 into package - slice2009
v2.4k_r4617
some cleanup and reformatting - slice2009
v2.4k_r4616
autolayout disabled for Clover prefpane - vectorsigma
v2.4k_r4615
ensure make clean delete apllications build folders - vectorsigma
v2.4k_r4614
separate own procedures from nanosvg - slice2009
v2.4k_r4613
add clip-path rasterizer by poke1024 - slice2009
Release Ufficiale v2.4k_r4617 https://sourceforge.net/projects/cloverefiboot/files/?source=navbar">https://sourceforge.net/projects/clover ... rce=navbar">https://sourceforge.net/projects/cloverefiboot/files/?source=navbar
CloverConfigurator
5.1.4.0
Updated platformdata in SMBIOS section
Updated ig-platform-id in Graphics section
Fixes [Thanks to headkaze]
@Gengik84[/mention] AptioFix3 che tu sappia l'hanno reintrodotto in quanto aggiornato, oppure perché con i portatili funziona meglio lo stop e l'ibernazione, cose che con aptiomemoryfix funzionano peggio?!
Aptio V3 è la prima versione con supporto nativo nvram,stato fatto diciamo di Vit9696.. le sue modifiche iniziali furono su AptioV2, poi dopo è stato fatto un driver a se
Essendo driver molto vecchi e come dice Vit scritti in modo orribile, creò successivamente AptioMemory
Detto questo di fatto clover e ibernazione sono basati su AptioV2 che era il requisito per questa funzione
CLOVER BETA
v2.4k_r4630
new look for Clover installer, graphics and descriptions, by Clovy - slice2009
v2.4k_r4629
some step in SVG parsing over - slice2009
v2.4k_r4628
update MacBookPro15,2 info - sherlocks
v2.4k_r4627
add entry for Antergos - sherlocks
v2.4k_r4626
Update build_gcc8.sh to gcc 8.2, binutils 2.31.1 - zenith432
v2.4k_r4625
increase atan precision - slice2009
v2.4k_r4624
consider Disabled option for AddProperties - sherlocks
v2.4k_r4623
correct previous commit - slice2009
v2.4k_r4622
improve atan2, initial implement text support - slice2009
v2.4k_r4621
add cannonlake framebuffer info. thanks to vit9696 - sherlocks
v2.4k_r4620
initial support for conic gradients - slice2009
v2.4k_r4619
allow gradients outside of defs - slice2009
Ha scritto dopo 1 ora 5 minuti 15 secondi:
ma questi efi in quali occasioni possono essere utili???
https://postimg.cc/image/iir87g4ml/">LINK_TEXT>
https://postimg.cc/image/ojox4lr9p/">LINK_TEXT>
Ha scritto dopo 6 minuti 3 secondi:
Clover 4630 ufficiale
Clover BETA
v2.4k_r4636
 sorting drivers in the package also on apfs volumes - vectorsigma
v2.4k_r4635
ATOM CPU not supported FLEX_RATIO, ticket 488 - slice2009
v2.4k_r4634
workaround for ibtool in Xcode10 Beta that prevent compileling xibs in some system - vectorsigma
v2.4k_r4633
remove old key for KernelIvyXCPM, AsusAICPUPM - sherlocks
v2.4k_r4632
cleanup the korean language in installer - sherlocks
v2.4k_r4631
correct some misprints in installer - slice2009
Riporto questa da IM https://www.insanelymac.com/forum/topic/329777-clover-problems-report-features-request/?do=findComment&comment=2628867">https://www.insanelymac.com/forum/topic ... nt=2628867">https://www.insanelymac.com/forum/topic/329777-clover-problems-report-features-request/?do=findComment&comment=2628867
Posso confermare questo problema quando installo nuove versioni di Clover in modalità legacy, boot0af non viene installato correttamente nell'MBR di una nuova unità (installazione di boot1f32 di PBR OK).
Sembra una regressione causata da r4541 (usa dd per installare i settori di avvio invece di fdisk440). L'utilizzo di Bootice 64 bit in Windows per installare boot0af su MBR (o l'installazione di settori di avvio con la versione Clover precedente alla r4541) ripristina la capacità di avvio.
https://github.com/Dids/clover-builder/releases?after=v2.4k_r4551">https://github.com/Dids/clover-builder/ ... 2.4k_r4551">https://github.com/Dids/clover-builder/releases?after=v2.4k_r4551
quindi riepilogando, se si esegue una installazione in legacy di clover e questi non si avvia o non viene visto da BIOS o boot manager, forse è presente un bug nel metodo di installazione nei settori mbr, risolvibile usando una versione precedente alla 4541. Poi naturalmente si aggiorna clover all'ultima release NON aggiornando i settori di boot
In merito alla 4637 ATTENZIONE!!! non ho capito se hanno fatto degli errori o se ci stanno cambiamenti radicali in arrivo... se si prova a installarla vedere le differenze in drivers64 e drivers64UEFI tra questa release e la precedente... dei driver apfs è rimasto solo l'open source, niente HFS e niente aptiomemoryfix in drivers64, mentre quello in drivers64UEFI ha cambiato denominazione AptioMemoryFix-64 e dimensione
quindi OCIO e backup ;)
Ha scritto dopo 7 minuti 33 secondi:
@Baio77[/mention] la iso la trovo molto comoda per quando si deve estrapolare un qualche driver ;)
