Mappatura porte Usb
  On 1/12/2020 at 1:48 PM, Gengik84 said:
ma hai letto la guida?
mi sembra poco... 😉
devi cercare la tabella che contiene XHC... comunque nel tuo caso è SSDT-4
la cartella origin viene ignorata quindi che ci siano tabelle o meno non fa differenza quindi se poi vorrai cancellarle, questo non crea problemi
Expand
Si, sto seguendo la tua guida (ho fatto lo screen sltanto dei SSDT). Sto cercando la stringa delle usb nel file "SSDT-4-xh_cfsd4" ma non c'è...
 * Intel ACPI Component Architecture
 * AML/ASL+ Disassembler version 20190816 (64-bit version)
 * Copyright (c) 2000 - 2019 Intel Corporation
 * Disassembling to symbolic ASL+ operators
 * Disassembly of iASLBY4AB3.aml, Sun Jan 12 15:14:56 2020
 * Original Table Header:
 *     Signature        "SSDT"
 *     Length           0x00002FD1 (12241)
 *     Revision         0x02
 *     Checksum         0x6D
 *     OEM ID           "INTEL"
 *     OEM Table ID     "xh_cfsd4"
 *     OEM Revision     0x00000000 (0)
 *     Compiler ID      "INTL"
 *     Compiler Version 0x20160527 (538314023)
DefinitionBlock ("", "SSDT", 2, "INTEL", "xh_cfsd4", 0x00000000)
    External (_SB_.PCI0.RP01.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP02.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP03.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP04.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP05.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP06.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP07.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP08.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP09.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP10.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP11.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP12.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP13.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP14.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP15.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP16.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP17.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP18.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP19.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.RP20.PXSX.WIST, MethodObj)    // 0 Arguments
    External (_SB_.PCI0.XHC_.RHUB, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS01, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS02, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS03, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS04, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS05, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS06, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS07, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS08, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS09, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS10, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS11, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS12, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS13, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.HS14, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS01, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS02, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS03, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS04, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS05, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS06, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS07, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS08, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS09, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.SS10, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.USR1, DeviceObj)
    External (_SB_.PCI0.XHC_.RHUB.USR2, DeviceObj)
    External (_SB_.UBTC.RUCC, MethodObj)    // 2 Arguments
    External (ATDV, UnknownObj)
    External (BED2, UnknownObj)
    External (BED3, UnknownObj)
    External (BTBR, UnknownObj)
    External (BTL2, UnknownObj)
    External (BTLE, UnknownObj)
    External (BTLL, UnknownObj)
    External (BTSE, UnknownObj)
    External (SXI1, IntObj)
    External (SXI2, IntObj)
    External (SXP1, IntObj)
    External (SXP2, IntObj)
    Name (NHSP, 0x0E)
    Name (NSSP, 0x0A)
    Name (DBPN, 0x09)
    Scope (\_SB.PCI0.XHC.RHUB)
        Name (H1CN, One)
        Name (H1VS, One)
        Name (H1TC, Zero)
        Name (H1CR, Zero)
        Name (H2CN, One)
        Name (H2VS, One)
        Name (H2TC, Zero)
        Name (H2CR, Zero)
        Name (H3CN, One)
        Name (H3VS, One)
        Name (H3TC, Zero)
        Name (H3CR, Zero)
        Name (H4CN, One)
        Name (H4VS, One)
        Name (H4TC, One)
        Name (H4CR, 0x04)
        Name (H5CN, One)
