[BETA] Clover Bootloader
Dalla V 2.4 r4819 alla V 2.4 r4831 di seguito le Fix apportate
seal conicGradient from Illustrator
Fix horizontal placement of icons for raster themes
better VS2013 compatibility
Fix for ticket #528
restrict clip-path to be used only in banner
show daylight is log
Fix r4826: -> operator has higher precedence than unary LICENSE.md README.md operator
Add/Update some icons to christmas and newyear themes.
Change GUI EntriesWidth to equal row0TileSize, and change math to horizontally centre main icons. Note: This will affect themes that use the TileXSpace layout option.
Fix scrollbar elements that use transaprency.
EDIT
Dalla V2.4 r4832 alla V2.4 4839
text formatting
fix wavelib compilation
fix library names
added hdacodec into svn control
CLOVER BETA
v2.4k_r4839
v2.4k_r4836
fix library names
v2.4k_r4834
v2.4k_r4832
text formatting
Dalla Rev 4833 è presente una interfaccia audio in Clover
https://www.insanelymac.com/forum/topic/304530-clover-change-explanations/?page=6&tab=comments#comment-2657187">https://www.insanelymac.com/forum/topic ... nt-2657187">https://www.insanelymac.com/forum/topic/304530-clover-change-explanations/?page=6&tab=comments#comment-2657187
CLOVER BETA
v2.4k_r4843
 include AudioDxe into package
v2.4k_r4842
missing definition
v2.4k_r4840
a choice between sync and async startup sound play
Rilasciata la release ufficiale 4844
CLOVER BETA
v2.4k_r4846
repair kext injection in Mojave, by vit9696
v2.4k_r4845
fix positions with bootCampStyle, by Needy
vector clover logo
v2.4k_r4844
accept audiodxe changes from goldfish64
CLOVER BETA
v2.4k_r4852
tune startup sound properties from GUI
v2.4k_r4851
update AudioDxe driver to sync with origin
v2.4k_r4850
security update for audio drivers
v2.4k_r4849
exclude redundant procedures
v2.4k_r4848
add embedded sound
v2.4k_r4847
tune and test startupsound from GUI
v2.4k_r4846
https://postimg.cc/XpQrw6Bf">screenshot1.png
https://postimg.cc/fJBKqbrk">screenshot3.png
CLOVER BETA
v2.4k_r4855
 correct save and restore audio parameters
v2.4k_r4854
change a metal to cesium
v2.4k_r4853
fixes for daylight and embedded sound by tluck
update romanian translations by arsradu
NB: clover 4855 hack 3 impostando nel BIOS da front panel HD audio a AC97 ho ottenuto il suono di avvio prima del caricamento della GUI di clover emoticon-personaggi_89 empticons_thu
@Baio77[/mention] intanto verifica se nei temi è presente sound.wav
se non ce l'hai metti questo decompresso nella cartella di ogni tema che hai
poi occorre settare da GUI di clover il livello audio, di default è 0000 io ho impostato 0060
selezioni l'uscita audio dai invio e con F7 dovresti sentirlo, a me questa non ha funzionato... poi la più importante, queste info vengono salvate nella NVRAM quindi se non è nativa non è possibile avere il suono di avvio
Ha scritto dopo 14 minuti 37 secondi:
Tutto spiegato quà dai supremi boss dell'hack
https://www.insanelymac.com/forum/topic/304530-clover-change-explanations/?do=findComment&comment=2660028">https://www.insanelymac.com/forum/topic ... nt=2660028">https://www.insanelymac.com/forum/topic/304530-clover-change-explanations/?do=findComment&comment=2660028
sound.wav.zipFetching info...
CLOVER BETA
v2.4k_r4862 --> diventata release finale scaricabile dal canale ufficiale
fix kext injection for Mojave by PMheart
v2.4k_r4861
better save and restore audio parameters
v2.4k_r4860
fix audio output numeration
v2.4k_r4859
startup sound variables will be stored under AppleBootGuid for legacy compatibility
v2.4k_r4858
improve reset nvram for bootchime. add more linux entry
v2.4k_r4857
check variables in audio interface
v2.4k_r4856
fix some audio bugs
CLOVER BETA:
v2.4k_r4870
change vertical layout to show optimus
v2.4k_r4868
PlayAsync works with own audiodxe
v2.4k_r4867
correct message position
v2.4k_r4866
cant distribute sound.wav because of licenses
v2.4k_r4865
fix an issue with sound variables at legacy boot
v2.4k_r4864
update efi version for some models
v2.4k_r4863
fix lapic patch for Mojave by PMheart. improve reset emuvariable nvram for bootchime
allora macachi chi è riuscito ad avere il suono di avvio? :D
nelle configuazioni dove l'uscita avviene con la scheda audio integrata, ho il suono all'entrata nella GUI di clover che al caricamento dei ++++++
dove ho uscita HDMI niente da fare... zero...
non ho ancora capito dove o come si setta il playasync
https://www.insanelymac.com/forum/topic/284656-clover-general-discussion/?do=findComment&comment=2661812">https://www.insanelymac.com/forum/topic ... nt=2661812">https://www.insanelymac.com/forum/topic/284656-clover-general-discussion/?do=findComment&comment=2661812
nessuna novità per suono HDMI???
