Shaneee Posted February 12, 2019 Share Posted February 12, 2019 https://i.imgur.com/wXF2L4c.png' alt='wXF2L4c.png'> Installed Operating Systems: Mojave 10.14.1 - Windows 10 Pro (Insider) CPU: Ryzen 5 2400G Motherboard: GIGABYTE GA-AB350-Gaming 3 RAM: 8GB DDR4 Graphics: ASUS ROG Strix RX560 HDD: 500GB 960 EVO - MX500 250GB - 2TB Seagate - 640GB WDC - 500GB WDC Networking: RTL8111 Sound: AppleALC Bootloader: Clover Install Method: createinstallmedia Used Kexts: FakeSMC AmdCPUMonitor ITEIT87x RadeonMonitor Lilu AppleALC Whatevergreen RealtekRTL8111 What's Working: Sleep All USB is Native iCloud / App Store Native Audio thanks to AppleALC and Algrey Any special fixes? A custom SSDT to fix NVME drive showing as external. https://i.imgur.com/uwW2cHW.png' alt='uwW2cHW.png'> https://i.imgur.com/4qRpXT4.png' alt='4qRpXT4.png'> Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 12, 2019 Administrators Share Posted February 12, 2019 Quote "Shaneee" post_id="25842" time="1550006161" user_id="1001"> Shaneee post_id=25842 time=1550006161 user_id=1001 said: Installed Operating Systems: Mojave 10.14.1 - Windows 10 Pro (Insider) CPU: Ryzen 5 2400G Motherboard: GIGABYTE GA-AB350-Gaming 3 RAM: 8GB DDR4 Graphics: ASUS ROG Strix RX560 HDD: 500GB 960 EVO - MX500 250GB - 2TB Seagate - 640GB WDC - 500GB WDC Networking: RTL8111 Sound: AppleALC Bootloader: Clover Install Method: createinstallmedia Used Kexts: FakeSMC AmdCPUMonitor ITEIT87x RadeonMonitor Lilu AppleALC Whatevergreen RealtekRTL8111 What's Working: Sleep All USB is Native iCloud / App Store Native Audio thanks to AppleALC and Algrey Any special fixes? A custom SSDT to fix NVME drive showing as external. Quote Have you got your CPU temperature showing up? Mine doesn't show up, sadly :( Link to comment Share on other sites More sharing options...
Shaneee Posted February 12, 2019 Author Share Posted February 12, 2019 Quote "Ciro82" post_id="25843" time="1550006285" user_id="48"> Ciro82 post_id=25843 time=1550006285 user_id=48 said: Have you got your CPU temperature showing up? Mine doesn't show up, sadly :( Quote Sure do, https://i.imgur.com/Oh5R1KG.png' alt='Oh5R1KG.png'> I see you are using VirtualSMC though. I don't think there is a CPU sensor compatible with AMD for it. That's the reason I still use Slice's branch of FakeSMC. Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 12, 2019 Administrators Share Posted February 12, 2019 Quote "Shaneee" post_id="25844" time="1550006462" user_id="1001"> Shaneee post_id=25844 time=1550006462 user_id=1001 said: Quote "Ciro82" post_id="25843" time="1550006285" user_id="48"> Ciro82 post_id=25843 time=1550006285 user_id=48 said: Have you got your CPU temperature showing up? Mine doesn't show up, sadly :( Quote Sure do, https://i.imgur.com/Oh5R1KG.png' alt='Oh5R1KG.png'> I see you are using VirtualSMC though. I don't think there is a CPU sensor compatible with AMD for it. That's the reason I still use Slice's branch of FakeSMC. Quote Damn, i may try to use it then :) What about the ITEIT87x one, is that one for the Motherboard sensors? Link to comment Share on other sites More sharing options...
Shaneee Posted February 12, 2019 Author Share Posted February 12, 2019 Quote "Ciro82" post_id="25845" time="1550006622" user_id="48"> Ciro82 post_id=25845 time=1550006622 user_id=48 said: Damn, i may try to use it then :) What about the ITEIT87x one, is that one for the Motherboard sensors? Quote Yeah it's for motherboard. Here's the files from my PC. Link to comment Share on other sites More sharing options...
Administrators Ciro82 Posted February 12, 2019 Administrators Share Posted February 12, 2019 Quote "Shaneee"> Quote Quote "Ciro82" post_id="25845" time="1550006622" user_id="48"> Ciro82 post_id=25845 time=1550006622 user_id=48 said: Damn, i may try to use it then :) What about the ITEIT87x one, is that one for the Motherboard sensors? Quote Yeah it's for motherboard. Here's the files from my PC. Link to comment Share on other sites More sharing options...
Baio77 Posted February 12, 2019 Share Posted February 12, 2019 Thanks for all emoticon-personaggi_89 emoticon_tecnologia Link to comment Share on other sites More sharing options...