        Name (H5VS, One)
        Name (H5TC, Zero)
        Name (H5CR, Zero)
        Name (H6CN, One)
        Name (H6VS, One)
        Name (H6TC, Zero)
        Name (H6CR, Zero)
        Name (H7CN, One)
        Name (H7VS, One)
        Name (H7TC, Zero)
        Name (H7CR, Zero)
        Name (H8CN, One)
        Name (H8VS, One)
        Name (H8TC, Zero)
        Name (H8CR, Zero)
        Name (H9CN, One)
        Name (H9VS, One)
        Name (H9TC, Zero)
        Name (H9CR, Zero)
        Name (HACN, One)
        Name (HAVS, One)
        Name (HATC, Zero)
        Name (HACR, Zero)
        Name (HBCN, Zero)
        Name (HBVS, Zero)
        Name (HBTC, Zero)
        Name (HBCR, Zero)
        Name (HCCN, Zero)
        Name (HCVS, Zero)
        Name (HCTC, Zero)
        Name (HCCR, Zero)
        Name (HDCN, Zero)
        Name (HDVS, Zero)
        Name (HDTC, Zero)
        Name (HDCR, Zero)
        Name (HECN, Zero)
        Name (HEVS, Zero)
        Name (HETC, Zero)
        Name (HECR, Zero)
        Name (S1CN, One)
        Name (S1VS, One)
        Name (S1CP, One)
        Name (S1TC, Zero)
        Name (S1CR, Zero)
        Name (S2CN, One)
        Name (S2VS, One)
        Name (S2CP, 0x02)
        Name (S2TC, Zero)
        Name (S2CR, Zero)
        Name (S3CN, One)
        Name (S3VS, One)
        Name (S3CP, 0x03)
        Name (S3TC, Zero)
        Name (S3CR, Zero)
        Name (S4CN, One)
        Name (S4VS, One)
        Name (S4CP, 0x04)
        Name (S4TC, One)
        Name (S4CR, 0x04)
        Name (S5CN, One)
        Name (S5VS, One)
        Name (S5CP, 0x05)
        Name (S5TC, Zero)
        Name (S5CR, Zero)
        Name (S6CN, One)
        Name (S6VS, One)
        Name (S6CP, 0x06)
        Name (S6TC, Zero)
        Name (S6CR, Zero)
        Name (S7CN, One)
        Name (S7VS, One)
        Name (S7CP, 0x07)
        Name (S7TC, Zero)
        Name (S7CR, Zero)
        Name (S8CN, One)
        Name (S8VS, One)
        Name (S8CP, 0x08)
        Name (S8TC, Zero)
        Name (S8CR, Zero)
        Name (S9CN, Zero)
        Name (S9VS, Zero)
        Name (S9CP, Zero)
        Name (S9TC, Zero)
        Name (S9CR, Zero)
        Name (SACN, Zero)
        Name (SAVS, Zero)
        Name (SACP, Zero)
        Name (SATC, Zero)
        Name (SACR, Zero)
        Method (GPLD, 2, Serialized)
            Name (PCKG, Package (0x01)
                Buffer (0x10){}
            CreateField (DerefOf (PCKG [Zero]), Zero, 0x07, REV)
            REV = One
            CreateField (DerefOf (PCKG [Zero]), 0x40, One, VISI)
            VISI = Arg0
            CreateField (DerefOf (PCKG [Zero]), 0x57, 0x08, GPOS)
            GPOS = Arg1
            Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.GPLD.PCKG */
        Method (TPLD, 2, Serialized)
                Buffer (0x10){}
            REV = One
            VISI = Arg0
            GPOS = Arg1
            CreateField (DerefOf (PCKG [Zero]), 0x4A, 0x04, SHAP)
            SHAP = One
            CreateField (DerefOf (PCKG [Zero]), 0x20, 0x10, WID)
            WID = 0x08
            CreateField (DerefOf (PCKG [Zero]), 0x30, 0x10, HGT)
            HGT = 0x03
            Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.TPLD.PCKG */
        Method (GUPC, 1, Serialized)
            Name (PCKG, Package (0x04)
                Zero,
                0xFF,
                Zero,
                Zero
            PCKG [Zero] = Arg0
            Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.GUPC.PCKG */
        Method (TUPC, 1, Serialized)
                One,
                Zero,
                Zero,
                Zero
            PCKG [One] = Arg0
            Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.TUPC.PCKG */
    Method (CNDP, 0, NotSerialized)
        If (CondRefOf (\_SB.PCI0.RP01.PXSX))
            If (\_SB.PCI0.RP01.PXSX.WIST ())
                Return (One)
        If (\_SB.PCI0.RP02.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP03.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP04.PXSX.WIST ())
            Return (One)
        If (CondRefOf (\_SB.PCI0.RP05.PXSX))
            If (\_SB.PCI0.RP05.PXSX.WIST ())
                Return (One)
        If (\_SB.PCI0.RP06.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP07.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP08.PXSX.WIST ())
            Return (One)
        If (CondRefOf (\_SB.PCI0.RP09.PXSX))
            If (\_SB.PCI0.RP09.PXSX.WIST ())
                Return (One)
        If (\_SB.PCI0.RP10.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP11.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP12.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP13.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP14.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP15.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP16.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP17.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP18.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP19.PXSX.WIST ())
