Build - Asus ROG X670E Hero + AMD Ryzen 9 7950X + AMD Radeon RX VEGA 56
luchina
After a lot of work and a lot of help from @fabiosun and @Lorys89, the monster is finally ready! Thank you very much for your help!
284071152-8e319275-6d93-4de5-b651-8e473e
Component Versions
Some Notes
  • Latest BIOS 1709 or higher, DSDT patch required, developed by @Lorys89 - Pls inject this DSDT.aml and set Enable/True RebaseRegions in config.plist
  • This EFI is compatible with Intel Wireless and Bluetooth (onboard Wi-Fi 6e AX210) for macOS Ventura and Sonoma
  • USBMap (corpnewt) method
For BIOS newer or equal to v1709
  • Post reference
Benchmarks
- Speedometer v2.1
- Geekbench v5 & v6
https://browser.geekbench.com/v6/cpu/3609806
https://browser.geekbench.com/v5/cpu/21961976
- Dehancer Benchmark / Davinci
- CPU Endurance for 10 minutes
- Cinebench R23
- Cinebench 2024 (CPU & GPU)
- Blackmagic RAW Speed Test
- Blackmagic Disk Speed Test
- Amorphous Memory Speed Test
Edited by luchina
Copy/Download of EFI
EFI-OC096-ASUS-ROG-CROSSHAIR-X670E-HERO-AMD-RYZEN-9-7950X-RADEON-VEGA-56.zip
Important
- EFI without kexts for Wireless because of the file size limit here on the forum;
- Download of AirportItlwm for Sonoma: https://github.com/OpenIntelWireless/itlwm/releases/download/v2.3.0-alpha/AirportItlwm-Sonoma-v2.3.0-DEBUG-alpha-ff1138b.zip
- Download of AirportItlwm for Ventura: https://github.com/OpenIntelWireless/itlwm/releases/download/v2.2.0/AirportItlwm_v2.2.0_stable_Ventura.kext.zip
- Pls rename this files for "AirportItlwm-Sonoma.kext", "AirportItlwm-Ventura.kext"  and copy to Kexts directory in EFI/OC/Kexts
Edited by luchina
2 hours ago, Lorys89 said:
Add kext smc super io and SMCProcessorAMD and disable 2 kext SMCAMDProcessor and AMDRyzenCPUPowerManagement
https://github.com/Lorys89/SMCProcessorAMD/releases/download/1.0.1/SMCProcessorAMD-1.0.1-RELEASE.zip
I don't know these new kexts.
Do they support using the AMD Power Gadget app?
When you say SMCSuperIO, is it the one that comes with VirtualSMC package? Or is it some other variation?
Thanks 😉
