Raccolta Lista USB XHCI Patch Port Limit
Baio77
Port's Limit Patch per: Catalina, Mojave, High Sierra, Sierra, El Capitan
[ da usare temporaneamente, poi eseguire la mappatura porte USB vedi guida ]
da inserire nel config --> kernel & kext patches --> KextsToPatch
 Catalina 10.15.x
#1
Name*: com.apple.iokit.IOUSBHostFamily
Find*[Hex]: 83FB0F0F
Replace*[Hex]: 83FB3F0F
Comment: USB port limit patch 10.15.x credits @daliansky
MatchOS: 10.15.x
#2
Name*: com.apple.driver.usb.AppleUSBXHCI
Find*[Hex]: 83F90F0F
Replace*[Hex]: 83F93F0F
MatchOS: 10.15.x
 Mojave 10.14.6
#1
Name*: IOUSBHostFamily
Find*[Hex]: c20200e0 83fb0f
Replace*[Hex]: c20200e0 83fb3f
Comment: USB port limit patch 10.14.x (credit ydeng)
MatchOS: 10.14.x
#2
Find*[Hex]: 4183ff0f 0f839404 0000
Replace*[Hex]: 4183ff3f 0f839404 0000
Comment: USB port limit patch 10.14.6
MatchOS: 10.14.x
#3 [opzionale]
Find*[Hex]: 83E30FD3 E34109DF
Replace *[Hex]: 83E33FD3 E34109DF
Comment: patch 3 (10.14.4+)
MatchOS: 10.14.x
Mojave 10.14.4-10.14.5
Find: 83FB0F0F 870B0400 00
Repl: 83FB7F0F 870B0400 00
Comment: Port Limit Patch 1 credits PMheart (10.14.4+)
Find: 4183FF0F 0F839404 00 00
Repl: 4183FF3F 0F839404 00 00
Comment: Patch 2 (10.14.4+)
Find: 83E30FD3 E34109DF
Repl: 83E33FD3 E34109DF
Mojave 10.14.3 10.14.2-10.14.1
Find: 00e0 83fb 0f0f 8716 0400
Replace: 00e0 83fb 3f0f 8716 0400
Comment: USB port limit patch 10.14.1 10.14.2 10.14.3 Patch 1 (credit ydeng)
Find: 00 00 83 FB 0F 0F 83 8F 04 00 00
Replace: 00 00 83 FB 3F 0F 83 8F 04 00 00
Comment: USB Port limit patch 10.14.1 10.14.2 10.14.3 (patch 2)
Find: 83 E3 0F D3 E3 41 09 DF
Replace: 83 E3 3F D3 E3 41 09 DF
Comment: USB port name 10.14.1 10.14.2 10.14.3 (Patch 3)
Mojave 10.14
Find* [Hex]: 83 FB 0F 0F 83 03 05 00 00
Replace* [Hex] : 83 FB 0F 90 90 90 90 90 90
Comment: USB 10.14+ by PMHeart
MatchOS: 10.14.0
 High Sierra 10.13.6
Find* [HEX]: 837D880F 0F83A704 0000
Replace* [HEX]: 837D880F 90909090 9090
Comment: USB 10.13.6+ by PMHeart
MatchOS: 10.13.6
High Sierra 10.13.5
Find* [HEX]: 837d940f 0f839704 0000
Replace* [HEX]: 837d940f 90909090 9090
Comment: USB 10.13.4+ by PMHeart
MatchOS: 10.13.5
High Sierra 10.13.4
MatchOS: 10.13.4
High Sierra 10.13.3-10.13.2-10.13
Name*: AppleUSBXHCIPCI
Find* [Hex]: 837d8c10
Replace* [Hex] : 837d8c1b
Comment: change 15 port limit to 24
MatchOS: 10.13.3;10.13.2;10.13
 Sierra 10.12.x
Find* [Hex]: 83bd74ff ffff10
Replace* [Hex]: 83bd74ff ffff1b
Comment: change 15 port limit to 26
MatchOS: 10.12.x
 El Capitan 10.11.x
Find* [Hex]: 83bd8cfe ffff10
Replace* [Hex]: 83bd8cfe ffff1b
MatchOS: 10.11.x
Edited by iCanaro
Migliorie & Aggiornamenti
  • Like 3
Se mi posso permettere, per chi ha già un'hack pre mojave con tutte le USB funzionanti, di eseguire la mappatura delle medesime
GUIDA: mappature delle USB
una volta fatto questo, poi si può togliere USBinjectall se presente e PatchPortLimit e tutte le USB funzioneranno al TOP con tutti i macOS, mojave (visti i problemi attuali) e a qualsiasi aggiornamento del sistema.