            Return (One)
        If (\_SB.PCI0.RP20.PXSX.WIST ())
            Return (One)
        Return (Zero)
    If ((NHSP >= One))
        Scope (\_SB.PCI0.XHC.RHUB.HS01)
            Method (_UPC, 0, NotSerialized)  // _UPC: USB Port Capabilities
                If ((H1TC == Zero))
                    Return (GUPC (H1CN))
                Else
                    Return (\_SB.UBTC.RUCC (H1CR, One))
            Method (_PLD, 0, NotSerialized)  // _PLD: Physical Location of Device
                If ((H1TC == Zero))
                    Return (GPLD (H1VS, One))
                Else
                    Return (\_SB.UBTC.RUCC (H1CR, 0x02))
            If (CondRefOf (DBPN))
                If (((DBPN == One) && CNDP ()))
                    Name (SADX, Package (0x03)
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                    Method (SADS, 0, Serialized)
                        DerefOf (SADX [One]) [One] = \ATDV /* External reference */
                        DerefOf (SADX [0x02]) [One] = \ATDV /* External reference */
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS01.SADX */
                    Name (BRDY, Package (0x02)
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                    Method (BRDS, 0, Serialized)
                        DerefOf (BRDY [One]) [One] = \BTSE /* External reference */
                        DerefOf (BRDY [One]) [0x02] = \BTBR /* External reference */
                        DerefOf (BRDY [One]) [0x03] = \BED2 /* External reference */
                        DerefOf (BRDY [One]) [0x04] = \BED3 /* External reference */
                        DerefOf (BRDY [One]) [0x05] = \BTLE /* External reference */
                        DerefOf (BRDY [One]) [0x06] = \BTL2 /* External reference */
                        DerefOf (BRDY [One]) [0x07] = \BTLL /* External reference */
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS01.BRDY */
                    Name (GPCX, Package (0x03)
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                    Method (GPC, 0, Serialized)
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS01.GPCX */
            If ((CondRefOf (SXI1) && CondRefOf (SXP1)))
                If (((SXI1 > Zero) && (SXP1 == One)))
                    Device (CIR)
                        Method (_ADR, 0, NotSerialized)  // _ADR: Address
                            Return ((One + SXI1))
            If ((CondRefOf (SXI2) && CondRefOf (SXP2)))
                If (((SXI2 > Zero) && (SXP2 == One)))
                    Device (CIR2)
                            Return ((One + SXI2))
    If ((NHSP >= 0x02))
        Scope (\_SB.PCI0.XHC.RHUB.HS02)
                If ((H2TC == Zero))
                    Return (GUPC (H2CN))
                Else
                    Return (\_SB.UBTC.RUCC (H2CR, One))
                If ((H2TC == Zero))
                    Return (GPLD (H2VS, 0x02))
                Else
                    Return (\_SB.UBTC.RUCC (H2CR, 0x02))
                If (((DBPN == 0x02) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS02.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS02.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS02.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x02)))
                    Device (CIR)
                            Return ((0x02 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x02)))
                    Device (CIR2)
                            Return ((0x02 + SXI2))
    If ((NHSP >= 0x03))
        Scope (\_SB.PCI0.XHC.RHUB.HS03)
                If ((H3TC == Zero))
                    Return (GUPC (H3CN))
                Else
                    Return (\_SB.UBTC.RUCC (H3CR, One))
                If ((H3TC == Zero))
                    Return (GPLD (H3VS, 0x03))
                Else
                    Return (\_SB.UBTC.RUCC (H3CR, 0x02))
                If (((DBPN == 0x03) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS03.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS03.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS03.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x03)))
                    Device (CIR)
                            Return ((0x03 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x03)))
                    Device (CIR2)
                            Return ((0x03 + SXI2))
    If ((NHSP >= 0x04))
        Scope (\_SB.PCI0.XHC.RHUB.HS04)
                If ((H4TC == Zero))
                    Return (GUPC (H4CN))
                Else
