Roberto Posted October 14, 2018 Share Posted October 14, 2018 Salve a tutti, ho questo notebook tra le mani con le seguenti caratteristiche: i3 2310m, intel hd 3000m, vorrei installare Highsierra ma i bootloader recenti (installati in legacy) mi da sempre un errore strano: rror uncopress prelinked kernel, error load prelinked kernel with status 0x8000000007 error loading kernel cache 0x7. Dopodichè passai direttamente a Sierra. Con un bootloader vecchio riesco a bootare, ma verso la fine vedo che si ferma a busy time out kextd wait appleacpicpu. Qualche suggerimento? :) Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted October 14, 2018 Supervisor. Share Posted October 14, 2018 Allega la EFI. Link to comment Share on other sites More sharing options...
Roberto Posted October 14, 2018 Author Share Posted October 14, 2018 "foskvs" post_id="16327" time="1539512323" user_id="58">Allega la EFI. EFI.zip Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted October 14, 2018 Supervisor. Share Posted October 14, 2018 Stai installando Sierra o High Sierra? Con le impostazioni attuali qual è l'errore? Link to comment Share on other sites More sharing options...
Roberto Posted October 14, 2018 Author Share Posted October 14, 2018 "foskvs" post_id="16333" time="1539514257" user_id="58"> Stai installando Sierra o High Sierra? Con le impostazioni attuali qual è l'errore? sierra, come ho scritto sopra si ferma qui, busy time out kextd wait appleacpicpu. Link to comment Share on other sites More sharing options...
Baio77 Posted October 14, 2018 Share Posted October 14, 2018 "Roberto" post_id="16334" time="1539514549" user_id="116"> "foskvs" post_id="16333" time="1539514257" user_id="58"> Stai installando Sierra o High Sierra? Con le impostazioni attuali qual è l'errore? sierra, come ho scritto sopra si ferma qui, busy time out kextd wait appleacpicpu. Prova questa Clover , se puoi aggiorna Clover alla versione Ufficiale corrente , la tua è abbastanza Obsoleta CLOVER.zip Link to comment Share on other sites More sharing options...
Supervisor. foskvs Posted October 14, 2018 Supervisor. Share Posted October 14, 2018 Ok, sposto. Rifai la usb da zero, per evitare conflitti tra i vari tentativi. https://www.macos86.it/viewtopic.php?f=41&t=2">viewtopic.php?f=41&t=2">https://www.macos86.it/viewtopic.php?f=41&t=2 Link to comment Share on other sites More sharing options...
Roberto Posted October 14, 2018 Author Share Posted October 14, 2018 "Baio77" post_id="16335" time="1539514796" user_id="55"> "Roberto" post_id="16334" time="1539514549" user_id="116"> "foskvs" post_id="16333" time="1539514257" user_id="58"> Stai installando Sierra o High Sierra? Con le impostazioni attuali qual è l'errore? sierra, come ho scritto sopra si ferma qui, busy time out kextd wait appleacpicpu. Prova questa Clover , se puoi aggiorna Clover alla versione Ufficiale corrente , la tua è abbastanza Obsoleta ho usato la tua cartella, ma erano prove che avevo già fatto io, cmq non va, stesso problema. E questo notebook non ha l'nvidia, ha solo la intel hd 3000 se no l'avrei riportato. Ha scritto dopo 2 minuti 14 secondi: "Roberto" post_id="16337" time="1539515510" user_id="116"> "Baio77" post_id="16335" time="1539514796" user_id="55"> "Roberto" post_id="16334" time="1539514549" user_id="116"> sierra, come ho scritto sopra si ferma qui, busy time out kextd wait appleacpicpu. Prova questa Clover , se puoi aggiorna Clover alla versione Ufficiale corrente , la tua è abbastanza Obsoleta ho usato la tua cartella, ma erano prove che avevo già fatto io, cmq non va, stesso problema. E questo notebook non ha l'nvidia, ha solo la intel hd 3000 se no l'avrei riportato. gli ultimi clover danno lo stesso problema che ho riportato sopra, installandolo in legacy da errore sul kernel Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 14, 2018 Administrators Share Posted October 14, 2018 Non Supporta uefi? Link to comment Share on other sites More sharing options...
Roberto Posted October 14, 2018 Author Share Posted October 14, 2018 "Gengik84" post_id="16339" time="1539515902" user_id="2"> Non Supporta uefi? no, purtroppo no Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 14, 2018 Administrators Share Posted October 14, 2018 Controlla il bios.. Può essere un impostazione che crea problemi di lettura del prelinked Link to comment Share on other sites More sharing options...
Roberto Posted October 14, 2018 Author Share Posted October 14, 2018 "Gengik84" post_id="16341" time="1539516587" user_id="2"> Controlla il bios.. Può essere un impostazione che crea problemi di lettura del prelinked il bios è molto limitato, posso cambiare pochissime cose, e quelle cose non mi sembrano che potrebbero interferire, un versione di clover vecchia cmq carica qualcosa.. Link to comment Share on other sites More sharing options...
Administrators Gengik84 Posted October 14, 2018 Administrators Share Posted October 14, 2018 @Roberto[/mention] rimuovi 0x00010000 non serve a nulla. rimuovi kernelPM rimuovi -disablegfxfirmware rimuovi kext-dev-mode aggiungi dart=0 Riprova... Link to comment Share on other sites More sharing options...
