ASUS ProArt X870E-CREATOR WIFI - Ryzen 9950x
26 minutes ago, fabiosun said:
@khileare you sure that rx6600 is full working?
have you tried it with other os?
so moved to slot 3 on pci-e and still not seen by Mac but works fine in windows and I can mirror or set it as main display and it works fine
Is the resize bar enabled in the BIOS? Also run a CMOS to force detection and reset the NVRAM on the Mac, reboot from Mac and see what the card says under Information/Graphics and Monitor. Basically, it should see it. I get an error without WhateverGreen.kext.
however it is the 4090 that predominates the slots, you have to try to temporarily remove it and try only the 6600 in pcie 1, once the mac is started insert it in the device properties of Opencore and put the boot arg nv_disable, put them back as they are now and try to start
this is your exact EFI updated for Tahoe
whatevergreen updated
patches updated
usbmap.kext updated for tahoe *
*here it seems you use two method for usb mapping (not good in my opinion)
Also SMBIOS could be updated to MacPro7.1 (you use instead iMacPro1.1)
also your core count is set to 6 it means you have a 6 cores cpu installed. Do You?
EDIT:
Also acpi ssdt section is a bit (too much) populated in my opinion
patches updated
EDIT:
thanks so much working very good
  • 3 months later...
patches updated
EDIT:
not working  For 26.4 Please Update it