                    Return (\_SB.UBTC.RUCC (H4CR, One))
                If ((H4TC == Zero))
                    Return (GPLD (H4VS, 0x04))
                Else
                    Return (\_SB.UBTC.RUCC (H4CR, 0x02))
                If (((DBPN == 0x04) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS04.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS04.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS04.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x04)))
                    Device (CIR)
                            Return ((0x04 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x04)))
                    Device (CIR2)
                            Return ((0x04 + SXI2))
    If ((NHSP >= 0x05))
        Scope (\_SB.PCI0.XHC.RHUB.HS05)
                If ((H5TC == Zero))
                    Return (GUPC (H5CN))
                Else
                    Return (\_SB.UBTC.RUCC (H5CR, One))
                If ((H5TC == Zero))
                    Return (GPLD (H5VS, 0x05))
                Else
                    Return (\_SB.UBTC.RUCC (H5CR, 0x02))
                If (((DBPN == 0x05) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS05.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS05.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS05.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x05)))
                    Device (CIR)
                            Return ((0x05 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x05)))
                    Device (CIR2)
                            Return ((0x05 + SXI2))
    If ((NHSP >= 0x06))
        Scope (\_SB.PCI0.XHC.RHUB.HS06)
                If ((H6TC == Zero))
                    Return (GUPC (H6CN))
                Else
                    Return (\_SB.UBTC.RUCC (H6CR, One))
                If ((H6TC == Zero))
                    Return (GPLD (H6VS, 0x06))
                Else
                    Return (\_SB.UBTC.RUCC (H6CR, 0x02))
                If (((DBPN == 0x06) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS06.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS06.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS06.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x06)))
                    Device (CIR)
                            Return ((0x06 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x06)))
                    Device (CIR2)
                            Return ((0x06 + SXI2))
    If ((NHSP >= 0x07))
        Scope (\_SB.PCI0.XHC.RHUB.HS07)
                If ((H7TC == Zero))
                    Return (GUPC (H7CN))
                Else
                    Return (\_SB.UBTC.RUCC (H7CR, One))
                If ((H7TC == Zero))
                    Return (GPLD (H7VS, 0x07))
                Else
                    Return (\_SB.UBTC.RUCC (H7CR, 0x02))
                If (((DBPN == 0x07) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS07.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS07.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS07.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x07)))
                    Device (CIR)
                            Return ((0x07 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x07)))
                    Device (CIR2)
                            Return ((0x07 + SXI2))
    If ((NHSP >= 0x08))
        Scope (\_SB.PCI0.XHC.RHUB.HS08)
                If ((H8TC == Zero))
                    Return (GUPC (H8CN))
                Else
                    Return (\_SB.UBTC.RUCC (H8CR, One))
                If ((H8TC == Zero))
                    Return (GPLD (H8VS, 0x08))
                Else
                    Return (\_SB.UBTC.RUCC (H8CR, 0x02))
                If (((DBPN == 0x08) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS08.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS08.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS08.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x08)))
                    Device (CIR)
                            Return ((0x08 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x08)))
                    Device (CIR2)
                            Return ((0x08 + SXI2))
    If ((NHSP >= 0x09))
        Scope (\_SB.PCI0.XHC.RHUB.HS09)
                If ((H9TC == Zero))
                    Return (GUPC (H9CN))
                Else
                    Return (\_SB.UBTC.RUCC (H9CR, One))
                If ((H9TC == Zero))
                    Return (GPLD (H9VS, 0x09))
                Else
                    Return (\_SB.UBTC.RUCC (H9CR, 0x02))
                If (((DBPN == 0x09) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS09.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS09.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS09.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x09)))
