AMD FX-6300 hackintosh booted by OpenCore 0.9.5 successfully
jsl2000
  • 3 months later...
hello.
Thanks to the information you provided, I was able to successfully boot macOS Sonoma on the FX-8300 system.
However, neither Opencore nor Clover could avoid the blank screen problem.
The results were the same using RadeonDelnit.
Even when using other GPUs such as RX580, Vega FE, and R9 390, the blank screen issue still appears.
Could you please give me some advice on this issue?
FX-8300
AMD Radeon Vega FE, RX580, R9 390(GPU-Spoof)
Crosshair V Formula-Z
  • 6 months later...
On 3/20/2024 at 7:34 AM, bjjunpark said:
hello.
FX-8300
Before applied OCLP to patch its GPU & USB 1.1 I need add -amd_no_dgpu_accel in boot-args if GPU is AMD RX560.
I have changed my GPU to AMD RAdeon R9 270 2GB now to avoid this black screen issue before OCLP was applied.
On 11/26/2023 at 8:57 AM, jsl2000 said:
My FX-6300 hackintosh can boot Sonoma 14.2 beta3 by legacy OpenCore 0.9.5 with ProvideCurrentCpuInfo quirk enabled without red screen panic or blank screen issue now after its GPU RX-560 replaced by R9 270 and config.plist modified.
My config-OC-M5A.plist is attached for your reference.
I've a similar system, I'll try!!! Great result indeed!!!