ho capito e sono riuscito a configurare il livello suono con
BootChimecfg.efi
quindi ora negli hack con uscita NON HDMI ho il suono pre GUI clover e post GUI e ho settato 2 suoni diversi, almeno il preGUI
@Baio77[/mention] ora con l'ultimo clover configurator puoi settare installare cose funzionali all'audio, quindi avvialo e aggiornalo
in HDMI pure io ancora niente, ma in uscita audio verde, ho il suone, differenziato, per GUI e post GUI clover ;)
Clover beta & finale
v2.4k_r4871
add sound by Rodion
per ottenere il suono durante il caricamento di clover basta mettere il file sound.wav nella cartella del tema in uso ed avere audiodxe.efi nei drivers. Per non avere ritardi nel caricamento GUI meglio spuntare playasync che è una opzione aggiunta nel'ultimo clover configurator
Il suono post GUI non è ufficialmente supportato dai boss su IM ma in molti lo usano... per chi si vuole fare una idea di quello che si puo ottenere, ecco mio hack 3 https://mega.nz/#!r2J11Qrb!gXD7YaA7ruCD2HJ9JphYj-Ew761foeADbizchAODjsM">https://mega.nz/#!r2J11Qrb!gXD7YaA7ruCD ... izchAODjsM">https://mega.nz/#!r2J11Qrb!gXD7YaA7ruCD2HJ9JphYj-Ew761foeADbizchAODjsM
  Quote
"iCanaro" post_id="24852" time="1549267144" user_id="57">
v2.4k_r4871
add sound by Rodion
  Quote
Il link non funziona
@Jolly[/mention] mi hai beccato nel momento che toglievo il primo del video originale da 100Mb :D l'ho convertito e messo un secondo più leggero da 5Mb... riprova adesso :)
  • 4 weeks later...
CLOVER BETA da v2.4k_r4871 a v2.4k_r4895
fix a mistake with EDID search
legacy Clover will search EDID for several ports, by RodionS
Update changes to build_rule.txt made in edk2 from 2018-08-16 through 2019-02-14
more correct hda dump
fix misprint
improved HdaCodecDump
ConsoleMode should be set before switching to graphics + fix typo in GetEdidDiscovered
fix misprint
cleanup bootcamp style by Needy
sync edk2 svn r28892 (credits to apianti for handling of EmuRuntimeDxe)
Mistakes of r4882
Workaround for Base64Decode being defined in OcSupportPkg with identical prototype to BaseLib
Mistakes of r4880 (cherry pick edk2 svn r28507 into Clover shell)
sync edk2 svn r28853
Conflicting Base64Decode was introduced into edk2 at svn r28780
Invoking edksetup.sh with 'set -u' breaks the build after changes made to edksetup.sh in edk2 svn r28763-r28766
New nasm version in build script
restart audio configuration while changing theme
update platformdata
missing argument
add sound by Rodion
  • 4 weeks later...
Release Beta e Finale coincidenti: v2.4k_4910
update nvidia identification
fix signed mismatch
use separate names for several lan cards
fix misprints
automatic determine Nvidia card family
do not create _DSM for HDEF device
fake USB device-id from ICH9 to ICH10
fix ref counting in VBoxHfs, by nms42
fix mistake of rev3904
update bios and efi verison.
make byte ACPI access, optional ASPM
Change windows build to be less complicated and just do stuff
Fix some code that does not compile in later versions of visual studio
sync edk2 svn r28976 (tagged as edk2-stable201903)
Add floating point support to 32-bit windows build
Revert some unnecessary changes to cbuild.bat
Fix some right shift compiler intrinsic function link errors by using EDK intrinsics
  • 3 weeks later...
Rilasciato Clover 4920 [shadow=blue]beta[/shadow] e anche la [dropshadow=blue]release ufficiale[/dropshadow]
improve automatic audio injection
exclude redundant lines
add info for iMac Early 2019. thanks to bootmacos
Fix another time zone problem
Fix default time zone handling
cleanup iGPU values and fix force reboot when wakes up with an HDMI connected in 10.14+
Upgrade GCC and MTOC versions
fix MatchOS for 10.14, only 10.14 (10.14.1 will be skipped) case
Remove EdkCompatibilityPkg from update.sh since it is not used and no longer present in edk2-master
fix applertc patch for 10.14.4+. thanks to RodionS
Installato il 4920 nei mie hack 2 e 3 in firma... tutto OK
segnalo anche, per chi interessa approfondire, che hanno spostato e ripreso a mano il wiki di clover, vedi qui
https://sourceforge.net/p/cloverefiboot/wiki/Home/">https://sourceforge.net/p/cloverefiboot/wiki/Home/
screenshot.png?format=raw"><a href=https://sourceforge.net/p/cloverefiboot ... format=raw">https://sourceforge.net/p/cloverefiboot/themes/ci/master/tree/themes/BGM/screenshot.png?format=raw' alt='LINK_TEXT>'>
Clover Beta
4924 -- Update coffeelake_ig_vals from OS 10.14.4
4923 -- fix acidantera access
4922 -- set loosen variable in message
4921 -- update bios and efi version. fix 1st Gen Intel HD Graphics QE/CI when using intel inject