                    Device (CIR)
                            Return ((0x09 + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x09)))
                    Device (CIR2)
                            Return ((0x09 + SXI2))
    If ((NHSP >= 0x0A))
        Scope (\_SB.PCI0.XHC.RHUB.HS10)
                If ((HATC == Zero))
                    Return (GUPC (HACN))
                Else
                    Return (\_SB.UBTC.RUCC (HACR, One))
                If ((HATC == Zero))
                    Return (GPLD (HAVS, 0x0A))
                Else
                    Return (\_SB.UBTC.RUCC (HACR, 0x02))
                If (((DBPN == 0x0A) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS10.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS10.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS10.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x0A)))
                    Device (CIR)
                            Return ((0x0A + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x0A)))
                    Device (CIR2)
                            Return ((0x0A + SXI2))
    If ((NHSP >= 0x0B))
        Scope (\_SB.PCI0.XHC.RHUB.HS11)
                If ((HBTC == Zero))
                    Return (GUPC (HBCN))
                Else
                    Return (\_SB.UBTC.RUCC (HBCR, One))
                If ((HBTC == Zero))
                    Return (GPLD (HBVS, 0x0B))
                Else
                    Return (\_SB.UBTC.RUCC (HBCR, 0x02))
                If (((DBPN == 0x0B) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS11.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS11.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS11.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x0B)))
                    Device (CIR)
                            Return ((0x0B + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x0B)))
                    Device (CIR2)
                            Return ((0x0B + SXI2))
    If ((NHSP >= 0x0C))
        Scope (\_SB.PCI0.XHC.RHUB.HS12)
                If ((HCTC == Zero))
                    Return (GUPC (HCCN))
                Else
                    Return (\_SB.UBTC.RUCC (HCCR, One))
                If ((HCTC == Zero))
                    Return (GPLD (HCVS, 0x0C))
                Else
                    Return (\_SB.UBTC.RUCC (HCCR, 0x02))
                If (((DBPN == 0x0C) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS12.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS12.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS12.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x0C)))
                    Device (CIR)
                            Return ((0x0C + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x0C)))
                    Device (CIR2)
                            Return ((0x0C + SXI2))
    If ((NHSP >= 0x0D))
        Scope (\_SB.PCI0.XHC.RHUB.HS13)
                If ((HDTC == Zero))
                    Return (GUPC (HDCN))
                Else
                    Return (\_SB.UBTC.RUCC (HDCR, One))
                If ((HDTC == Zero))
                    Return (GPLD (HDVS, 0x0D))
                Else
                    Return (\_SB.UBTC.RUCC (HDCR, 0x02))
                If (((DBPN == 0x0D) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS13.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS13.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS13.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x0D)))
                    Device (CIR)
                            Return ((0x0D + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x0D)))
                    Device (CIR2)
                            Return ((0x0D + SXI2))
    If ((NHSP >= 0x0E))
        Scope (\_SB.PCI0.XHC.RHUB.HS14)
                If ((HETC == Zero))
                    Return (GUPC (HECN))
                Else
                    Return (\_SB.UBTC.RUCC (HECR, One))
                If ((HETC == Zero))
                    Return (GPLD (HEVS, 0x0E))
                Else
                    Return (\_SB.UBTC.RUCC (HECR, 0x02))
                If (((DBPN == 0x0E) && CNDP ()))
                        Zero,
                        Package (0x02)
                            0x07,
                            0x80000000
                        Package (0x02)
                            0x12,
                            0x80000000
                        Return (SADX) /* \_SB_.PCI0.XHC_.RHUB.HS14.SADX */
                        Zero,
                        Package (0x08)
                            0x12,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80,
                            0x80
                        Return (BRDY) /* \_SB_.PCI0.XHC_.RHUB.HS14.BRDY */
