[BETA] Clover Bootloader
CLOVER BETA
v2.4k_r4702
consider _UID for old intel graphics - sherlocks
v2.4k_r4701
update latest bios version - sherlocks
v2.4k_r4700
fix compilation for acidantera - slice2009[/color]
Versione ufficiale disponibile 4700
Nuove Beta
Dalla V.2.4 4703 alla V2.4 4714
Correzioni x queste versioni in ordine progressivo:
-use shell definitions from clover folder preliminary parse theme.svg - slice2009
-if MaxBacklight then Backlight - slice2009
-global mistake with name Scale dont free shape pathes other debugging - slice2009
-improve IntelBacklight. fix blackscreen issue for coffeelake laptop thanks to headkaze. fix EDID injection if properties by rehabman - sherlocks
-take into account more theme icons handle group visibility - slice2009
-add more image to parse numerous fixes - slice2009
-improve bios release date and add EFI version for mojave - sherlocks
-correct MP5,1 bios version - sherlocks
-a new formula of intelbacklight for coffeelake by rehabman - sherlocks
-dont relate to parent group - slice2009
CLOVER BETA
v2.4k_r4717
prevent clover boot options from being deleted when NVRAM is reset - sherlocks
v2.4k_r4716
 new way for reset native NVRAM in GUI by Sherlocks. thanks to vit9696. back to formula for coffelake backlight. - sherlocks
v2.4k_r4715
use font style for Menu as global font style - slice2009
CLOVER BETA
v2.4k_r4721
update EFI Version for Mojave. correct intelmaxvalue display as hex in GUI. - sherlocks
v2.4k_r4720
dont pretransform pathes exclude used shapes from rest of image - slice2009
v2.4k_r4719
add prelang kbd option if want to keep language when updating macOS with native NVRAM. - sherlocks
v2.4k_r4718
fix freezing issue when using reset NVRAM in GUI. add iGPU device id of 9th intel CPU. - sherlocks
Clover Beta
Dalla V2.4k_r4723 alla r4727
gradients repaired - slice2009
correct link distance is parseUse - slice2009
vector theme rendering - slice2009
fix brightness level problem of actual monitor when intelbacklight for sandy/ivy - sherlocks
correct opacity by clovy - slice2009
anche con la 4733 scritte in cirillico... e dire che glielo avevano già fatto notare ieri di questa cosa nel thread su IM
Ha scritto dopo 1 ora 53 minuti 4 secondi:
al 4734 risponde sempre cirillo :D
@Baio77[/mention] finalmente dalla 4735 risolto il problema con cirillo :)
CLOVER BETA
v2.4k_r4749
 using vector font drawing - slice2009
v2.4k_r4748
a possibility to inject commom FB for AMDRadeon, green compatible - slice2009
v2.4k_r4747
support for embedded PNG implement dithering - slice2009
v2.4k_r4746
add MacBookAir8,1 info - sherlocks
v2.4k_r4745
update clovy theme - slice2009
v2.4k_r4744
add Macmini8,1 info. thanks to Rodion Shingarev - sherlocks
v2.4k_r4743
correct os_icon names, by blackosx - slice2009
v2.4k_r4742
correct text size after theme change fix animation transparency - slice2009
Ha scritto dopo 1 minuto 5 secondi:
@Gengik84[/mention] hey boss :D ma
vuole dire che le schede video AMD possono funzionare senza WEG?
"iCanaro" post_id="18369" time="1541849658" user_id="57">
Gengik84 hey boss :D ma
Chi ha detto che è obbligo usare WEG?
si OK, ce ne stanno diverse che funzionano senza niente, in genere comunque si consiglia sempre di mettere LILU e WEG. Mi domandavo in quelle che se non metti WEG si ha black screen nel macOS, se a partire da questo clover si evitava il "problema" e se occorreva o meno qualche flag nel config.
Se hai qualche dritta sono a orecchie aperte... sembro topo gigio :D
436x?
li provo si.. ma come sempre detto li sconsiglio nell'uso diciamo generale in quanto di fatto beta
è stato messo mano a diverse cose (forse troppe tute insieme? ), dove altre cose precedenti e stabili hanno problemi