Se poi si è proprio dei pigroni nonostante la parte tecnica più difficile di solito la esegue Gengik, si può usare FBPatcher di headkaze per generare un kext funzionale.
Edited by foskvs
Anche perchè di fatto ormai la patch per port limit su Mojave non funziona più, quindi chi ancora non avesse questo osx, consiglio di eseguire la mappatura sia per facilità visto la patch funzionante sia per evitare o aver meno problemi una volta passati all'ultimo osx
E' solo una mia pignoleria... Chi esegue un'installazione pulita di Mojave?
Edited by fabiosun
in qualunque caso dovrebbero essere mappate le usb e disattivate quelle non in uso proprio per il fatto che la patch su Mojave non funziona più e quindi uno si ritroverebbe a non avere usb 3.0.
ogni porta anche se 3.0 funzionerebbe solo come 2.0
quel kext inietta solo le porte.. ma Apple le blocca per via del port limit
Questo il motivo che non è efficace solo tale kext riferito a questo discorso
se vuoi mapparle, segui la mia guida, c'è il link nel post di @iCanaro
Edited by fabiosun
  • 4 weeks later...
@Baio77[/mention] mi pare che questa patch non sia presente, mi ci dai un'occhio?
aspè... che il traduttore ha infilato punti a destra e a manca :D corretto
Find* [HEX]:83FB0F0F 83030400 00
Replace* [HEX]: 83FB0F90 90909090 90​​
Comment: USB 10.14.1+ by PMHeart
MatchOS: 10.14.x[/hidden]
su 10.14.3 non credo che funzioni perchè il binario è cambiato
scrissi sul relativo topic Release la patch e se qualcuno la volesse provare
non ho avuto risposta :D
Ha scritto dopo 13 minuti 12 secondi:
mi sembra era questa
find
41 83 ff 0f 0f 83 94 04 00 00
repl
41 83 ff 3f 90 90 90 90 90 90
ora non ricordo se guardai il binario 10.14.3 o beta 1 di 10.14.4
@Gengik84[/mention] ecco il kext...
Ha scritto dopo 21 minuti 6 secondi:
fatto primo giro di test su mojave APFS 10.14.4beta, provate entrambe le patch senza e con USBinjectall, il risultato è che non vengono caricate tutte le USB
ora provo con mojave HFS 10.14.3 ma prima lo devo aggiornare, lo uso poco e sono ancora con la 10.14.2 :D
IOUSBHostFamily.kext_10.14.3.zip
IOUSBHostFamily.kext_10.14.2.zip
"iCanaro" post_id="24594" time="1549028428" user_id="57">
Ti servono i tentacoli x usare tutti i PC hai a disposizione e comunque 8 arti NON ti basterebbero emoticon-occhi_61 emoticon-occhi_61 emoticon-personaggi_89 emoticon-personaggi_89
allora dopo giro di prove con le patch port limit quella messa da gengik e l'altra di di PMheart che ho inserito su, in mojave 10.14.3 e 4beta a me in questo hack 2 in firma NON ne funziona nessuna :(
funziona con SSDT creatomi da gengik tramite la mappatura che eseguii comodamente su high sierra, oppure visto che ero in fase di test, avevo preparato ma mai testato USBports.kext con hackintool e questo funge pure lui