                        Zero,
                        Package (0x02)
                            0x07,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Package (0x02)
                            0x12,
                            Package (0x03)
                                Zero,
                                Zero,
                                Zero
                        Return (GPCX) /* \_SB_.PCI0.XHC_.RHUB.HS14.GPCX */
                If (((SXI1 > Zero) && (SXP1 == 0x0E)))
                    Device (CIR)
                            Return ((0x0E + SXI1))
                If (((SXI2 > Zero) && (SXP2 == 0x0E)))
                    Device (CIR2)
                            Return ((0x0E + SXI2))
    Scope (\_SB.PCI0.XHC.RHUB.USR1)
            Return (GUPC (Zero))
            Return (GPLD (Zero, Zero))
    Scope (\_SB.PCI0.XHC.RHUB.USR2)
    If ((NSSP >= One))
        Scope (\_SB.PCI0.XHC.RHUB.SS01)
                If ((S1TC == Zero))
                    Return (GUPC (S1CN))
                Else
                    Return (\_SB.UBTC.RUCC (S1CR, One))
                If ((S1TC == Zero))
                    Return (GPLD (S1VS, S1CP))
                Else
                    Return (\_SB.UBTC.RUCC (S1CR, 0x02))
    If ((NSSP >= 0x02))
        Scope (\_SB.PCI0.XHC.RHUB.SS02)
                If ((S2TC == Zero))
                    Return (GUPC (S2CN))
                Else
                    Return (\_SB.UBTC.RUCC (S2CR, One))
                If ((S2TC == Zero))
                    Return (GPLD (S2VS, S2CP))
                Else
                    Return (\_SB.UBTC.RUCC (S2CR, 0x02))
    If ((NSSP >= 0x03))
        Scope (\_SB.PCI0.XHC.RHUB.SS03)
                If ((S3TC == Zero))
                    Return (GUPC (S3CN))
                Else
                    Return (\_SB.UBTC.RUCC (S3CR, One))
                If ((S3TC == Zero))
                    Return (GPLD (S3VS, S3CP))
                Else
                    Return (\_SB.UBTC.RUCC (S3CR, 0x02))
    If ((NSSP >= 0x04))
        Scope (\_SB.PCI0.XHC.RHUB.SS04)
                If ((S4TC == Zero))
                    Return (GUPC (S4CN))
                Else
                    Return (\_SB.UBTC.RUCC (S4CR, One))
                If ((S4TC == Zero))
                    Return (GPLD (S4VS, S4CP))
                Else
                    Return (\_SB.UBTC.RUCC (S4CR, 0x02))
    If ((NSSP >= 0x05))
        Scope (\_SB.PCI0.XHC.RHUB.SS05)
                If ((S5TC == Zero))
                    Return (GUPC (S5CN))
                Else
                    Return (\_SB.UBTC.RUCC (S5CR, One))
                If ((S5TC == Zero))
                    Return (GPLD (S5VS, S5CP))
                Else
                    Return (\_SB.UBTC.RUCC (S5CR, 0x02))
    If ((NSSP >= 0x06))
        Scope (\_SB.PCI0.XHC.RHUB.SS06)
                If ((S6TC == Zero))
                    Return (GUPC (S6CN))
                Else
                    Return (\_SB.UBTC.RUCC (S6CR, One))
                If ((S6TC == Zero))
                    Return (GPLD (S6VS, S6CP))
                Else
                    Return (\_SB.UBTC.RUCC (S6CR, 0x02))
    If ((NSSP >= 0x07))
        Scope (\_SB.PCI0.XHC.RHUB.SS07)
                If ((S7TC == Zero))
                    Return (GUPC (S7CN))
                Else
                    Return (\_SB.UBTC.RUCC (S7CR, One))
                If ((S7TC == Zero))
                    Return (GPLD (S7VS, S7CP))
                Else
                    Return (\_SB.UBTC.RUCC (S7CR, 0x02))
    If ((NSSP >= 0x08))
        Scope (\_SB.PCI0.XHC.RHUB.SS08)
                If ((S8TC == Zero))
                    Return (GUPC (S8CN))
                Else
                    Return (\_SB.UBTC.RUCC (S8CR, One))
                If ((S8TC == Zero))
                    Return (GPLD (S8VS, S8CP))
                Else
                    Return (\_SB.UBTC.RUCC (S8CR, 0x02))
    If ((NSSP >= 0x09))
        Scope (\_SB.PCI0.XHC.RHUB.SS09)
                If ((S9TC == Zero))
                    Return (GUPC (S9CN))
                Else
                    Return (\_SB.UBTC.RUCC (S9CR, One))
                If ((S9TC == Zero))
                    Return (GPLD (S9VS, S9CP))
                Else
                    Return (\_SB.UBTC.RUCC (S9CR, 0x02))
    If ((NSSP >= 0x0A))
        Scope (\_SB.PCI0.XHC.RHUB.SS10)
                If ((SATC == Zero))
                    Return (GUPC (SACN))
                Else
                    Return (\_SB.UBTC.RUCC (SACR, One))
                If ((SATC == Zero))
                    Return (GPLD (SAVS, SACP))
                Else
                    Return (\_SB.UBTC.RUCC (SACR, 0x02))
Dunque 😅:
Devo disabilitare:
HS04
HS09
SS04
SS05
Ho cambiato questi valori in zero per disabilitare e One per abilitare.
