Support Team Anto65 Posted November 26, 2024 Support Team Share Posted November 26, 2024 Prova a caricare la EFI completa ( rimovi i seriali se vuoi ) Non hai accelerazione , schermo nero ? Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 un attimo. il config non era in oc perdonatemi provato . schermo nero Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 eccola EFI h410_rx580.zip Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 26, 2024 Support Team Share Posted November 26, 2024 Prova magari da usb avviabile EFI.zip reset nvram prima L ' SSDT-GA_H410M_H.aml da dove arriva ? Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 ricevimento di un altro ssdt Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 fa questo Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 26, 2024 Support Team Share Posted November 26, 2024 33 minuti fa, emiliano ha scritto: ricevimento di un altro ssdt 🙂 non l ho capita Cambia il Config.plist.zip Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 schermo nero Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 26, 2024 Support Team Share Posted November 26, 2024 Config.plist.zip Link to comment Share on other sites More sharing options...
Support Team Carbo Posted November 26, 2024 Support Team Share Posted November 26, 2024 Hai connesso il monitor con la DP? Con HDMI non va Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 Ha solo hdmi Link to comment Share on other sites More sharing options...
Support Team Carbo Posted November 26, 2024 Support Team Share Posted November 26, 2024 Ahia, non sono riuscito a farla funzionare 1 Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 Allora dobbiamo solo aspettare che qualche admin ci venga in soccorso. Incrocio le dita . Grazie di tutto intanto Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted November 26, 2024 Moderators Share Posted November 26, 2024 hai provato senza weg? Link to comment Share on other sites More sharing options...
emiliano Posted November 26, 2024 Author Share Posted November 26, 2024 La Kext ? Link to comment Share on other sites More sharing options...
Moderators carlo_67 Posted November 26, 2024 Moderators Share Posted November 26, 2024 si disabilitalo e riprova, prima prova a mettere nel bootarg agdpmod=pikera se non va disabilitalo e riprova sempre da usb, pulisci sempre nvram 1 Link to comment Share on other sites More sharing options...
emiliano Posted November 27, 2024 Author Share Posted November 27, 2024 buongiorno attui. disabilitato con agdpmod=pikera. continua così IMG_7875.png Link to comment Share on other sites More sharing options...
emiliano Posted November 28, 2024 Author Share Posted November 28, 2024 Buona sera. Ho un config che mi fa funzionare hd630 ma ho problemi con il risveglio dallo standby. In sostanza il display non si riattiva. Qualcuno mi può’ aiutare ? Grazie Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 28, 2024 Support Team Share Posted November 28, 2024 Bene , prova ad aggiungere DeviceProperties-PciRoot(0x0)/Pci(0x2,0x0) force-online ( Number )1 Link to comment Share on other sites More sharing options...
emiliano Posted November 28, 2024 Author Share Posted November 28, 2024 Puoi aiutarmi tu @Anto65. Non vorrei sbagliare. Grazie Config.plist.zip Link to comment Share on other sites More sharing options...
Support Team Anto65 Posted November 28, 2024 Support Team Share Posted November 28, 2024 Config.plist.zip 1 Link to comment Share on other sites More sharing options...
emiliano Posted November 28, 2024 Author Share Posted November 28, 2024 @Anto65 ripartito dallo standby. allego ioreg. però dopo essere irpartio ha grato per un po la rotella. grazie comunque Helmut’s iMac.zip Link to comment Share on other sites More sharing options...
emiliano Posted November 28, 2024 Author Share Posted November 28, 2024 Poi un’altra a cosa è qeusto lo faccia a già prima. Al riavvio mi parte sempre hackintool anche se mi. Ho spuntato di riaprire le finestre al login Link to comment Share on other sites More sharing options...
emiliano Posted November 28, 2024 Author Share Posted November 28, 2024 inoltre Launchpad non ha effetto sfumato forse perché ho solo 8 gb di ram Link to comment Share on other sites More sharing options...