Ho modificato il config aggiungendo la voce
ho tolto le patch (UsbInjectall non l'avevo)
123740309_Schermata2020-01-12alle16_19_36.thumb.png.3587a5e0065360276b06a278fe070b4e.png
ed ho riavviato...
La prima cosa che ho notato è che apple mouse e tastiera non funzionano piu...
poi avviando IOreg...
1361166470_Schermata2020-01-12alle16_10_54.thumb.png.3fa328ab19feb10fdd9c926ea549b4f1.png
HS04 è ancora attiva
HS09 ok disabilitata
SS03 è sparita anche se ho impostato il valore su "One"...
SS04 ok disabilitata
SS05 ok disabilitata
Edited by bradipo666
Ciao, ho fatto la mappatura delle usb ma ioreg rileva delle porte attive che ho disattivato, come posso fare per risolvere? Ho ovviamente seguito tutta la guida di macils e la mappatura l'ho fatta per catalina con patchportlimit e io kext usb (mi riferisco a usbinjectall), come lenght ho messo 12237 nel config.plist.
ringrazio in anticipo chi mi aiuterà nel risolvere il mio problema
In allegato lascio tutti i file di origin, ioreg usb 2.0, 3.0, post mappatura e ssdt patchato dentro la cartella PATCHED.
Hardware:
motherboard: asus b360m-g gaming
cpu: i5 8400
gpu: r7 250x
Archivio.zipFetching info...
Edited by gabrycosta04
Ho dimenticato l'hardware :(
@gabrycosta04 magari apri thread per tuo hack che metterai in firma... visto che non ci conosciamo, passa in presentazioni poi:
in tuo thread posta hack_info, ioreg per mappatura unico (non importa ne fai 2 separati)  screenshots DPCImanager e magari EFI senza la cartella apple e microsof all'interno... quello che non capisci, leggi FAQ che ho in firma
vedo che hai ssdt x 390, non sono sicuro che sia il massimo per la tua serie, ma per essere caricato, è caricato
Expand
Ah ok va benissimo, lo faccio subito!
  On 1/15/2020 at 2:40 PM, Gengik84 said:
Ssdt va bene quello 390..
@gabrycosta04
ti riferisci a una SS e 2 Hs?
Comunque se rientri nel limite delle 15 porte, puoi lasciare anche porte in più di quelle che effettivamente stai usando
Expand
Ad entrambi! Ho 9 porte totali, posso lasciare così? Non vorrei cali di performance delle usb (visto che già ho avuto di questi problemi nel mio vecchio hack). In oltre vorrei un'altra cosa, la chiedo nel thread che sto creando direttamente!
Ragazzi ho rifatto la procedura da capo, solo che stavolta mi sono uscite porte da disattivare che nella prima volta nn erano uscite... comunque... il risultato è sempre lo stesso: mouse e tastiera Bluetooth nn ne vogliono sapere di funzionare... l’ultima prova che ho fatto e stata quella di abilitare soltanto la porta HS01 “One” e mettere tutte le altre su “Zero”. Ho compilato, salvato e sostituito il file nella EFI. Ho riavviato ma quando avvio ioreg e cerco XHC, mi dice che le porte attive sono HS01, HS04 e SS04... come è possibile?
